Question about HP Photosmart C7180 All-In-One InkJet Printer
Printer - Ink System Failure
I get an error code Oxc18a0201 (Ink system failure) on my HP Photo Smart C7180 printer. Can you help me?
Thanks!
  • rjjgraphics Oct 05, 2008
    I also have an ink system failure and am unable to copy, fax, print, etc...
    What do I do now?
  • leticiat Dec 21, 2008
    I also have an ink system failure error code Oxc18a0201
  • 207 Answers
I had a similar problem of a senseless printer error code with similar useless help from HP for one of my client's HP Photosmart 7510. I also could not find any other relevant help online. But, while searching, I did notice a suggestion to clean the contacts. When I removed the ink cartridge carrier, I noticed a large build-up of ink around the nozzles. Cleaning out the carrier did the trick for me. It couldn't hurt to give it a try.
Follow the steps below if you need them. And, please click "Yes" below if this has helped you at all.
Remove the carrier: Open the printer to access the ink cartridges. Slide out the ink cartridge carrier if it is parked. Remove all of the cartridges. Then flip the lever to the right of the carrier. Grasp the carrier using your thumb on one side and index/middle finger on the right, both near the top, and pull straight upward. Careful, yours may be more full of ink than my client's was.
Clean the carrier: Wash the carrier in a sink with warm/hot water at various angles until all noticeable ink is cleared away. Briefly wash water directly into the carrier's induction screens which contact the sponges of the ink cartridges. This may help a little to flush any ink from the nozzles which might have dried in them while the printer was inoperable.
Remove most of the water: Shake the carrier downward (only while upright) and tip the carrier forward and side ways. But, be careful since some ink will still be contained in the carrier's ink channels. Pay close attention to the induction screens. If you tip it too far or shake while inverted, ink may splash out through the screens or drain back onto the carrier. If this does occur, repeat the cleaning procedure.
Note: Do not attempt to drain all of the ink from the channels, whether through the induction screens or through the nozzles on the underside of the carrier.
Dry the carrier contacts: Lightly wipe the tiny metallic white squares on the backside of the carrier with a dry paper towel. Spot dry the surrounding area, including the nozzle arrays on the underside of the carrier - dab, don't wipe. You should get ink spots on the towel from the nozzles. This is to be expected and is a sign that the nozzles are not clogged (at least not completely).
Inspect the carrier transport: Examine the area with the metal prongs that were exposed when the carrier was removed. Dab dry any areas with ink if you find any, especially near the metal prongs. If you discover any ink on the prongs, use a wet, but drip-dried cloth or towel to continuously dab the prongs until they are clean. Then dab with a dry cloth or towel. Re-inspect and ensure any lint or other debris is removed from the prongs.
Reassemble and test: Return the carrier to the transport, flip the locking lever to the downward position, return the ink cartridges, and then test your printer.
I hope this helped and that all goes well. Please click "Yes" if this has helped you at all.
Posted on Mar 30, 2014
  • 679 Answers
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Feb 03, 2009
I recieve Ink System failure error message with error code 0xc18a0206 on my HP PHOTOSMART C7180 ALL-IN-ONE PRINTER.
The error that you are having is a hardware issue, it means your printer has an Ink System Failure. Believe me, there's no use going through troubleshooting for this one. Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts and an extra year of warranty for $1.00.
Feb 03, 2011 | HP Photosmart C7180 All-In-One InkJet...
Ink System Failure Error Oxc18a0201
Read this, it should help you:
http://www.fixyourownprinter.com/forums/printer/50063
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
Hi
Thanks for using FixYa. To resolvethe issue of display of error Oxc19a0036 you’ll need to reset the printer andto reset it please follow the step-by-step procedure on the link---
Howto Reset Photo Smart Printers
Please do rate the solution andrevert for further assistance.
Thanks
Rylee
Jan 21, 2010 | HP Photosmart D7560 InkJet Printer
My c7180 keeps coming up error OXC18a0201 Ink system has failed, it says to shut off, and I have and it comes right back
Problem occurs for me when i run too long with an empty cartridge solution press * and # at the same time press 1 2 3 and "support R0632M" should display press > and "information menu" should display press > and "configuration menu" should display pres OK and "hardware failure status" should display press OK "failure status:clear" Press OK to clear press cancel press cancel press cancel turn printer off unplug power cord for two minutes plug back in power on use your printer
Jun 28, 2009 | HP Photosmart C7180 All-In-One InkJet...
Ink system failure Error: 0x05d1281
Ink system failures is a very serious problem on HP printer systems. Ifyou have this problem you should be ready to replace your printer.However there are still troubleshooting steps that you can do to try toresolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 14, 2008 | HP Photosmart C7180 All-In-One InkJet...
Ink system failure
Wait two minutes.
Sep 14, 2008 | HP Photosmart C6100 All-In-One Printer
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Hp c7180 ink failure
Here is the exact sequence for the C7180. It worked great for me:
This is easily fixed with the following key sequences. You do NOT have to open the printer and unplug a circuit board.
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
NOTE: I did this and the fist time the error came back. Do the sequence again (as I did) and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
Jun 12, 2008 | HP Photosmart C7180 All-In-One InkJet...
0xc19ac3ff error code
Same deal. Message "ink system failure". I restarted the printer, it works fine
Mar 07, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7180 All-In-One InkJet Printer Logo
493 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
