Question about Pioneer DEH-P4100
I cant get my subwoofer system to work
I have all the wires needed hooked up to my deck and i am getting no sound out of my subwoofers. i was wondering if there is some way to turn the subs on or off through the deck. I dont have my remote anymore.
  • shorttty13 Dec 23, 2008
    i have the same problem but i cant remmeber how to turn the remote on to get the amp to turn on. can u help me.
Do you use a amplifier to power the subs? If so, the amp needs a signal to turn on. This is supplied by the blue/white wire labeled 'system remote' in pioneer radio's.
Search for the next term on this site for more information about this wire:
Remote turn-on in car amplifiers is obligatory?
Posted on Nov 20, 2008
Subwoofer not working.
Most likely, the "remote" wire to the subwoofer amplifier has come off or is not making good connection.
May 15, 2015 | JVC TH-BA1 Soundbar System with Wireless...
Why cant i get sound from my subwoofer? All wires and fuses r good but still no dound??
Check all of your connections and your receiver's surround
modes. Also, you may want to consult your troubleshooting
guide in your receiver's and subwoofers owner's manual.
Other than that, even though the receiver has been tested,
there might be a problem with the subwoofer output of the
receiver. You might also try different interconnects between
the sub and receiver -that could be the problem.
Has it worked in the past with this receiver and subwoofers?
Try it with just one subwoofer and see what happens. If you
still get no sound, then it might just be in your best interest
to get a new, higher quality receiver. That's what I did when
I ran out of help to get the subwoofer problem solved, and it
worked after replacing the receiver
Sep 20, 2012 | Car Audio & Video
I hooked up a Sony deck and new Kenwood 12' subwoofers and amp that came together in a box set in my 95 Jeep Grand Cherokee and when I play the radio the stock car speakers play but the subwoofers are...
their should be a blue and blue white wire on the Sony radio. cut the blue wire and then connect the car side to the blue white wire and tape off the blue wire that is on the radio side.
the blue wire only turns on when the radio is activated. the blue white wire is activated when the radio is turned on.
please rate my solution.
Jul 02, 2011 | AudioBahn Car Audio & Video
Subwoofer turns on and is hooked up, but no sound.
The signal don't seems to be present to the sub input.
Try change the wire betwen the audio system and the subwoofer.
Spider Guy
Mar 15, 2010 | Onkyo 630-Watt 7.1 Channel Home Theater...
I just picked up a 12" type r in a box with a alpine m 350 how do I know what kind of type R I have without taking it out of the box?? and how do i hook it up to this amp??
Not to insult you in any way but u need to know how to wire into car's electrical system at the battery then to a fuse then to the amp and then output the signal from the deck to the amp.. finally to the subwoofer. you need to hook up 12V constant battery power , then remote from the deck ,ground wire from amp to chasis for power.. then wire to sub.
Sep 10, 2009 | Alpine SWR-1222D 12" Type-R Series...
Subwoofer trouble
does your deck have a sub control on it sub on or sub off are your rca jacks plug in to the right one are your rca cables in good shape speaker wires hooked up properlly amp is set on low pass filter
Jul 06, 2009 | Car Audio & Video
How to hook up a subwoofer to my computer?
i to have that sub and i hook it up to my dell 1501 i use a mini steroe plug it has two input so you can hook up two device get two y cables on one end it will have a plug like your headphone plug on the other end has two male the ones you hook up at the back of your steroe the other cable is a y cable as well this one has two female end and steroe end to hook up to the sub connect both wires to become one male to female one end goes to the computer the other end the sub you cant do it wrong there is only one plug that will fit hope this helps .
Jan 12, 2009 | Jensen JW250 Main / Stereo Speaker
Could a ground stop your woofer from working?
First check the speaker wire from the amp to the sub, see if it's connected right. Second check the rca cables that goes from your amp to the back of the deck. I f both wires are still connected fine try to replace the rca cables. If it still doesn't work the rear out put at the back of your deck, where the rca's are connected are bad. FYI deck is bad.
Nov 29, 2008 | Jl Audio 12W3 Car Subwoofer
No sound coming from subwoofer
sometimes these subwoofers are for builtin amplified if this is the case it will not work
Oct 25, 2007 | Sony STR-DG510 Receiver
No sub when listening to a cd
you're using the wrong remote output wire. You have it hooked to the power ANTenna wire (blue) which turns off when not using the tuner. You need to use the REM OUT wire (blue w/ white stripe).
Oct 14, 2007 | Sony CDX-M630 CD Player
Pioneer DEH-P4100 Logo
228 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
