Question about LG RU-27FB30C TV
LG RU-27FB30 The TV will simply not turn on. It looks like it was knocked, but nothing inside seems loose or broken. When I push the on button, nothing happens, I checked and the switch itself works and electricity gets to it. Do you think it would be the power supply?
  • pendidol Aug 06, 2008
    doesn't turn on
    President:
  • 3,130 Answers
What do you mean "knocked" Yes sir it sure does sound like the power supply specificly the stand by supply? Only real way to tell if you know anything about troubleshooting solid state electronics is to get a schematic and start at the beginni9ng of the supply and work your way over to the sweep supplys. On alot of sets the horizontal has to be good for the ,main switching supply to start up but in this case if it dosent click or make any sound I supect the main supply. Good luck
Posted on May 26, 2006
Power button pushed troughand fell it to the case, tv wont turn on power
Sounds like something came loose inside, the button falls in when the circuit board comes loose or breaks. You have to open the unit up and see what is broken or loose...
Nov 23, 2010 | Sanyo DS32224 TV
CAN YOU TELL ME HOW TO CHECK THE NUMBER OF HOURS ON A PROJECTOR LAMP FOR AN LG RU-44SZ51D ?
push the MUTE button on your remote control at the same time as pushing the OKbutton on your tv set . Hold for at least 10 - 15 seconds . You should now see a page on your screen that will tell u total lamp hours
Sep 06, 2010 | LG RU-44SZ51D 44" Rear Projection...
My LG DLP RU-52SZ51D rear projection TV doesnt turn on.
See if Lamp Fan is running it can be defective and if Fan is OK it will be Ballast Board, Call Encompass Parts 1-800-638-3328
Dec 31, 2009 | LG RU-52SZ51D 52" Rear Projection...
I have a lg dlp projection tv that while i was watching it it just popped and shut off. thought it was a bulb so i change that but nothing. what is happening is when i turn the power button on the yellow...
Lets statrt with the obvious, did the lamp that you replaced showed any type of damage(blown, broken) and when you put in the replacement lamp did you also replaced the lamp cover? or at least remembered to activate the door switch? these tvs have a starter board if everything checks out see if you get any type of activation sound whent you turn the power on, kind of a click sound and another thing to look for is the ventilation fan, is it activating when you push the power button?
Sep 05, 2009 | LG RU-44SZ63D Television
Half my screen works
I had this, and it was just a small connection that was loose.
Dec 22, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Lg plasma tv lg rt42px10
If your screen has cracks running inside the display then you will need a replacement screen. The Plasma screen is the most expensive part and would cost almost the price a new TV as there would also be a labour cost to add on.
Aug 03, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
Tv wont turn on
I had the same problem and took it apart. Before the repair there was no "click" when I pushed the button, a clue to the problem. The on-off button on the front pushes a weakly made angle piece of plastic inside which had broken. The plastic piece in turn is supposed to push an internal switch which is offset to one side.
I used epoxy (Araldite) to repair the broken plastic angle piece, but it still looks weak to me so I switch the tv off at the wall and leave the on-off button alone (though it does work now).
Opening the case requires some knowledge and care, and can be dangerous. It may void the warranty so be careful or give it to a qualified repair person.
Hope this helps!
Dec 12, 2007 | Televison & Video
Won't Power On
as you have seen inside that no power & no light. problem seems to be in power supply. 1 check fuse. 2 check switching ckt. 3 check for loose contact or print break. 4 now if you get power on & still tv is not ok then check for hor. output transistor in hor. output stage. if you are not tech person please do not try to fix it as high voltage is there inside.
Sep 23, 2007 | LG 30FZ4D TV
LG RU-27FB30C TV Logo
324 people viewed this question
Steve Allison
Steve Allison
