Sony trinitron flickering
Takes a long time to warm up. once warm, keeps flickering from completely black to picture and back again
  • Anonymous Oct 21, 2008
    I have a 22" sony trinitron. It turns on black for a while, then flickers from black to picture. eventually like 5-10minutes perfect picture
Sony Trinitron it 36 fiickering
Posted on Sep 25, 2008
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony kv36fs76u
hi there, your set has a capacitor problem, most of it are on the horizontal section and video section., usually 100 microfarad electrolytic capacitor with a high voltage is damage. try to test some parts. ty
Dec 02, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV sometimes flickers to black
just check ur tv settings,with user manuals,check close caption it must be turn off,check antenna or catv lead for loose connection. i hope i help u?
May 07, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Televison & Video Logo
266 people viewed this question
Top Televison & Video Experts
Electro Med Services...
