I want to get a wep key for my router model wrt54g-v8 serial number cdff1g5b8259
  • 3,940 Answers
You can create a WEP easily.
In the router setup, when you enable wireless security, you select WEP, then you can use any alpha numerics you want for the key.
for 64bit encryption, you can use a 10 digit key. ( I suggest an old phone number as it is 10 digits, hard to figure out and generally easy to remember) 128 Bit encryption is a 26 character key which is hard to guess, but hard to remember too.)
Once the key is set in the router and saved, you merely View Wireless Networks, select you router and type in teh key when prompted for the key.
Posted on Sep 13, 2008
Wep key for Linksys
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option (you) can copy the wep key from this field if you want to use the old one or just modify it for your new wep key8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select saveand apply. then you are good to go.
Dec 25, 2011 | Linksys WRT Computers & Internet
Wheres my wep key code?
You will need to open the setup page of the router and check the settings of the network. It depends on the model of your router. Follow the link how to find network key wep / wpa
Dec 01, 2011 | Linksys Wireless-G WRT54G Router
How do i make my unsecured network secure? using linksys WRT54G v8
Access the setup page of router by typing 192.168.1.1 in the address bar.
By default, leave the username blank and the password is admin.
Once on the setup page, go to Wireless. Under Basic Wireless settings, change the default SSID Linksys into any name. This will allow you to easily determine which is your wireless network.
Then go to Wireless Security and enable WEP. Type a passphase and click the generate button. Take note of the Network key. Remember that you will use this network key to all wireless computers.
On your wireless computer, view the available wireless networks or site survey. Select your SSID and enter the network key to connect.
I hope this helps!
Jun 20, 2010 | Linksys Wireless-G WRT54G Router
Is windows 7 compatible with WRT54G router?
Yes, but you can not use your passphrase to attach to WEP. You will need to use one of the generated keys. It's the number onder your passphrase in the router configuration. It'll look like "accde45fff296" or something like that.
Dec 07, 2009 | Linksys Wireless-G WRT54G Router
How do i set up a password for the router?
access following link
http://192.168.1.1
or
http://192.168.0.1
then type user name as "admin" and password as "admin" or blank or "password"
then set your internet as WEP then enter wep 128 bit encryption key like number thensave setings wep encryption key is your password.
Jul 17, 2009 | Linksys Wireless-G WRT54G Router
I DO NOT HAVE A PROBLEM
you dont require cd just go to the web site to download instructions to set up for free! its so simple! http:/www.linksysbycisco.com/us/en/support
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Linksysy asks for a network key (Wep key or WPA key)
1. Using a computer that is wired to the router, access the router's setup page by typing 192.168.1.1 on the address field of your browser.
2. By default there is no username and password is admin.
3. Once you're in the setup page, click wireless then there is a sub tab there called wireless security.
4. You will find there the wireless key that is enabled in your router.
Nov 08, 2008 | Linksys Wireless-G WRT54G Router
How to lock a linksy box?
Logon to your routers settings. normally by opening the following web page http://192.168.1.1
  1. Now click on the "wireless" tab
  2. Click on the "Wireless Security" sub tab
  3. In "security mode" select "WEP"
  4. Leave the "default transmit key" as it is
  5. Change "WEP Encyrption" to "128 bit"
  6. In the "Passphrase" enter anything you want. Make it about 8 characters long
  7. Press "Generate" and you will see Key 1, 2, 3 and 4 now have 26 Digits in each. Congratulations you have now secured your router and gernated your WEP key.
  8. Now you have 4 keys, you only need to use . But which one??? Easy. Above where, it says "Default Transmit key" and a number, 1-4. The number that selected is the Key you need to use i.e if 1 is selected use the letters in Key 1.
May 17, 2008 | Linksys Wireless-G WRT54G Router
Network key
Lkrawlings:
Can you go into your router from IE? like http://192.168.x.x, then from this configuration page of your router you can find what key you had put into your router. Make sure the type of security you are using like WEP, WPA, PSK, WPA2 etc. This key should match on your desktop or laptop machine to gain connection to your router.
If you are unable to find your key like this then:
You could refresh your router to factory defaults by pressing for 5 seconds, you will find this hole at the back of your router. try going again into your router like I said above and make up any other key.
Hope that helped!
Dec 07, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Computers & Internet Logo
David Payne
David Payne
