Question about Crown MA-5002VZ 2-Channel Amplifier
Crown macro tech 3600VZ AMPLIFIER
CAN ANY KIND PERSON TELL ME WHERE I CAN GET CIRCUIT DIAGRAMS /TECH.INFO FOR THIS AMPLIFIER .I AM BASED IN UK.AND WOULD MUCH APPRECIATE ANY HELP OFFERED.
THANK-YOU DEKKA.T.
    Brigadier General:
  • 5,158 Answers
Haven't found one yet tho i'm wondering... what issue/problem are you having with the amp ?
Robert
Posted on Sep 14, 2008
  • Roberta Smith
    Roberta Smith Sep 14, 2008
    Also... have you considered contacting the company directly. they are usually pretty good about providing information on there products. I would suggest you start here
    http://www.crownaudio.com/support.htm
    Robert
    Please rate this solution... thanks
  • 2,071 Answers
  • 43 Answers
Best buy would be a start
circut city
Ineed 3600vz lay-out circut
http://www.eserviceinfo.com/downloadsm/45838/Crown_MA3600VZ.html
Apr 29, 2014 | Crown MA-5002VZ 2-Channel Amplifier
Unit turns on but goes to red
Make sure that no more that 8 ohms are hooked up for each speaker. Or whatever the rating is for that amp
Oct 19, 2013 | Crown MA-5002VZ Macro-Tech Professional...
Circuit bort is broken
Do you mean Circuit board?
If so then it will depend on how bad it is. For example if it has broken components on it. These would need to be replaced. A small crack that has broken the printed tracks could be repaired by soldering it back together and using wires to ensure it makes the required circuits.
Really bad damage and broken parts will make it fit for the bin!
Oct 03, 2013 | Crown MA-3600VZ Amplifier
I test my crown amplifier 3600vz a few minites then i stop couse verry hot i discover i open the back panel i saw resistor12 and resitor14 burn,i ask what is the promblem,the value of r12 and r14 is...
The ouput drivers have failed and along with the heavy current drain the resistors burnt off . So before the resistors are changed the entire section of the predriver and output section must be checked before new outputs are installed.
test the amplifier with a series voltage regulator and is there is heavy load drain then shut down and recheck till the drain limit is maintained to confirm the correct working of the amplifier.
Sep 09, 2011 | Crown MA-3600VZ Amplifier
How much power does a single Crown IT-TECH 6000 occupies from power socket
http://www.crownaudio.com/pdf/amps/137434.pdf
it varies between what you are playing and how you have wired the speakers
May 10, 2010 | Crown I-TECH 6000 Amplifier
No power to Crown XLS 602 Amplifier
Hi...
There may be some internal fuses on that unit.
You can open it by taking the cover off and looking for fuses and discolored parts.
It may have a thermal fuse on the power transformer which then will require service
Check the web for service people in the UK
Mar 31, 2010 | Crown XLS 602 2-Channel Amplifier
I have a crown macro -tech 600 and i get a humming sound in ch 1. every time it is turn on. What can i do to correct it. Keith.
You can connect a oscilloscope on output 1 and see what kind of signal your amp produces. You can also check the optional plug-in module (PIP-clip or other types) on the back of your amp.
Regards,
Gerard
Jan 12, 2010 | Audio Players & Recorders
6000d amplifier cutting off
Hi...
Crown has posted on their website all the tech info you can probably use for your situation.
Cheers!
Jan 15, 2009 | Crown XTi 2000 2-Channel Amplifier
Crown 3600vz the two red light on amp stay on and does not go off
disconnect your load (speakers) and check.if it is o.k your problem is in speaker.if the problem goen your problem will be short circuit in speaker or cabels.-if not the problem will be in amplifier and this is not logic matter because it is new -anyway try to disconnect all inputs.if the problem goen your problem is in one of the inputs-try to connect input one by one until you find the bad one-if all above failed return your amps back to the shop.(from where you get them)
Jan 02, 2008 | Audio Players & Recorders
Crown MA-5002VZ 2-Channel Amplifier Logo
552 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
