Question about Emerson Smartset Clock Radio
Antenna Have trouble getting local FM station..can I extend the antenna reach?
  • gsa8316 Sep 22, 2008
    I am having a great deal of problem getting reception. If I hold the radio and turn it a certain direction, I can get reception. As soon as I set it down, I loose reception. If I choose just any station that will come in, it fades as I walk away. Adjusting the location of the power cord does not do any good
  • pam124 May 19, 2009
    My mom has the same problem - can't get any AM stations and only a few FM stations from her room (it's by a window too!). Is there an external antenna we can use?
    President:
  • 814 Answers
You will need to buy a signal amplifier antenna. One that doe not have to be connected to the radio. It will provide the amplified signal and the radio antenna (the a/c line cord and the back of the clock/radio) will be able to pick up the signal from the amplified antenna.[http://www.radiolabs.com/products/antennas/am-antenna.php] this web link will show you one type of these antenna's. Copy the web link and paste it into the address bar in your browser. It will take you to the website. There maybe other types of these antenna's but this one had the best price. Call the store and talk to them before you buy the antenna to make sure it will work in your situation. I hope this information helps you with your antenna problems.
Posted on Jun 12, 2009
  • 4 Answers
You need a 5.8ghz antenna. 5.8 ghz is about twice the frequency of 2.4 ghz, and conversely half the wave length.
Thus for a similar physical size antenna, you can have to twice the number of elements in a 5.8 ghz antenna, giving you a 3 dB improvement.
But 16 dBi is 5 dB more than 11 dBi, so what gives? Well, it's the particular electrical design that can have a difference.
Posted on May 30, 2012
Have sirius and hands free phone features with sirius antennae. I do not get good signals from local FM or AM Radio stations. Why?
Sirius is a satellite biased service , so it uses a satellite antenna , local stations how ever don't use that antenna and use a dipole antenna , are both type antenna's connected to your radio , lots of installers don't bother to connect local antenna to new radio installs , im mean you got Sirius why'd you want local stuff anyway is there thinking
Oct 20, 2015 | Kenwood Car Audio & Video
Only 2 FM stations working. I have an Insignia Stereo receiver. At first, we could get all of the FM stations, then all of a sudden we can only get two. The antenna has not been moved from where it or
If you have an external antenna, check you antenna connections.
Weather can change your reception. Are the stations you can hear local? within 30 miles? Or is there an amplifier on your antenna system? It may have quit functioning. if you have cable TV you might want to hook up your stereo to that system, you will need a 75 to 300ohm adapter that you can pick up from an electronics store or online.
(coax to twin lead)
Sep 27, 2014 | Audio Players & Recorders
Rca rt 2770 programming. My fm radio stations
You can manually program a station by pressing AM/FM to get to the correct radio band. Then tune in a station with the Tuner +/- (the left/right arrow) buttons on the remote. Next press Memory (just below 7) and then a number on the keypad. The number must be entered before the Program Preset number stops blinking. (For FM you can use some 2 digit numbers.) To scan through the stations in memory use the Channel +/- buttons on the remote or the Next/Previous track buttons on the RT2770. You could fill all of the memory slots automatically by pressing and holding the AM/FM button for two seconds. The unit will store the stations that it tunes in in order until the memory slots are full. Note: you do need to have the FM antenna and AM loop antenna connected (and extended for the FM antenna).
Retrevo has the manual for the RCA RT2770 available here: http://www.retrevo.com/support/RCA-RT2770-Home-Theater-Systems-manual/id/2869dj191/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Apr 30, 2014 | Audio Players & Recorders
My str de 925 will no lock on a radio station
Insure that the antenna is connected securely on their respective antenna
input, Stations will not lock , if the signal is low.
For FM :
• Wire antenna is applicable if your distance to the nearest FM
is about a km or less, other wise use a VHF TV antenna.
for AM :
• These antenna is directional, you may need to extend the wires
so as to receive AM stations.
Jul 31, 2012 | Sony STR-DE925
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
Can't seem to tune many stations at all. Also once a station is tunned it "slips".
The antenna works with the power cord. Try extending the length of its power cord with an extension cord.
Position of the radio in the room, the furniture in the room and your position in relation to the radio all affect its reception.
If there is a place to connect an external antenna, this will be helpful. Check with Radio shack and best buy for a FM loop antenna. Usually the wire is flat.
An inexpensive antenna for FM only is also a cheap alternative
Jan 03, 2011 | Tivoli Model Three Clock Radio
Cd and dvd work but no radio station
When you switch to Radio AM/FM, are you having trouble tuning into a radio station? If so, make sure the antenna cable is connected properly and that it is the right type. Some car antennas differ from stereo manufacturers so if yours differ, you will have to get an adapter. This website has an extensive range of antenna adapters. If it is outside of your country, then use it only as a guide to finding the correct adapter for your needs, then you can search locally for a supplier.
Dec 03, 2010 | XO Vision DHXO1911 Car Video Player
Connect sirius fm adapter to 2008 honda civic sedan radio
You should use the direct FM box to get the static to go away. You unplug the antenna from the radio, plug the antenna lead from the box into the radio, the antenna line plugs into the box. You will have a mini jack that plugs into your radio or dock.
This way you can switch it on any station to get rid of the static.
You shouldn't need to take the dashboard out to get to the radio. Usually you have to take the trim pieces in front of the radio to get the antenna line out.
Sometime you can reach it from the back of the radio if there is enough clearance to get cak there.
Jun 12, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
I have a sansui receiver 9900z with a broken antena,I think. The broken part was connected to the rear near the antena connectors. I am not sure if this is suppose to ba a antena or not? The set plays well...
The back of the receiver should be marked for FM and AM antenna connections.
Usually the FM antenna needs at least a dipole antenna or a "T" antenna. The part that broke off is probably just the AM antenna.
If you go to your local Radio Shack, you can get a cheap AM/FM antenna for under 20.00. (probably under 10.00)
After hooking up an antenna, you should be good to go.
I hope this helps.
Good luck.
Please remember to leave a rating if I have helped you with your question.
Mac =)
Mar 30, 2008 | Audio Players & Recorders
Emerson Smartset Clock Radio Logo
644 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
