Question about Garmin Rino 130 (14 Channels) 2-Way Radio
Rino 130 5.8 version
No voice transmission from 1 unit to another. however the tones send fine.
I opend my unit and see that the mic is disconected from its posts. so i am looking to repair that issue. it looks like the posts are too short or recessed?
Posted on Sep 13, 2009
Menu send note missing
When you do updates it might have taken off the message option. it is just like a computer when you upgrade it will take off old programs and install the new ones... so you might check into that...
Aug 09, 2008 | Garmin Rino 120 2-Way Radio
I cannot hear other radios with my rhino. It
Check the manual to see if you can set the PL tones (CTCSS) and set them to the same as the other radios. If you hold down the monitor button and you can hear the other radios this is most likely to be the fix.
Nov 09, 2009 | Garmin Rino 130 (14 Channels) 2-Way Radio
My rino always says searching for sattellites
Once your rino travels more than 600 miles from original satellite fix you need to - Go to main page / satellites / options / new location.
Should take about 15 minutes to locate new satellites.
Sep 09, 2009 | Garmin Rino 130 (14 Channels) 2-Way Radio
My garmin 520 radio does not transmit voice you can hear taps on the microphone and blowing into it but no voice even if u yell. it is less than one year old and has yet to be used.
You need to have this on a service monitor to see what if any frequency deviation is occuring when you transmit. You could have a defective mic or you could have a deviation setting set to low, whixh with th emodern radios is something you may or may not have to set within the program. "Back in the day" we set the deviation manually with a tweak of a pot while looking at a deviation meter and injecting 1K audio tone riding the carrier
Jul 05, 2009 | Garmin Rino 130 (14 Channels) 2-Way Radio
I need a battery cover for a rino 130 where can I get one?
Contact Lindsey at Garmin Support - 1-800-800-1020 or 913-397-8200, back cover is about $14.00
Jun 28, 2009 | Garmin Rino 130 (14 Channels) 2-Way Radio
I can not transmit.
i had this problem with mine that i just got a month ago. i called garmin, they said send it in or return it and get a new one. I returned and got a new one today and it sends and receives perfectly. You need a new one.
Nov 10, 2008 | Garmin Rino 530 GPS Receiver
Rino 120 Send note
This sounds like the new firmware version may not work on the
older model.
The best solution would be to contact Garmin
Product support at (913) 397-8200 or 1-800-800-1020
Monday - Friday, 8am-5pmCDT or by email at sales@garmin.com
Pat
Garmin Rino 130 no Power
There first 2 main thing to check..... the off on switch.... and the fuse. Insie the radio there is a very small fuse.... its a surface mount component fuse... very small. That could be the problem. Also check the contacts on the radio..... if you have a way of connecting the correct voltage directly to the radios power terminals using jumpers I would definatly do it. Your most likly going to have to take the raio apart and and connect the battery to trace the power through it. The small fuse will be one of the first components after the positive power input. If this seems too much..... bring it to a radio shop... they can do all this quickly
Sep 20, 2007 | Garmin Rino 130 (14 Channels) 2-Way Radio
Garmin Rino 130 Shut Down
I had the same problem; mine would shut off when bounced around too.
I used a #0 phillips screwdriver (very small) to take out the 6 screws that hold the case together, Carefully separate the face and back because there are wires that can be broken if you pull them apart too fast.
After you get the case apart, lift up the circuit board at the bottom and you will see a small blade pin that sticks out from the side where the batteries are and is supposed to slide up into a contact on the circuit board. I guess over time it starts to wiggle and get loose so I carefully bent the pin (very slightly so it would rub the inside of the contact.
So far I have tested it by dropping and beating it up a little and it seems to have fixed the problem.
Hope this helps.
Jun 16, 2007 | Garmin Rino 130 (14 Channels) 2-Way Radio
Garmin Rino 130 (14 Channels) 2-Way Radio Logo
76 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Steve
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
