This problem seems to have appeared out of nowhere. I haven't changed anything in my setup. My Paradigm Servo subwoofer has decided to make a thump sound every time I switch (with or without remote) to a different input source on my Yamaha RX V2200 receiver. This also happens on DVD menus and during playback when the DVD does a layer change. If I turn on the <Mute>, there is no thumping if I change the input source on the receiver itself. However, if I use the remote control, it thumps. I think this happens because the remote automatically turns off the <Mute> when a different source is selected, therefore sending the noise to the subwoofer. The thump also occurs when I turn on/off the <Mute>. Not so much when I turn it off but I can still hear a soft thump. Only the subwoofer thumps. There is no thump coming from the other speakers.
I've checked all the connections and re-tighten them but the problem persists. I read on an Internet forum that I could fix the problem by forcing the input settings on the receiver to "Digital" or "Analog" for each input source. Apparently, if the receiver is set to "Auto" detect the source, it causes the thumping / popping on the subwoofer / speakers. I checked the settings on my receiver but the only choices the Yamaha has are "Auto", "DTS", and "Analog". In any case, I tried all different combinations but no change.
There have also been some references on some forums that it could be a "ground loop" problem between the receiver and the subwoofer. Some resolved this problem by using an AC adapter that allows a 3 prong grounded plug to connect to a 2 prong outlet or by using a ground loop isolator. I don't think this would help my situation because my subwoofer power cable already has two prongs and there is no a buzzing / humming noise emitted from the subwoofer (assuming that no buzzing / humming means no grounding problem).
One post I read had an identical problem and his solution turned out to be a new cable. To checkout this possibility, I removed ALL the connections from the receiver and then connected the subwoofer with a new cable. In fact, I also moved the subwoofer across the room to reduce the chances of it being on the same power circuit as the receiver. I still got the switching problem.
I suspect this means that the receiver is indeed the culprit. Whether it is actually a transistor or something else on the "muting circuit", I don't know.
One last item I checked was the switch setting on the back of the subwoofer. It was set to "Auto on/off", so I changed it to "Always on". It's still thumped.
Please let me know what you think and thank you for your help. I really need to get this booger fixed.
-   Hi
Same issues, but happens if I use remote or change input/output on the amp itself.
All was ok till a week ago, now theres a great THUD everytime I switch.
Turning the amp off to and then switching is a no go, since the amp needs to be on if I wanna switch dvd to sky or similar!
Help!!!!-   thfcmark
When many active subwoofers are switched on or off, a loud thump often accompanies the events. Not only is this disconcerting to hear, but these switching transients are potentially hazardous to the speaker's health. There are commercially available units which you can fit to stop potential turn-on damage dead in its tracks with special anti-thump circuitry.
Most decent amps have a power on (mains) anti thump system but it's usually a relay which delays the speakers being activated when mains power is applied. The transient spikes found during actual use by switching sources is only handled by top end equipment and it's built into the unit.
Use of a .01μF or .022μF 250VAC metallised polypropylene capacitor across the switch contacts can stop thump but a lot of knowledge of your amp would be neededto fit them.
The cheapest way would be to switch off the amp prior to switching sources and then switching the amp back on.
The most expensive way would be to make the sub woofer Active which would involve a seperate amp with anti thump built in. It would then have to be fed via the sub woofer line out.
Ive seen this problem in alot of audio setups in vehicles but most peeps dont know this is not a good thing and will cause damage to your woofers or amp. 99% of the time it turns out to be as you said that bad boy muting circuit. alot of these curcuits do use separate transitors or diodes as mute switches but most of them are directly from the Microproccessor. Only way to trouble shoot this is with a schematic and a good car stereo tech. Good luck
I purchased a Yamaha RV-V2200 receiver in 2001 and it's worked well for almost 8 years, but now it's...
(More)
I purchased a Yamaha RV-V2200 receiver in 2001 and it's worked well for almost 8 years, but now it's losing settings. In Florida we receive a lot of lightning and associated power problems, so I use a wall switch to disconnect power from my AV equipment when I'm not using it. The manual states that settings may be lost if disconnected for more than one week. Now it loses settings in less than 24 hours. Does anyone know if this memory is powered from an easily replaceable battery or if it would require soldering in a new battery or capacitor?
I bought this av receiver in 2001. It is hooked up to a Yamaha NS-P420 speaker system, and also has...
(More)
I bought this av receiver in 2001. It is hooked up to a Yamaha NS-P420 speaker system, and also has a center channel speaker. Since day 1, I have only run this system in the 6 channel surround sound mode. I've only run the subwoofer on various occasions over the last 7 years. Maybe 10 times at the most. Over the past few weeks the receiver was making crackling and popping sounds and losing sound. My husband took the cover off and blew out the dirt with a compressor. That worked for like a day. Now, I will be watching tv and all of a sudden the sound will go out. I have figured out that if I change the presets on the amp to say Rock concert, or church, or any of the other 8 or so presets, the sound will work only on the left and right front channels. When I put the preset to either entertainment game or entertainment 6 channel, there is no sound, but there is sound on entertainment disco in the front right and left speakers like all the other presets. If I leave the receiver in the 6 channel surround while the sound is out, I will get an extremely loud swooshing sound (which will probably at some point fry my right and left front speakers and give me a heart attack) and then the sound will come back on all 6 channels. This happens no matter which piece of equipment i'm using. The receiver is hooked up to the tv, a dvr, dvd player, and 2 vcr's. Always has been. If you have any thoughts, I would appreciate it. Thank you.
When I turn on the receiver, I hear a humming/feedback noise that comes from the Center speaker,...
(More)
When I turn on the receiver, I hear a humming/feedback noise that comes from the Center speaker, rear right speaker and the subwoofer.
Sometimes this humming noise comes from the subwoofer when the receiver is turned off.
At higher volumes this noise is drowned out.
When the mute is on the humming noise disappears.
I have re-wired and re-connected the speakers, all to no avail.
The volume control knob controls the volume irratically. The display shows it going up and down but...
(More)
The volume control knob controls the volume irratically. The display shows it going up and down but 15.2, 15.5,15,7,15,2 when turned. using the remote works perfectly. Tried to blow out the pot. to no avail. Is it the pot. or the matrix of the circuit?
