Question about HP Compaq Business nc8000 Notebook
My nc8000 shuts down after few seconds and starts after power plugged in or battery inserted
My laptop was having problems with display, screen was turning blank randomly and was back on after standby or power off -by blank I mean dimmed desktop could be seen - just backlight was off, system was still responsive so Fn + F3 worked. I diagnosed problem as bad inverter but in the before I did when laptop was powered on and off too many times a different problem appeared, at first rarely, but now always.
After laptop is connected to power supply or battery is inserted it starts up automatically almost instantaniously. Power led is green, hdd and fan are spinning up, dvd clicks as usual, screen remains blank. But after about 2 seconds computer shuts down and cycle repeats after 4 seconds.
I can avoid automatic powering up by removing battery when computer is powered on, when battery is plugged in again it won't start and battery is being charged as orange light indicates.
To diagnose problem I removed all unecessary equipment - hdd, dvd, wifi, tried booting without lcd panel connected to mainboard, without keyboard and for the sake of experimenting tried both inverters - original and replacement.
I suspect it might be a broken power switch on mainboard which is always pressed on or power circuits like internal DC/DC impulse power converter with exhausted capacitor, unable to provide enough power to start GPU for example.
I have tried looking around for an answer and found many similar problems but no reliable solution. Please put me on the right track diagnosing and solving problem as it might be simple enough to fix by using screwdriver and soldering iron with support of nearby electronics shop.
PS. Laptop's guarantee is long gone and sorry for my English.
  • turecki Mar 07, 2009
    Thank you for helping, fixing the inverter part of my problem was already solved but I couldn't find a solution for a power problem described above and bought motherboard for this nc8000. For anybody interested - I have resoldered all pins of square MAX chip near battery connector using soldering iron with tip shaped to be very thin using a file - without success, replaced few fishy capacitors. Nothing helped, probably this MAX chip is dead and after motherboard exchange all laptop peripherials appear to be ok.
Hi Turecki, It's a moderately easy fix for this common issue with HP/Compaq Laptops. Simply go to ebay, purchase an "inverter" board built for a NC8000 laptop can range from $10-$50 just purchase one with a minimum 6 month warranty. Its about a 0.5 inch by 15 inches. Unscrew all of the tiny phillips screws located and hidden behind black rubber covers on the LCD screen. Pop off the plastic LCD cover and replace the inverter board located at the bottom of the LCD (plug & play). Put it all back together and voila...problem fixed.
Have fun and practice some repair skills.
~Alex
Posted on Mar 06, 2009
Any solutions to my notebook problems
The first thing to always try is resetting your PC. With a laptop, you must unplug it and remove the battery. While the laptop is unplugged and the battery removed, hold down the power button for a minimum of 30 seconds. This will reset the PC. Plug it back in and see if it works now. Always try to reset the PC first, for many different problems.
May 31, 2014 | Compaq Presario Notebook
The battery and power plug on leds flash orange at the same time. When I press the power button, the HDD and the ON leds come on green for a few seconds then they go off and machine shuts down without...
Your battery probably got wet. If this is the case you are going to have to deal with it by following the procedures you just outlined until you replace it due to the fault in the battery.
Jun 23, 2011 | Toshiba Satellite L455DS5976 Notebook
When I went to shut it down it had a few programs to shut down. I waited a few minutes then closed the lid down. It is now flashing on the first light symbol on the corner and when you open it up it turns...
Sounds like it is stuck in hibernate mode. Hold the power button down for 5 seconds and try to start it again. If it doesn't start remove the battery, unplug the laptop, hold the power button down for 60 seconds. Now plug in the power supply but leave the battery out. Turn it on. It should start now and you can re-insert the battery.
Apr 22, 2011 | Compaq Presario CQ60-212US Notebook
Hi: My Aspire 4710Z was not shutting down properly. I pulled out the battery to turn it of. Now, when I put back the battery after few hours, there is no power in my Lap top. Screen is black and now...
Remove the battery and the AC adapter from the laptop.
Press and hold the power button for 60 seconds then let go
Plug the AC adapter only back into the laptop
Now press the power button on the laptop
If it now boots properly shut down the laptop and insert the battery
Now push the power button again
If it now fails you may have a bad battery
Mar 05, 2011 | Computers & Internet
My HP Compaq nc8000 will not start up correctly. When i hit the power button, only one green LED comes for a few seconds, then a yellow LED (which is the charge light) it sounds like the laptop is powering...
Check it is powering laptop,if not the jack has bad connection and not connecting to mainboard constantly,
Dobt thats what is happening in your case but need to rule it out for next step.
Remove the battery then try ac adaptor on its own.
Next try removing ram,insert one stick only,next sub it with other stick only,if still no good remove hard drive,you are attempting to get bios start screen to show up,if still no good you may be looking at mainboard power regulator ic fails,which are a real problem on some compaq models this also damages other components on the mainboard(google search will reveal what im on about)
Dont remember offhand but if its the type that has common mainboard fail its not worth repairing as the new boards always fail eventually due to same problem.
There are also light error codes in the back of the manual and available online to diagnose this by the type of lights showing up.
Feb 17, 2011 | HP Compaq Business nc8000 Notebook
When I turn on my HP Pavillion DV2000, the lights are displayed, however the screen is blank, is there something that can be done??
Remove the AC power jack and then the battery. Hold down the on/off button for 30 seconds, that will drain any residual power from the laptop.
Then just plug in AC power only and try to boot the laptop up. If it boots let it load Windows and then shut it down. Remove the AC power jack and then re-insert the battery. Then try to boot the laptop up.
If it boots up you all good.
If this does not work please post back.
Good luck.
Nov 16, 2009 | Dell Latitude D600 Notebook
DV8309 power up problem: blue lights on for few seconds then off
The inverter inside the lcd panel is most likely your problem. Try removing the whole lcd screen from the laptop if you are capable and run it with the external screen to confirm. leave the lcd switch off (this lcd switch above the power button turns the lcd inverter on and off)
Jun 19, 2009 | HP Computers & Internet
Booting problem in acer 4520
*********** board needs to be replaced
Dec 08, 2008 | Computers & Internet
HP nc8000 shuts down after 10 seconds
try pushing on the upper right corner of your laptop, above the home key, does it start up again?
If so its the maxim chip
if not take one so dimm out and dissable wireless.
Could also be your battery not charging because a battery or power cord malfunction.
Oct 21, 2008 | HP Business Notebook NC8000
AC Power and Battery Problem.....
Sounds like the battery or possibly the charging circits themselves are the problem. Can you try turning on the laptop with just the power cord in and no battery?
Aug 20, 2008 | Compaq NC8000 Notebook
HP Compaq Business nc8000 Notebook Logo
1,017 people viewed this question
Top HP Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
