Question about Nintendo DS Lite Console
The power light cover came off and the top screen is not completely showing.
  • 33 Answers
The hinge is broken - a common fault with the DS.
Options:
1. Fix it Yourself (see YouTube.com for helpful videos) - need a new case & possibly a new LCD top screen - these are small inside and ensure you are confident before starting. Will cost about £15 to £25 in parts.
2. Send it to Nintendo - repair charge of upto £55 (in the UK).
3. Sell it on eBay (as faulty) and buy a new one (with 12 month warranty, this will cost you about £40-50).
4. Get it mended privately - will cost you £30-£60.
Posted on Sep 19, 2008
Taking cover off nintendo ds lite
Are you talking about the back cover or front cover?
Either way, before starting you are going to need two things: A tri-wing screwdriver and a Philips screwdriver.
To remove the BOTTOM COVER, you must take off the stickers covering the screws and remove the screws. 001e10e1-317e-4bb5-97cd-230a82f77aaf.jpg
Then, carefully pry the back off, revealing the motherboard inside.
To remove the TOP COVER, you must take off the stickers covering the four screws in the corners of the INSIDE top screen. Unscrew them and gently push the inside top screen down until its about half a centimeter apart from it's backside. Then pull the backside off and you have it open.
If you wanted to open the DS completely, like have it in half, you should first open the BOTTOM COVER and remove the motherboard after disconnecting it from everything attached to it. Then follow the steps given for removing the TOP COVER and slide the ribbon and cables sticking through from the TOP to the BOTTOM back to the TOP so that they are not sticking through and won't be damaged when you take the DS apart. Then unscrew the power light and voila! The DS should be separated.
May 31, 2014 | Nintendo DS Lite
Philips 40" LCD No video
probably,did you have a look for bad caps?
make sure all the cables are housed correctly ect
Mar 16, 2013 | Philips 40PFL5505DF7 40 in LCD TV
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
My acer is not coming on ,there is power going into my lap top but the screen is completly blank?
Bring your laptop under sunlight. If you look very closely and can see your screen then your backlight went out. Otherwise there might be a loose/broken connection to your lcd.
Jul 03, 2012 | Acer Aspire 5535-5050 Notebook
Picture on tv screen showing only half picture bottom of screen blackpicture only showing about 6inches at top of screen
good day sir
your problem is on the back light of your TV..the upper side is not function because the back-light lamp is busted and the lower part is good so you have to do is replace the upper side..
I teach you to do that
first,remove the cover of your TV by removing all screw at the back side then you remove the plastic cover of unit
secondly,when you see the inverter board,power supply and main board remove it
thirdly,remove the steel cover of the LCD screen to see the back light bulb or lamp
and finally, after you see the lamp replace it with a new one only the top side lamp is busted so that's the only lamp you replace
thank you
Apr 03, 2011 | Televison & Video
My lab top when restarted it beats 3 times, screen blank
Nothing to worry, Open your laptop from the back side.Remove the RAM  and reinsert it.
Your system will work fine.
Rate this solution.
Dec 27, 2009 | HP Pavilion dv9700t Notebook PC
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
Long beep and a blue screen, blank screen no menus
Operator panel display
Service tip: The printer has detected a problem with the system card, the operator panel assembly cable (part of
the top cover access assembly), or the operator panel assembly if POST does not complete. The printer emits 5
beeps, and sticks in a continuous pattern until the printer is turned off.
Check for ground between JOPP1 pin 4 and ground. If correct,
replace the operator panel assembly. Go to “Operator panel
assembly removal” on page 4-22. If incorrect, check the operator
panel assembly cable. If the cable is damaged, replace the top cover
access assembly. Go to “Top access cover assembly removal” on
page 4-23. If the cable is okay, replace the system card.
Jan 20, 2009 | Lexmark C522n Laser Printer
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
Nintendo DS Lite Console Logo
47 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
