The head fell off my wife's tripod. The female thread broke into two parts and even though glued with metal weld continues to fail. It looks like this female thread screws out. Parts anywhere ??
Telescopes and other things designed to fit on a tripod usually have a female thread and the attaching screw is part of the tripod.
If there is no female thread it isn't designed to fit on a tripod and an adaptor will be required. If it is available it will have to be sourced from the manufacturer or an optic specialist.
If it was mine I would have a brief look through Amazon/ebay and if no luck I would fabricate something myself.
Look at it closely to make sure it is not a nipple threaded into the pump that can be removed and replaced. If it is indeed part of the pump you may be out of luck. You can take it to a competent welder that may be able to weld it but it may distort the pump body so it will not work. Good luck!
Available replacement parts for Sunpack tripods are pretty much limited to new heads, mounting plates, or carry cases; take a look at what B&H Photo has to offer. You don't say what specific tripod you have, but I'd suggest a search at eBay where several are available at auction right now. Furthermore, a check of completed auction/sales shows both new and lightly used ones sold in the past month for between $10 to $50. Buy one for parts or use it as is. You won't find any part plus shipping for less than that.
Sunpack makes consumer not pro level tripods even though the term Pro may appear in some product names. When you buy a tripod that costs $400 and up without the head, you get more options for replacement parts. I have a Sunpack myself for lightest duty when hiking, but my main tripod is a Manfrotto with the grip head. The huge difference in cost makes a corresponding difference in what parts I can find online. When my Sunpack broke (in a different way than yours but equally unusable) I used gaffer's tape to hold it together until I could find a new one (on eBay for $15).
Here is a link to your products parts site. If you are unable to locate the part there, you can contact them directly by clicking calling 1-800-888-0127
Not quite sure what you are hoping to achieve here - the bubble is to help you level the tripod, and by its very nature when centred will indicate this. Once you have levelled the tripod, adjust the head (pan and tilt, or ball and socket) until the camera is also level. It is possible to purchase a three-way level that fits in the hot shoe.
The bottom threads on most tripod heafs are 3/8", but some are 1/4"/ The mounting screws on MOST tripods are 3/8", but I have seen `/4" (especially on monopods. IF:
tripod=3/8 head = 1/4 need mounting plate 3/8 female to 1/4 male
tripod = 1/4 head - 1/4 nothing
tripod 3/8 head 3/8 nothing'
tripod 1/4 head = 3/8 there is an adapter/reducer that screws into the 3/8
' female and reduces that to 1/4"
Below the tripod head you will see what looks like a "sandwich" of two chromed pieces of metal. The lower one is the top of the tripod's center column. The upper one is the bottom of the tripod head. Using wrenches or other tools, unscrew the upper one counterclockwise to separate it from the lower one. There is a 1/4" threaded stud which holds them together.
If you plan on replacing the head with a pro head like a Manfrotto, you will need a reducing bushing. Most heads expect a 3/8" stud, and this tripod's thread is a standard 1/4" stud. The adapters are available through Wolf, Adorama, B&H, and the like.
