Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52w20 question
Hey Overflow. What it does is that the green light comes on for 10 seconds then goes out and stays out. During this time it sounds like something like the tubes in the front of the set are warming up. I also checked the fuse on the power board and I checked the output voltage on the two wires that go to the board that houses the flyback trans. I was getting 24 volts a.c. output.? I don't know what it is supposed to be.
Thats all I get
If you can help please e-mail me back directly at michampagny @hotmail.com
Thank you very much for any help you can provide
Mike
  • RCA Master
  • 5,138 Answers
Check 3 capacitors on FBT board 2200uf 16v and two 220uf 35v replace all of them,also CK all ribbon connectors and plug ins on board they can be defective also make sure second ribbon connector is in right on FBT board this will keep it from coming on also.
Posted on Sep 15, 2008
I have a sony tv model kdf-50e2000,and it has a problem with the picture going blank,the only light that on or flashes is the green (POWER) light. when turning the set on the green light blinks as it...
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Dec 28, 2010 | Sony KDF-50E2000 50" HDTV
Screen stays black green light comes on for a few seconds.
This sounds like you have "bricked" your psp... there are a few things that can cause this: first would be that you have bricked it trying to install Custom Firmware, another would be that the battery died or it was shut off during an update. You can buy what is called a Pandora Battery and a "magic" memory stick which will reset your PSPs firmware to the original 1.5, or if you still have warranty you can send it in to Sony to get fixed. Pandora batteries and Magic Memory Sticks are sold in a package for about $10-15 on the internet. Good Luck, hope you fix it.
Please Rate, thanks!
Jan 16, 2010 | Sony PlayStation Portable (PSP) Console
RCA d52w20 will not come on
sounds likje the flyback those sets are famous for the flybacks needing replacement.They dont always blink 3 times when the flyback fails, often they justrefuse to power up.
Sep 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wont turn on
there may be a short in the system. Bad news: You should have a licensed pro help you diagnose it and fix it. Good news: its fixable.
Aug 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca hdtv
Hey Lady Winn:
I tried the capacitors but nothing. It still does the same thing. The green light comes on and stays on for 10 seconds then goes out.
What would you try next?
Thanks Mike
May 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't stay on!
Check C506 = high failure item # 483512247584 680pf / 2kv
Dec 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCD 52W20 with no green...
Re-check hook up on focus/screen adjust assembly.Adjust RGB screen controls.All green/ no control can be bad green CRT==check w/CRT checker.CRT OK/==diagnosis required.Green video drive circuit??
Jul 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
