Question about Mitsubishi WS-65511 65" Rear Projection Television
Double picture on Mitubishi WS-65511, Year 2002 TV
Everything on the TV works fine except the picture is distorted. It is like a double image with a red ghost outline. Even the menu display is affected. Any ideas how to repair this.
  • 3 more comments
  • y2kev Nov 11, 2008
    I have a WS55511 and the Green is out of alignment and concave (pulled in to the center at the top and bottom) Is it worth fixing?
    I'm good with replacing electronic components if I know what Part I need.
  • Anonymous Nov 28, 2008
    I have the same problem but it is the blue instead of green on my TV.
  • ramrod6531 Dec 22, 2008
    i have the same problem, except mine is just a blue shadow and only from white pictures on the screen. It's not that bad, but getting annoying. it seems like there should be some type of manual adjustment. does anyone know if there is?
  • Anonymous Jan 14, 2009
    double image, lots of red
  • MrsQ Mar 15, 2009
    I have the same problem, the words are double and the color at the top and bottom are distorted. I bought part number STK393110 and dont know where it goes. Does anyone have the schematics for this model number WS65511?
  • 10,594 Answers
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Posted on Sep 13, 2008
TV keeps turning off & resetting every 15 minutes & up to 10 hours. When it is running the picture is PERFECT & BEAUTIFUL ! Can anyone tell me where to start after the DM Elec. caps ?
WHY DOES IT KEEP TURNING OFF - Fixya
www.asksbook.com/support/t24227796-keep_turning_off
Apr 24, 2014 - These, like most newer tvs have self-checks that shut the tv off if the fault could .... Mitsubishi WS-65511 65" Rear Projection Television Logo ...
[PDF]871D3547B10 (V21 OG) 52 through end.indd - Mitsubishi
https://www.mitsubishi-tv.com/asset/file/owners_guide/WS-55511.pdf
Projection Television Models ... WS-65511 WS-65611 WS-65711 WS-65712 ... which can be determined by turning the equipment off and on, the user is encouraged ...same stationary images on the screen for more than 15% of your total TV
Jan 19, 2016 | Mitsubishi WS-65511 65" Rear Projection...
It is having double image. The second image is to the right with red color.
Sounds like a convergence problem. See if you can adjust the customer convergence controls (in the menu).
If you can not adjust one or both the colors than your convergence amp is toast!
Mar 06, 2011 | Mitsubishi WS-65511 65" Rear Projection...
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Out of focus
You have a convergence problem, probably the convergence electronics are going out or the TV has been violently moved and needs a mechanical alighnment. Small adjustments can be made from the menu.
May 17, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Double images
you will need to have the tv re converged to make the picture right call a repairman
Feb 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Mitsubish tv ws 65511 double image (red), rest is working perfect
You will need one STK393-110 Convergence IC and two 5Amp Pico fuses. You can get the parts with free installation instructions at the following link.
http://servicemanuals.vstore.ca/
Jan 14, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Picture and color distortion
I am having the same problem hopefully some one answers us.
It's a Blue Convergence issue but how to fix it I am still waiting.
Apr 13, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
318 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
