Question about Dryers
Push to start switch for whirlpool dryer i need diagram i have four terminals on switch two blk. wires, one tan, and one white withred stripe whirlpool model #11062822101
    Genius:
  • 1,239 Answers
Hi push to start switch for - how-to-repair-a-dryer-1.jpg Except for the power cord and the exhaust vent, the components that make up the dryer are contained in a sheet metal box. Each component acts independently of the others, but all are interrelated in some way. There are several different ways to disassemble the cabinet for tests and repairs, depending on the manufacturer and model of the machine. Basic disassembly procedures are simple.
Some knobs may be held to their shafts with setscrews. Unscrew the fasteners and pull the knobs straight out. To get at most parts, however, only remove the back panel. Don't disassemble the rest of the cabinet until you're sure you can't make the tests, replacements, or repairs from the back. If the light in the dryer burns out, remove it from the dryer. You may need to remove retaining screws and panels to access it. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the
Step 2: To remove the lower front panel, pull it away from the bottom of the cabinet. Lift the lower panel up and away. Remove the springs under each side of the lower panel.
Step 3: To remove the top panel, wedge a stiff-bladed putty knife under the rim of the top and pry the top off. The putty knife helps release several spring fasteners at the top of the cabinet sides and front.
Step 4: To remove the dryer's control panel, remove the screws that hold it to the cabinet top or front. These screws may be under a piece of metal or plastic trim; pry off or unscrew the trim. Most knobs are friction-fit; pull them straight out.
Caution: When testing or repairing the electrical parts of a gas dryer, remember that the dryer is hooked to a gas pipe. Turn off the shutoff valve on the supply pipe before disconnecting the gas supply line or moving the dryer and before doing any electrical work.
Posted on Sep 13, 2008
Old whirlpool thin/twin Dryer timer old timer M404-G New timer M460-G how to hook up
The problem as stated is that the new M460-G timer does not have the same pins as the old one (because there seem to be a variety of sub-models under the M460-G name). However, I have successfully (at least to provide the timed heat function) used a different M460-G on my Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, I had to figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also by inspection of a wiring diagram at appliance pros dot com
On Frigidaire Crown FBGB23RGS2 Gas Dryer:
The original M460-G is wired:
Terminal / Function / Color
A / Gas / Org
B / Line voltage / Red
c / Motor / Wh
Timer wired between TM and C
AD / Auto Dry / Pink
TD / Start Switch and Motor / Tan
On other M460-G Gas Dryer timer (from mystery Dryer), I wired it to into my Crown dryer as follows:
Terminal / Function / Crown Dryer Wire color
BU / Line Voltage / Red
BK / Motor / Wh
R / Gas / Org
V / ? / No Connection
Timer wired between TM and BK
WB / switched on while Motor & Gas / Tan
OR / ? / Pink (figured it was safe)48146720-bbc3-47da-833c-6d50a0cf5df0.jpg
Sep 06, 2015 | Whirlpool Dryers
1992 dodge dynasty radio diagram
Assuming the radio connects to the RS amplifier, the harness is as follows:
From fuse 13: PNK or BLK -> PNK/LT BLU -> PNK or BLK -> PNK/LT BLU -> radio (!)
From fuse 20: RED/WHT -> radio
From fuse 10: VIO -> amp
From radio: ORG and BLK/YEL to interior lights
From radio to amp: DK BLU/RED, BRN/RED, DK BLU/ORG, BRN/ LT BLU, VIO, DK GRN or DK GRN/WHT, DK BLU/WHT, BRN/YEL
From radio to pwr ant: DK RED/GRN
From RS amp to:
R. door: LT BLU/VIO and LT BLU/DK GRN
R. front: ORG/BLK and ORG/RED
R. rear: TAN/BLK, TAN/RED, TAN/DK GRN, and TAN/VIO
L. rear: WHT/DK GRN, WHT/VIO, WHT/BLK, WHT/RED
L. front: YEL/BLK and YEL/RED
L. door: LT GRN/DK GRN and LT GRN/VIO
Mar 17, 2017 | 1992 Dodge Dynasty
Jvc kd-hdr1
Most wiring now is standard colors....red=ignition(goes to a switched power source...Yellow=battery...goes to a hot all the time(even with key off)...black=ground...white=left front speaker positive...white w/blk stripe=left front speaker negative...gray=right front spkr +...gray/ blk=right front spkr - ...green=rear left +....green/blk rear left - ...violet=right rear +...violet/blk= right rear - ...light blue or blue with a stripe is the remote turn on lead either for an amplifier or power antenna...some radios have an orange/ with white stripe that connects to your parking light dimmer circuit to dim the radio light with the dash lights....and then you should have the antenna plug and possibly rca outputs that go to an external amp
Feb 26, 2012 | JVC KD-HDR1 CD Player
Hi Ginko. I have a Kenmore dryer model 11086810100 that has some wires removed from inside. The only HOT I can find is the red wire. I have 2 wires that have femals push-on crimped terminals, but I have no...
Hi Robert.
Thanks for the pics. I operate in UK and color codes here are different.
From what I can see the wiring in your picture does not match the US standard either.
The thermal fuse for example should have two blue terminals, not red and blue. The thermal fuse wires goes on one side to start, and on the other to the drive motor through the broken belt switch (if present).
The wiring at the blower must be revised and done again.
Here a service manual covering Kenmore 70 series dryers.
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
There is a wiring diagram at page 25.
Here a picture showing correct wiring: http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
See also the pictures in this blog:
http://www.satfix.net/showthread.php?931-How-Dryers-work.-Whirlpool-Inglis-Kitchen-Aid-Kenmore-Admiral-Roper
About the red and yellow cable, the only red yellow wire in the diagram operates the switch for the guard function. The wire becomes hot and powers the motor when the guard switch is closed.
Parts (including wiring harness and terminals) are available here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086810100/0582/0151200?pathTaken=&prst=0&shdMod=11086810100
Jan 02, 2012 | Kenmore Dryers
I need the wiring diagram for a pioneer avic-n2! i need to know which colors do what!
Pioneers wiring is easy. Red is ignition-Yellow is battery-Black is ground-Blue is remote for amp or antenna-Orange is illumination-Speaker wires are usually grey, grey w/blk stripe-white, white w/white stripe-green, green w/blk stripe-purple, purple w/blk stripe. Green and purple is rear, white and grey is front
Sep 18, 2010 | Pioneer AVIC-N2 Car DVD Player
Need a diagram on convertng a three prong to a four prong plug.
you need to put the RED and BLACK wires on the terminals L1 and L2 these are the power wires,polarity doesn't matter either wire on either terminal/then the WHITE wire goes to the N neutral terminal/the GREEN or GREEN/YELLOW STRIPE wire goes to the metal case of the dryer as safety ground
Jan 31, 2010 | Dryers
Im need a wiring diagram for a stereo in a 1991 2500 4x4
GND- blk(thick)
PWR-ylw(thick)
P.ANT- blu w/white stripe
DOOR chime- orange
SPEAKERS
FrontL- brn wire and tan wire FrR-grn and lite grn wires
LRear-ylw and brn w/white stripe wires Rrear- dark & lite bl wires
Nov 03, 2009 | 1991 Chevrolet K2500
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Need a wiring diagram for distributor for a 1988 pontiac fiero gt with a 2.8 v6
There are two plugs which are plugged into the distributor one is a two wire  and one is a four wire. the two wire has a pink wire on terminal A and a white wire on terminal B these two wires go to the remote coil  black plug The four wire has a black wire with a red trace on terminal A A tan with black trace on terminal B A purple with white trace on terminal C A white wire on terminal D
Aug 09, 2008 | 1988 Pontiac Fiero
Dryers Logo
102 people viewed this question
Top Dryers Experts
