Question about Crown CM-311A Professional Microphone
Wiring diagram the xlr connector pulled loose from the inside. I know how to fix but don't where the wires go need a wiring diagram
Http://www.performanceaudio.com/media/pdf/54/3429_b.pdf
That should shed some light...might have to through solder on to the circuit board should be relatively easy!
Posted on Dec 02, 2008
? turn signal connector wires came loose only then wiper stop working + brake lights turn sig was searching for any help for wire diagram to get thing working again 2001 f150 its 7 wires, Thanks for a
Go to alldatadiy.com and buy the wiring for your vehicle. Other wise go to the junk yard and cut the plugs and wires out of an exact vehicle. This is the only two ways you will fix it. Exact diagrams or exact plugs and switches.
Nov 16, 2014 | Cars & Trucks
How can I fix a broken cable inside a sennheiser mzh3040?
you have to unsolder the wires on the coil assembly then pull everything out through the bottom. replace the bad wire, reassemble the xlr end and resolder the wires to the coil.
Aug 05, 2014 | Sennheiser Audio Players & Recorders
L need a wire diagram for the joystick
You have something much more serious to address before you replace the female xlr fitting. I have never, in 12 years and hundreds of issues with chargers and such, never saw a burned connector. You need to figure out why it burned before you restore it, otherwise you are going to toast another xlr connector, or worse, yourself!
Apr 27, 2014 | Health & Beauty
2001 Honda XLR 125 R wiring diagram
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2001 Honda XLR 125 wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
Service Manual Honda Xlr 125
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/227
Apr 26, 2013 | 2001 Honda XLR 125 R
Just bought a Charbroil 4637133 Quickset grill at yard sale and it clicks but doesn't ignite. I looked underneath and on the other side of the control panel there's a wire connected to the ignitor...
the wire is supposed to connect with a small round slip-on terminal lug. They often brake at the lug, so you are left with just a hanging wire.
Look inside the grill at the burner- somewhere you will find a small metal probe pointing towards the burner. Once you find the probe, look underneath for the other end. This is where the wire is supposed to go.
Good Luck, and Thank You for using FixYa!
Jun 10, 2011 | Char-Broil 7000 Quick Set Gas Grill
The wiring has snapped from the mic to the xlr socket on the microphone is there somewhere i can get a diagram to fix it? the mic is a se electronic z3300a
It uses a standard balanced XLR wiring which is 1= ground/shield, 2= (+ve) hot and 3 is (-ve) cold. Do not bridge pins 1 and 3 as this mike uses phantom power. Please let me know if this helps.
Nov 18, 2009 | SE Electronics Z3300a Professional...
I need to know how to wire an xlr y adapter
I always solder it this way.
Take a female XLR connector, two thin sym. cables and two male XLR connectors.
Solder both cable parallel in the female connector and the ends on the male connectors.
This way you get the same signals on both inputs of your amplifier.
Regards,
Gerard
Oct 26, 2009 | Behringer EUROPOWER EP2500 Amplifier
Where can i get my shure beta 58 repaired? I live in Redditch in the UK.
The easiest way to find a service agent near you for your microphone is to contact Shure at the following;
All service and repair issues for Shure, QSC, Phonic, Sound Devices and Radial products are handled directly by Shure Distribution UK. Please contact them at the following for information on service and repair issues:
Unit 2
The I.O. Centre
Lea Road
Waltham Abbey
EN91AS
Phone: 44(0) 1992 703058
Fax: 44(0) 1992 703057
email service@shuredistribution.co.uk
Hope this helps. Please remember to rate my answer.
Many Thanks
Jul 13, 2009 | Shure Beta 58A Professional Microphone
Shure SM57 Wire broken off
On the XLR end, you should see a small screw hole. This screw is reverse threaded. In other words to make it go into the mic, you need to turn it counter-clockwise. Once that screw is inside the shaft, the XLR connector should come out. You may need to pull it out using needle-nose pliers. Pull carefully so you don't break the wires.
Dan
Oct 06, 2008 | Shure SM57-LC Professional Microphone
Maytag ice dispenser wiring diagram model MSD2456GEB
apc...appliance parts center has a good web site that might get you a wiring diagram. or your local appliance supply store might.
Jan 09, 2008 | Maytag MFI2568AE Side by Side French Door...
Crown CM-311A Professional Microphone Logo
916 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
