Question about Dryers
I have a siemans wtxd5522uc 27" ultrasense gas dryer that the ignitor won't fire. What is the supply voltage to the ignitor? Is it usually the ignitor that goes or some sensor? Every thing else working from a control standpoint so the main control board seams to be working. Thanks, bob
    Genius:
  • 1,239 Answers
Hi sir it ignites at the voltage bet 230v-250v.there will be a sensor problem where it cannot try to ignite try to clean ignitor area.. In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Gas dryers use an electric ignition device rather than a pilot light to light the gas heater: An element becomes hot and glows like the filament in a lightbulb. Electric ignition systems are always sealed; you can't adjust or repair them. If an electric ignition device fails, call a professional service person for replacement.
©2006 Publications International, Ltd.
In a gas dryer, heat is provided by a gas heater, controlled by an air shutter.
Electric dryers have self-contained electric heating elements.
Posted on Sep 13, 2008
    Genius:
  • 3,422 Answers
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
I need operating manual for my Siemens ultrasense Plus gas dryer. Model Number WTXD8500UC/01
https://www.manualslib.com/products/Siemens-Ultrasense-Wtxd5300us-2952500.html
Jun 03, 2017 | Siemens Computers & Internet
The Hi and Lo gas valve coils do they work in tandem ? Does the Lo stays on all the time ? Ruy ...
Their is 2 coil hosing but one of them has 3 wires and 2 coils inside it. The ignitor does 2 jobs, it lights the fire and acts as a thermocouple through the holding coil. If the flame does not ignite after the sensor detects the heat from it and shuts down then once the ignitor cools down the gas valve is shut down even if power is going to the gas valve. When the temp drops below 105f in the drum the control closes contacts inside allowing power to be supplied to the gas assembly. The ignitor and flame sensor along with the booster holding and secondary coils are all energized at once but the solenoids won't open the valve because the ignitor is hogging the power. The power supplied to it runs through the flame sensor. When the temp inside the sensor reaches a point the bi-metal inside tripped the power to the ignitor and the power gets diverted over to the secondary coil. Thr flame stays on till the temp inside the drum reaches 160f at which time the control thermostat opens circuit to the gas assembly and power is shut down. The drum continues to tumble and when the temp drops once agin below 105 the process is repeated and another blast of heat is shot into the dryer. So what goes wrong? Faulty flame sensor sticking/open, cracked ignitor, old coils that work intermittently or not at all when hot but work again when cooled.themobilian_2866.jpgthemobilian_2865.jpg themobilian_2868.jpgMore here.
Aug 21, 2011 | Whirlpool GGW9878P Gas Dryer
Dryer running ,but no heat.Roper gas dryer,mod - RGD440VQ0, Sn - MW/2901047
Most common reasons for a gas dryer to fail: 1. No electric, 2. no gas supply, 3. failed ignitor, 4. failed flame sensor. If 1 & 2 are ruled out, then we go from there. An ignitor/glow ignitor is what gets hot and allows the gas to be ignited. Most dryers will not let the igntior come on if the flame sensor is down. Replacing an ignitor is very easy. Usually 1 screw and a molex (special type of plastic electrical connection). Molex connection will usually pull apart very easily. This repair should cost less than about $30 if you buy it online. There are step by step instructions for this repair on this website if you search for "gas dryer no heat troubleshooting." Making this repair will require access to the internal workings of your dryer. Make sure the dryer is unpluged from the wall before you access it or the control panel.
Feb 05, 2011 | Roper Dryers
Dryer turns on, spins, blows air, no flame/heat. Checked voltage at the ignitor and found it to be "0". what should I check next.
your ignitor is bad its not pulling enough amps to open the valve. take it off pick up a new one at your local supply house that sells appliance parts.
Dec 17, 2010 | Kenmore 73952 Gas Dryer
Roper RGX5634KQ2 Dryer will fire initially, and heat up. It will stay fired up for around 1-2 minutes, and go out. After another couple minutes, the igniter fires, but there is no flame. This continues...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Could be a coil...but I have learned that it usually is the ignitor...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Roper RGX4634KQ Gas Dryer
Dryer is spinning but the burner wont fire up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 07, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer will not heat. Looks like the lighter glows but does not always fire the gas to heat the dryer
An ignitor can still be bad even if it comes on and glows...
heatman101
Jun 14, 2010 | Dryers
Not heating during drying. everything else works
There are 3 things to turns on the heat. The ignitor, the thermal sensor, The gas valve. The ignitor has to glow first when you start. if it doesn't then it has a problem right there. After the ignitor comes on, and the thermal sensor has to produce some voltage so the gas valve can open to fire a flame then the heat will start. If the thermal sensor is bad, valve can't open then the ignitor will shut down, hence there is no heat.Taking the back panel off and try look to see the ignitor when you start so you can diagnose it correctly. Good luck
Apr 22, 2010 | LG DLG5932W Gas Dryer
Sometimes does not ignite.
you have a bad timer rotory dial that will not pick up the signal for the ignitor to fire
Jan 30, 2010 | Kenmore 73952 Gas Dryer
Gas dryer
hi
Sep 14, 2008 | Dryers
Dryers Logo
112 people viewed this question
Top Dryers Experts
