Question about Maytag MDB7100AWB Dishwasher
Wont run, and control board blinks
My dishwasher stopped working. There is a couple of inches of water in the bottom, and the control board is blank except for a small blinking light in the lower left corner. The outgoing drain is clear, the motor is not seized, or stuck, and I tried turning power on and off with no results
Model MDB7160AWB
    Genius:
  • 1,239 Answers
Hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
If your dishwasher won't fill with water properly or isn't drying the dishes, you most likely have a valve or heating element problem. In the next section, we'll discuss how you can assess these types of problems.
Valve, Dispenser, and Dish Rack Repairs
Checking on and routinely maintaining the various valves, detergent dispenser, and dish rack can keep the right amount of water and cleaner working effectively in your dishwasher.
Posted on Sep 13, 2008
Samsung dishwasher heavy and delicate lights blink and cycle stops
The lights that are blinking are indicating an error code--the particular code you describe is a "heater error". You will have to check the circuit for an open heater element, loose or broken wire, defective main control board. The part number for the main board is DE92-02256C. Hope I helped you!
Aug 07, 2015 | Samsung DMT400RHS Builtin Dishwasher
My viking vdb325ss dishwasher runs for a few minutes and then stops with control pad lights blinking. The "normal cycle" and "pots and pans" lights blink together. I have reset and restarted the dis
Hello Peter!
Your owners manual or a call to Viking should help you decode the blinking panel lights. They are not random and are a desperate cry for help from the machine.
It has been my experience (YMMV) that a common dishwasher problem in older machines is accumulated grunge (the technical term) in the water level sensor. In many cases the sensor lives in a plastic container on the side of the DW and although the designers try hard to avoid contamination, the container eventually loads up and intermittently jams the float.
Before I pulled the unit however, I'd check the bottom of the wash cabinet for contaminants. There may be an screen (under a cover plate) that has clogged.
Your situation sounds a bit different, since my Samsung did not pump out water, it just stopped and flashed a code, but who knows? Go for the low-hanging, common issues first.
All the best.
Nov 23, 2014 | Viking VDB325SS Dishwasher
Water in bottom of kenmore elite ultra wash dishwasher
you must check the filters that are at the bottom under the spray arm
then you must start and then hold down cancel or stop and it should kick in the automatic water discharge mode and activate the water pump if this does not work you need new dishwasher pump installed which can be found online by googleing your model number. gut if this all works then the small flapper thats internal on the pump isnt sealing and allowing water to flow back into the bottom. last but not least you might need a new control board.
Nov 02, 2012 | Kenmore Dishwashers
The dish washer starts to fill then stops and starts again then stops and the red light blinks on and off
Does it blink seven times, pause, then seven times, pause, seven times, etc. ?? If so you may have a bad heater element. Or the water temp into the D/W is not hot enough. Most machines require at least 120 degree water to work properly. Take a close look at the heater if it looks ok you'll have to check it and the heater circuit with a meter. Turning the breaker off for 7 to 10 minutes will reset the control board but wont fix the heater of course. Good Luck
Mar 12, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher wont fill
Make sure the dishwasher is not stuck in some kind of error mode. Make sure the water valve is turned on. Take the bottom front service door off and locate the water valve on the front left bottom of the machine. Make sure there are wires connected to it. If it's still not working, pick up a cheap electrical multimeter. Set it to the resistance setting, and remove the wires from the water valve. Test the resistance across the water valve's terminals. If the resistance is very high, or infinity, the water valve needs to be replaced. If the water valve is ok, turn the dishwasher on and test the voltage across the wires that go to the water valve at a time in the cycle when you know the dishwasher's controller will be trying to let water in. It may be either ac or dc voltage, so try both settings on the meter if you don't get a reading. If no voltage is read across those wires, open up the dishwasher and find the circuit board that the water valve's wires connect to, and make sure they're connected to the board properly. If that still doesn't work, there's a problem with the dishwasher's control board. Look for a square or rectangular blue, gray, black, white box on the circuit board near where the wire plugs in. This is the mechanical switch that turns on the power to the water valve when the computer sends a signal that it wants water. This switch may be jammed up. Try tapping it firmly with screwdriver. If that doesn't work, you can desolder the power switch and solder on a new one. If that doesn't work, you'll need to replace the board or do some advanced work on it.
Jul 14, 2009 | Bosch 36 Inch Pyramid Chimney Hood - Black
My Bosch SHX46A06UC just runs and runs and wont stop.
The control board is not turning on the water heater due to bad control board, heater or limiting fuse.
May 10, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
KENMORE ELITE DISHWATER panel went blank but there
Check the continuity of the thermal fuse. It's clipped onto the electronic control inside the console.
Let me know if you need more help.
Mar 12, 2009 | Kenmore Dishwashers
Dish washer doesn't drain, and control board only blinks
sounds like the control board is faulty. i would suggest having a technician replace it.
Sep 13, 2008 | Dishwashers
Maytag MDB7100AWB Dishwasher Logo
221 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
