Question about Toshiba SD-230 DVD Player
DVD plays with sound but no picture
I have a DVD Toshiba SD 240E. It plays discs with sound but no picture. How do I fix this?
    President:
  • 3,130 Answers
Have you checked the unit on another input or another set to eleminate the video input? also try the video cable. If theres sound and no video and you tryed then the video output amp in the player has a problem and the only way to fix this would be with a schematic and a scope to trace out the video signal. Good luck
Posted on May 25, 2006
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
TOSHIBA SD-1600 WILL NOT PLAY DVD+R RECORDIBLE DISC.
wer i can find the model of the toshiba dynabook video driver?
Dec 22, 2008 | Toshiba SD-1600
Toshiba DVD Video Player Model No, SD-370EKB
Check the line carrying your video signal. See if it is damaged or not hooked up properly. It is usually the yellow wire, although it can be any number of colors.
Jul 23, 2008 | Toshiba Televison & Video
Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Not playing DVD's
have you asked for profesinl help or take it apart to fix the problem
Dec 18, 2007 | Toshiba SD-P1400 Portable DVD Player
Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Jun 25, 2007 | Philips DVP642 DVD Player
Open Questions:
See all Toshiba SD-230 DVD Player Questions
Toshiba SD-230 DVD Player Logo
174 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
