Suspect dvd drive ribbon cable disconnected from Acer 9410 laptop
How do I access it; open the case or access via battery or memory openings?
are there manuals/ instruction online somewhere?
thanks
  • Janice Reed Jan 19, 2009
    need to remove dvd drive incompaq presario 700 laptop .. but i can't figure out how to get it out
  • Steven Brown May 11, 2010
    Can you clarify what brand and model number of DVD drive you're attempting to open ?
    Az.
    Scholar:
  • 95 Answers
I guess it depends on the type of drive your laptop came with. Some laptops have a switch on the bottom of the laptop that lets you release and remove the DVD drive. Others have a small screw that has to be removed to pull out the drive. Yet others need the case completely taken apart. Guess it depends on your model...
Steven
Posted on Sep 17, 2008
How do i safely remove the cable that attaches to the motherboard on my toshiba laptop
Toshiba satellite motherboard removal.
A motherboard is usually replaced for one of two reasons. You either replace a motherboard because it has gone bad, or you replace an older motherboard with a new or upgraded motherboard. In either case you will have to completely disassemble your laptop to even gain access to your motherboard. Fortunately, the Toshiba Satellite laptop can be completely disassembled even if you don't have a lot of technical knowledge.
Turn off the laptop, disconnect the power cable, remove the battery pack and disconnect any miscellaneous cables and peripheral devices. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Attach an antistatic wrist bracelet to prevent shock from static electricity. Static electricity can harm your computer's internal parts. Place the laptop face down, and remove the single Phillips-head screw attached to the hard drive cover. Remove the hard drive cover, then set it aside. Remove the single Phillips-head screw attached to the wireless card/memory cover. Remove the cover and set it aside. Slide the hard drive out of its compartment. This will disconnect the hard drive from the computer. Set the hard drive aside very carefully. Push on the ejector tabs on either side of each RAM module. Slide the RAM modules out of their compartments at a 45-degree angle. Remove them from the laptop and set them carefully aside. Disconnect the antenna cable from the wireless card, and then lift the wireless card out of the laptop. Remove the four retaining screws from the modem card. Lift the modem card slightly out of the laptop, and then disconnect the modem cable from the motherboard. Set the modem card aside. Remove the single Phillips-head screw securing the DVD/optical drive. Slide the DVD drive out of the laptop's frame and set it aside. Remove all marked screws from the bottom casing of the laptop, and then place the laptop face up. Open the laptop as far as it will go. Use a small flathead screwdriver to pry up the keyboard bezel. The keyboard bezel is a small plastic strip sitting between the keyboard and the LCD display. Remove the two Phillips-head screws securing the keyboard in place. Lift up on the keyboard and disconnect the keyboard's ribbon connector from the motherboard. Remove the keyboard from the laptop and set it aside very carefully. Close the laptop. Place the laptop vertically so the LCD display hinges are face up. Remove the two Phillips-head screws from the hinges. Set the laptop down and open the laptop as far as it will go. Remove the four Phillips-head screws securing the LCD display. Lift up on the LCD display, and then disconnect the video cable from the motherboard. Remove the LCD display from the laptop and set it aside carefully. Disconnect the DVD control board cable, the touchpad cables and speaker cables from the motherboard. Disengage the plastic latches on the rear of the laptop casing near the hinges, and then remove the top casing from the laptop's base and set it aside. Remove the two Phillips-head screws securing the CPU fan and heat sink in place. Disconnect the fan cable from the motherboard. Remove the fan and heat sink from the motherboard and set it aside. Remove the single Phillips-head screw securing the motherboard to the bottom laptop casing. Disconnect the USB port connector from the motherboard and remove the jack from its housing. Lift the motherboard from the bottom laptop casing and very carefully set it aside.
Hope this helps.
Dec 13, 2012 | Computers & Internet
How to replace cmos battery on satellite p105-s6217 laptop
Turn the laptop over and remove the battery pack.
From the bottom of the laptop, unscrew the plastic shells securing the slots for memory,
Bluetooth, hard drive and modem.
You may have to remove more than one screw for each shell. Keep all screws in a small container, away from the work area.
Remove the memory (RAM) modules, the hard drive and any optical drives (CD-ROM or DVD-ROM).
Press the clips on either end of the memory slot to raise the RAM module and detach by pulling it out. Work slowly and carefully, to prevent damage to RAM modules or the memory slot.
Do the same for all modules, if you have more than one.
Slide out the hard drive and optical drive. If the drives seem to be stuck, look for any screws you may have missed.
Turn the laptop over and insert a pointy tool under the thin strip at the top of the keyboard. Use the tool as a lever to pry the securing strip loose, while working with your finger to release latches along the length of the strip.
Remove the keyboard by undoing two screws securing it.
Raise the keyboard and disconnect its cables.
Close the laptop lid and turn it around, so that you are facing ports on the back.
Remove two screws from the metal plate around the ports.
Open the lid and remove a single screw securing the wireless card cover; the screw is under the keyboard, which you already removed.
Disconnect cables from the motherboard.
Access the board through the space created by removing the keyboard. Unplug the speaker cable from the motherboard by carefully pulling at its head.
Unscrew and remove Wi-Fi antennas, and detach the wireless card from the motherboard. Unplug thin, ribbon-like cables from the video card.
Detach the display assembly from the base of the laptop.
Loosen any attachments, and pull the casing toward you to detach the display assembly, including the LCD panel, from the base.
With the motherboard completely exposed, unscrew and remove the video card.
Undo two screws from either side of the hard drive housing and detach the drive.
Dismount the CPU heat sink and detach the fan cable from the motherboard by removing five screws.
You can now access the battery board with the CMOS battery attached to it.
Undo two screws to detach the battery board from the motherboard.
Disconnect two cables running from the battery board, and carefully raise the board to detach it.
Replace the CMOS battery by prying it open with a pointy tool. Insert a new battery and reassemble the laptop.
hope this helps
Oct 04, 2012 | Toshiba Satellite P105S6217
Dvd replacment
pretty simple, open case to access side screws , loosen/remove side screws
disconnect rear cables. slide drive out slide new drive in reverse order of assembly.
Jul 23, 2012 | Apple aluminum 13-inch MacBook laptop-...
How to open laptop
Hi Dear...........
If you want open any electronice think you need to complete tool box with first ad. If you have a complete tool then follow the mention instruction and open the laptop, if you don;t know anything about laptop then don;t try to open it.
  1. Reverse the laptop as shown in the figure. And remove the battery. Open the the screws from back side for the Wi-Fi card cover, the modem card cover, the memory card cover, the hard disk cover.
  2. Reverse the laptop as shown in the figure. And remove the battery. Open the the screws from back side for the Wi-Fi card cover, the modem card cover, the memory card cover, the hard disk cover.
  3. Take out the Wi-Fi card cover, the memory card cover, the modem card cover, the hard drive cover. Place them at safe place.
  4. You may require to Open the DVD drive with a paper clip.
    Carefully take out the DVD drive from the computer. In most of the computer one screw from the back site of the laptop fix the DVD Drive. So you have to remove all the screw from the bottom of the laptop.
  5. Insert a thin object under the securing strip(keyboard bezel) and lift it up. Be careful, it may be very tight(there are no screw at keyboard bezel in most of the cases)
  6. Take out the securing strip(keyboard bezel).
  7. Now you can see two screws securing the keyboard and these screws are easily visible remove those screws.
  8. Now careful keyboard is connected with flate ribbon cable to the system board. Disconnect the keyboard cable from the main board and remove the keyboard.
  9. Now you can fine one cable(most probably black colors) from LCD and it is connected to system board. Disconnect the LCD cable from the system board.
    Remove the screw connecting the LCD cable to the base.
    Disconnect the flat LED board cable from the system board.
  10. Carefully lift the display/LCD assembly off the base.
    The display/top cover assembly - LCD assembly and top cover assembly connected by hinges.
  11. Remove the screw securing the HardDisk holder.
    Remove the Hard disk holder.
    Disconnect the left and right speaker cables from the system board.
  12. Now remove five screws securing the heatsink assembly for CPU. And disconnect the fan cable from the main board.
  13. Carefully take out the heat sink off the CPU. And be sure to put heat sink thermal jel /glue when reconnecting the heat sink.
  14. Remove two screws normally at the corner side connecting the system board to the base
  15. Now lift of the system board starting from the left side, be careful with the PC card connector.
  16. Remove the system board off the base.
  17. Modem card is still connected to the system board with screws securing the modem card. If you want you can remove modem card.
  18. Remove the screw securing the optical drive holder.The screw is hidden under the black tape.
  19. Remove the optical drive holder.
  20. Remove four screws securing the card bus connector (PC card connector).
  21. Turn the system board right side up.
  22. Carefully remove the cardbus connector.Unlock the CPU and lift it off the system board.
  23. Turn the system board upside down.Remove two screws securing the video chip fan.
  24. Remove the fan cable on the system board.
    Remove the video chip fan
  25. Hay great techie guy you have done it.
Video :
Part 1
Part 2
Jan 09, 2012 | Computers & Internet
HOW do you open an acer one to access memory slot and hard drive?
Hi James, Here is a step by step video tutorial.
Enjoy your new upgrades.
Oct 22, 2011 | Acer Aspire One D255-2670
How do i disassemble to access motherboard and DC jack
Me too, need to get inside to clean and remove dust and see why my video is gone after about 10 minutes of operation or so, good chance it is an overheating problem, but I cant get the case open.
May 19, 2010 | E-Machines M5414 Notebook
How do I remove the keyboard for the Acer Aspire 9410
You should see a plastic piece that runs along the top of the computer just above the keyboard. This snaps in place and can be pried up. Be careful, though. There may be a screw under the computer that has to be removed first.
Look on the back of the computer. There may be two screws in the hinge covers. If so, remove them.
Once the plastic piece is off, you will find screws (probably 3 or 4) at the top of the keyboard. Unscrew them and lift the top of the keyboard up. Carefully disconnect the ribbon cable toward the bottom and you're there.
Nov 19, 2009 | Acer Aspire 9410 Notebook
Try updating the video driver. Also try to connect your laptop to external machine to check if the video display on the other machine is ok or not.
If same problem occur, suspected the LCD of your laptop is faulty and needs to be replace.
Jun 07, 2009 | Acer Aspire 9410 Notebook
Install new ram in Acer aspire L320?
Sorry- I have to disagree, One screw at the back releases the lid. Inside, the dvd/hdd sub-chassis has one screw holding it to a brass post on the mobo. Undo that, then lift the chassis slightly with it's plastic strap handle, so you can detach the two connectors from the SATA drive, and the ribbon cable to the DVD (careful you don't bust the latch).
Then the whole lump simply lifts out- and you can see the 2 memory cards. The one I've just looked at appears to have 2 x 512mb simms- so you could replace these with 2 x 1024mb DDR2 SDRAM simms, to give 2GB of ram, which is what Acer say is maximum.
Cheers- AL (Luton)
Apr 03, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
Removing L100 hard drive
Remove the front panel by gently lifting the three flat plastic tabs. Remove one screw at the corner of the disk drive and lift the disk drive and DVD drive upward by the plastic handle on top. Disconnect the two SATA connectors from the disk drive by simply pulling them off. Disconnect the ribbon cable from the DVD drive gently lifting up on the black tab at the ribbon connector. This is hinged and releases the ribbon cable.
The unit is now free and you can turn it over and remove the screws securing the disk drive.
Jul 20, 2008 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
282 people viewed this question
David Payne
David Payne
