Question about GE Energy Star WCVH6260F Front Load Washer
GE Front load washer WCHVH 6260F
Started to wash a load of clothes the washer paused as usual but the start/pause button is now flashing and the washer has stopped. Can not get it to continue the wash cycle and of course the door is locked.
  • nessabro Feb 01, 2009
    the washer will start a load and get from 59 min to 47 and then the start stop button starts flashing. initialy i hit the button until the wash cycled completed itself but i had to keep pressing the button through out and the clothes didn't wash and they didn't spin very well. i have checked the filter at the front of the washer and found a few items that i assumed must have been what the problem was. i have just loaded the washer up with excitement only to find that the same issue is re-occuring. eep!
  • stedakadan4 Apr 18, 2009
    Our washer won't start. The stop/pause button is blinking. We cleaned the filter (found a sock, coins and lint). It did not solve the problem. Any other solutions?
I had the same problem.....The start/pause button would flash during a cycle and the washer would not finish the cycle. After reading on this forum that there is a filter/strainer inline with the drain, I tried this solution.
Remove the (3) screws that hold the lower front panel (Just below the door)
Once the panel is removed, you should see a white plastic strainer hooked to the washer drain.
Please a large bowl under the opening and unscrew the knob/handle, pull the filter/strainer out and clean all of the lint/trash out of this area.
My filter/strainer was clogged with a baby sock, 2 doilies, a fewe pennies, 2 dimes and lot's of lint.
I believe all of this debris was causing musty odors in the machine as the lint would stink due to dampness.
Once I cleared out this filter/strainer the problem and my odors went away
I wish GE would add this "EASY" step into the owners manual for proper care and maintenace.
Thank you for letting me know about this filter/strainer as it did resolve my problem
Posted on Jan 26, 2009
Hi I am curious if you got a solution I have cleaned th filter as you did only to have it re-occur a week later..Any ideas what to do next?
Posted on Mar 25, 2010
I had the same problem... pausing mid-cycle, sit and hum but not spin (I am assuming it was waiting for the water to drain). Cleaned my trap, and found no end of my children's "treasures".
This seems to have solved the problem, I hope this and bleach eventually helps with the mildew problem too.
Posted on Sep 13, 2009
I have the same problem. I found an string(slip) in the filter. The filter is back to the front pannel under the door. Open the plug and chek the filter.
Posted on Oct 02, 2008
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
Washers start button will only flash as in pause in stead start washing ? I unplugged wash to reset computer and still flashing in pause mode ? What's the next step in troubleshooting thanks nicole k in...
You need to get the diagnostic info. It should be located just inside the kickplate. Unplug the washer, and then remove the kickplate. Inside will be a packet of info that will help you diagnose your washing machine.
Nov 21, 2010 | GE WSXH208A Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Ge washer wcvh6260 ...... start/pause button flashes, won't start
Does the 'door locked' light come on? If not, check the switch and it's actuator (a pin that is part of the door latch).
Aug 22, 2009 | GE WCVH6260F Front Load Washer
The door is locked on my front loader washer.
PUSH THE START PAUSE BUTTON, AND CLEAN THE LINT TRAP AT THE BOTTOM OF THE UNIT
ROB
Apr 14, 2009 | GE WPXH214A Front Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
648 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
