Question about Akai Televison & Video
I have an AKAI PDP4247-FA and the screen started flickering off and on and then went blank. This occurred on and off for about 6 months then went totally blank.
5 Suggested Answers
  • 15 Answers
SOURCE: akai tv went blank
if you purchase a nine pin RS-232 connector cable with a male end and a female end you can hook your TV up to your computer. You can actually run a diagnostics program, and tests on your TV! The cable is like 5-10 dollars depending on length and is availible at most local computer stores. Just hook the cable up to the data port beside your PC input on the back of the TV. Good luck! (just saved you 100 tv repairman bill) and also check the bulb to make sure it is still good! The service guide to this TV has ALL the answers to your TV at www.nodevice.com , search in service manual and it has all the codes to reset your tv and counters for the bulb for $10..(for the manual that is you just download it to your computer then print it off)
Posted on Jul 01, 2009
  • 8457 Answers
SOURCE: I've had my TV for about 6 month and one day it
Call for warrenty service,ur tv backlight video is dead,or dying.Unplug,replug the tv an hour might have video back,but must replaced it sooner or later.
Posted on Dec 22, 2009
  • 11800 Answers
SOURCE: PDP4247 Akai. Cablevision powered.
The tv goes into standby. 2 possible causes:
1 - the power source has aged and the voltage it delivers to the other components of the tv (in particular the control processor) is no longer stable: if the voltage drops below a certain level the processor just shuts down, putting the tv in standby. The power source will have to be checked and the aged components replaced (it's most likely the capacitors).
2 - there is a power fluctuation on the mains power line - the others don't shut down because they have a lower power necessity and they are able to coup with that.. The only way to test and fix that is to run the tv thru a UPS.
Posted on Oct 25, 2010
jomabug76
  • 1148 Answers
SOURCE: jvc hd-61g787 Screen takes between
check jvc website support
Posted on Nov 03, 2010
I have a 6 Year old AKAI 26" LCT2660V. While watching a movie last night, The screen went black in the middle of it and won't come back on. When I first bought this it started doing the same thing...
Sounds like power regulator board fault. If you wish to get some details; visit the site linked here. Pull up older posts.
You should be something in electronics to gasp the essence of the posts there.
Oct 20, 2017 | Akai LCT2060 Television
I have a pdp4247 plasma i have a 3" white line down the center /w
there are no bulbs in plasma tv's. the problem is most likely a bad video board (what converts the digital input to usable picture for the screen) it will need to be replaced, probably better to get a new tv.
May 21, 2010 | Akai PDP4225M 42 in. Plasma Television
I've had my TV for about 6 month and one day it just went blank,the red light flickers on and off,but no power.
Dec 22, 2009 | Akai LCT2715 27 in. LCD Television
No picture akai 42 inch plasma
I have not solved problem, although I paid you to solve it many months ago. The information I paid for was not the problem although the answer I was given was someone telling me it was for sure the problem.
Oct 03, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No signal on monitor
Do you have another monitor to test your computer? Looks like a surge went into the computer display and damaged the video card.
Sep 07, 2009 | XFX GeForce FX 5500 Graphic Card
My 14 month old, 32 inch Samsung flat screen tv ''flickers'' The cable went 'out' 3 or more times and when returning the TV started flickering. We have unplugged & plugged it back in several times, but...
Check if this occurs regardless what the source of the signal, whether it is DVD or cable or a playstation. You can also check if the Menu flickers as well. If the menu does not flicker along with the picture it could be a problem with the source, probably your with the cable box or the port where it goes to on your tv
Aug 05, 2009 | Televison & Video
While watching TV screen went blank. Voice stayed on
the photon charges at the back of the tv might be damaged, try to take it in to be repaired if not i suggest u buy a new one, please, please, please do not take it apart to fix it urself, alot of bad burns have happened to people who try to fix plasma tv's.
Apr 12, 2009 | Akai 50 in. Plasma TV
Akai PDP4247-L PLASMA main power supply module
Yes there two power supply unit one for the main power supply is used for the plasma screen which helps to display the image on the tv screen ,So you need to replace the main power board did they say they have it??
Sep 08, 2008 | Televison & Video
Authorized Repair Centers for Akai Flat Panel TV
My 42 inch Akai is about 6 months old,, and is showing green where black should be..
BUt there is help for you all.. Call Verizon, sign up for their "Expert Care" program. it's $10.00 a month, and active after the third month.
with a $75.00 deductable. THey will fix or Replace (give you choice of three alternate models/brands).
Free services under this plan are adjustments, and One FREE remote per year!.
i recomend you sign up for this program, and after 90 days. call for service. They more than likely will replace your TV's.
This is what they did with mine..
ALSO.
it doesn't matter how old your TV is, the plan is applicable to all TV's in your household. So one plan, one monthly payment of $10.00, covers all the TV's you own!!
Dec 09, 2007 | Televison & Video
It's simply gone blank... or into a coma perhaps.
But that is the only way -its replacement time Nothing for you to fix
Jun 18, 2007 | Samsung SyncMaster 971P LCD Monitor
Televison & Video Logo
44 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
