Question about Dishwashers
Dishwasher drain issue
My Hotpoint Quietpower dishwasher does not seem to drain after a wash cycle, however it will drain after a rinse cycle. Any ideas?
    Sergeant:
  • 409 Answers
Check to see if there is anything stuck in the drain pump. it not, replace the drain pump, as it's malfunctioning.
Posted on Sep 13, 2008
FILLS, DOES NOT WASH, THEN DRIES
GE GLDT690TBB Fully Integrated Dishwasher with 7 Wash Cycles Including SaniWash and SpeedWash, Nylon Racks, Stainless Steel Interior, Countdown Display and QuietPower 56 Quiet PackaBlack- Recent Questions, Troubleshooting & Support
Oct 07, 2015 | GE GLDT690TWW Fully Integrated Dishwasher...
Why doesn't the water draincompletely after the dishwasher cycles?
It drains as part of a cycle as does the wash and rinse cycles.
Most will drain through a hose into a garbage disposal connection. First I would check the grate inside the bottom of the dishwasher for debris them in the disposal. That issue will slow down the water from draining and timing out the cycle leaving water inside. The water when draining from the dishwasher into the disposal should be seen from above flowing out rather fast if correct. If not? The hose from dishwasher to disposal also might be clogged. This is fairly typical issue for dishwashers, when the dishes are not Cleaned beforehand.
Jan 02, 2015 | Dishwashers
Hotpoint LFT 228 A dishwasher intermittent draining problems. Sometimes so much water that it leaks, will drain sometimes but then water appears in the filter again, items in dishwasher sometimes come out...
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
Sep 25, 2011 | Hotpoint-Ariston LFT 228A 23 in Builtin...
AFTER THE WASH AND RINSE CYCLE IT DOES NOT SEEM TO
Bad pump or a kink in the drainline between the appliance and the garbage disposal. And since we're speaking of garbage disposals check to see if scum hasn't built up at the drain orfice on the dishwasher.
Good Luck
Dave
Aug 19, 2009 | Dishwashers
Frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Mar 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Drainage problem
cycle switch on the front is most likely bad
Jan 09, 2008 | Hotpoint 24 in. HDA3740G Built-in...
Control Module?
Sounds like a dishwasher.. You didn't say or give a model number. Dishwasher that do not drain are usually caused by clogged up drain hoses, often right where it connects to the drain or disposer under the sink. In some cases, there's a separate drain pump that is defective, in other cases, there's a drain solenoid, and in others a drain impeller that's broken or clogged. All depends on the model.
Oct 24, 2017 | GE 24 in. PDW9880LSS Stainless Steel...
Dishwashers Logo
173 people viewed this question
Top Dishwashers Experts
