Question about GE Nautilus 24" Built-in Dishwasher
Runs even though latch is not closed
Even unlatched the dishwasher will run. Can't open it to add a forgotten dish, or to add some vinegar without getting sprayed. Also it is leaving a nasty white residue. I believe it is soap not from hard water.
    President:
  • 1,462 Answers
Latch is in closed position. to correct, put thin screwdrivers thro the slot at the top and lever the latch up. if the door hook (mounted on the cabinet is metal, bend it down slightly
Posted on Sep 14, 2008
My dishwasher runs but door is in locked position. it will now run with door open and the door wont close/lock
It sounds like your door latch got tripped into the closed position (even though your door is open). You MIGHT be able to use a screwdriver or some tool to be able to pull the latch lever back out to the open position, but it might also be necessary to take the door apart to get to the latch to be able to reset it. The real problem is that if it happened before, it will probably happen again. So the real solution is to replace the latch assembly.
May 31, 2015 | Jenn-Air 24 in. JDB2100AW Dishwasher
How do I clean dishwasher its starting to leave whiet spots on dishes
Good Afternoon Friend,
I understand you want to know how to clean your Frigidaire dishwasher, model# PLD2560LCC, as it is starting to leave white spots on your dishes. Please follow these simple instructions:
1. Load your clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
2. Do not add detergent.
3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad.
4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes). The SENSING light will be off.
5. Unlatch and open the door and pour 2 cups of white vinegar into the bottom of your dishwasher.
6. Close and latch the door and allow cycle to finish.
Note: If these conditions persist, a home water softener should be considered.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire 24 in. PLD2560LCC Energy...
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Jan 08, 2014 | Frigidaire Professional Series 24 in....
Bosch shv46c03uc
I would check the latch on the door..When you shut the door it makes contact telling the washer it's closed
Aug 17, 2013 | Dishwashers
Frigidaire d. w. grit and white film on glasses
Good Morning Friend,
I see that you are receiving grit and a white film on your glasses, in your Frigidaire dishwasher, model# FDB1050REC. Here are some common solutions that you can begin with.
-Check your water hardness. Hard water can cause lime deposit buildup on the interior of the dishwasher. Dishes and glasses may also get spots and film for a number of reasons. To remove buildup, spots and film, clean using the following instructions:
1. Load clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
5. Unlatch and open the door, and pour 2 cups of white vinegar into the bottom of dishwasher.
6. Close and latch the door and allow the cycle to finish.
For extremely hard water, it may be necessary to install a water softener.
-Your water temperature may be low. Avoid extremely low or high temperatures.
-Avoid overloading and improper loading.
-Make sure you are using fresh detergent. Old detergent is ineffective.
-Make sure your rinse aid dispenser is filled.
-Check to see that the proper amount of detergent is being used for cycle selected.
-Your home water pressure may be too low-it should be 20 to 120 pounds per square inch (psi).
If none of these suggestions helps, I would suggest contacting either the manufacturer or a local authorized technician. Hope this helps.
-Best Regards-
WP
Feb 16, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Dishes come out of dishwasher with a sticky film, and after the dishes cool off the film hardens and is almost impossible to remove.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Apr 22, 2011 | GE Profile PDW1860NSS Builtin Dishwasher
Inside of washer has a chaulky film. even my dishes and glasses
Hi
Daniel
Feb 13, 2011 | KitchenAid Dishwashers
My dishes are coming out with a kind of film on them -- especially the silverware and glasses. Now the plates even look like they have a film on them. The dishes are often still dirty.
Hi
Daniel
Feb 13, 2011 | Bosch Dishwashers
White coating on glasses, silverware and door of dishwasher that is very difficult to remove (even with a stainless steel scrubber) Is there a product I should be running through the cycle (without...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 22, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
GE Nautilus 24" Built-in Dishwasher Logo
117 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
