USB connection on a P6VXA motherboard.
I want to connect an internal memory card reader (Mitsumi FA404M, powered via the USB cable) on my PC, which has a P6VXA motherboard. Therefore, I would like to connect it to the USB connection on the motherboard. The only problem is I don't know on which four (of the five) pins, available in either row, that I should connect to (there is nothing on the board identifying any of the pins). Any help with this would be greatly appreciated. Thanks!
  • 624 Answers
SOURCE: motherboard
Are you trying to install the Dell Media Card Reader? If so then the other end of the ?FlexBay USB cable that plugs into the card reader goes into a small rectangular connector towards the back of the motherboard. Specifically orient as follows; place the computer on its side, the power supply to your left and the front of the computer facing towards you. Starting at the back of the motherboard next to the power supply follow the back edge of the motherboard till you come to the approximate center of the board. About an inch towards you there will be a rectangular connector the FlexBay USB cable end should fit into. If this isn?t the cable from the Dell Media Card Reader let us know and we?ll try to help, otherwise please don?t forget to rate this posting.
Posted on Feb 11, 2007
  • 624 Answers
SOURCE: motherboard
All of the internal card readers I've seen either: -have built-in media converters which in turn plug into standard connections (USB, Firewire, ect.). -have their own PCI card with an appropriate connector for your card reader. That card plugs into your motherboard. Is it possible you card reader is missing something or perhaps was designed for some other motherboard?
Posted on Feb 15, 2007
  • 2961 Answers
SOURCE: T2893 Motherboard Layout - Where do the power jumpers go?
go to this link for the information you need
Posted on May 06, 2007
  • 59 Answers
SOURCE: Dell Dimension 9100 PC Desktop problem
I'm not sure where the floppy drive comes in, but if you have usb connectors on your mobo then you can connect the 5 pin connector to half of the usb pins.  Try that and see what happens.
Posted on Oct 26, 2007
SOURCE: FA404M installation
The internal USB cord is made for the memory cards, install the floppy ribbon for the floppy disk. Don't forget to attach the power also.
Posted on Nov 28, 2007
I'm trying to upload my pictures from my DXG-587V to my computer but every time I plug it into the computer, my camera shuts off and I can't get my computer to pull it up. Any suggestions??
Hi Beth,
The best i can suggest you is.. Turn off the Camera before you connect the USB Cable..
Try a different USB port on your PC to connect the Cable and once you have connected the Cable, Power on the Camera, it should work.
Nov 14, 2011 | Cameras
Hi i have a panasonic dmc fs7 but i cant find the cable to connect it to the pc, is there anyway to do it wirelessly?
No.The only way you can connect your camera to a computer is via usb connection cable (supplied) .Remove the card from the camera,then insert it into the card reader on your computer ..Be sure the memory card for your camera is compatible with your card reader.
Jul 31, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Usb driver
on motorola cells usb problems are very often... i suggest you to buy a thing called card reader. card reader is very small (2x1) device; you put your cells memory card into it and connetc the reader to your computer. it's like usb, but just you transfer your files directly to your memory card.
Apr 07, 2010 | Motorola Mobility RAZR V3m Cellular Phone
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
Mitsumi 7 in 1 card reader
There are two cnnections required on the back of the card reader.
One is for the Floppy drive. It is flat and wide cable.
The other is a black cable with a smaller connector. This is a USB connector that needs to be plugged into your motherboard.
These USB connections are usually near the bottom right of the motherboard where you connect the power switch and LED lights. They usually have 9 pins. See this link and loko at the third picture so see what i'm talking about.
If you don't have a USB connector on the motherboard.. you'll need to purchase an extension card or an adapter that will plug into a usb outlet on the front of back of your computer.
Best wishes...
Dec 08, 2008 | Mitsumi (FA404MBLACK) (fa404m/black)...
Mitsumi FA4o4M Combo Floppy Card and Data card reader/writer
black cable to be connected on a free usb outlet on the motherboard
Feb 02, 2008 | Mitsumi (FA404MBLACK) (fa404m/black)...
15-in-1 internal memory card reader
you should connect it by the scheme VCC | Data - | Data + | Ground.
In most motherboards you have connector something like this
By this scheme the first one is vcc and then by the scheme
i`ve attached.
If you can, show please screenshots of your connector on card reader!
Jan 23, 2008 | HP Pavilion dv6000z Notebook
FA404M installation
Sep 01, 2007 | Mitsumi (FA404MBLACK) (fa404m/black)...
Hi You can`t install applications on the memory card,you have to install it only on your phone memory. Good Luck
Aug 23, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
