Question about Kitchen Ranges
Burners won't turn on
I was boiling some water the other night and the burner turned off, and wn't come back on, any of them. STARTED W/ A BAD SWITCH. OPENED UP TO GET PART # PUT BACK TOGETHER& NO BURRNERS OR OVEN, WORKS AT ALL. MAKES A BEEPING SOUND WHEN KNOBS ARE TURNED ON AND CLOCK ONLY COMES ON WHEN KNOBS ARE TURNED ON. REPLACED SWITCH . + CLOCK. STILL DES THE SAME THING. CAN IT BE THE BREAKER? MODEL 790.95329302 KENMORE
  • 11 more comments
  • jtjoefixit Sep 13, 2008
    ITS ELECTRIC RANGE.
    would the clock and buzzing sound be there if the breaker is bad?
    how can all elaments go up all at once just by changing one switch that shorted out ?
    your not reading my problem right.your not helping me. what can cause my range to do the things it did and why would a bad switch that has been replaced cause every element not to work and whats up w/ the buzzing sound. i need a tech. to call me.
    how to check if i have enough electric to my range.
    i do have the manual.
    i do have manual
    no.
    i got a volt meter & its getting 240 out of the outlet
    the clock & the element light is the only stuff that comes on when the knobs are turned on.at the same time theres a buzzer that soundswhen turned.
    i have checked
  • jtjoefixit Sep 16, 2008
    im. a fix it guy but not stoves i thought some body has had the same problem like i had read at the beginning so i gave you my credit card # to get the lady that had the same problem. what fit it. and i guessed just like you guys did . i did more trouble shooting then what i got in return. sorry i waisted my time. have a great day.!!!!!!!
    chefs?????? whats that mean. it means i new more of what my stove was doing than you asemmmmmmmmmmmmmmmmmmmmmmmmm.no thak you.
  • 2,071 Answers
Just click below;
http://www.acmehowto.com/howto/appliance/range/electric/check/heating-element.php
Hopes it may help;
Regards,
VOTIT
Posted on Sep 13, 2008
  • 750 Answers
Jtjoefixi,
So far everything the guys and girls here at fixya.com have told you are good ideas.
But my advice after reading everyones comments is you have to many chefs.
And come Monday morning you need to call one of sponsored service companies and get it fixed the right way!
There is no hands on service here and I am sure so many answers here are getting you confused.
If you were my kid and across the country far away, I would tell you to used find a service company and be done with it!
fixya.com has some good sponsors that can service you!
Bless You,
    President:
  • 624 Answers
Most electric ranges operate with 220 volts. This is supplied from two 110 volt sources. It is possible that you are only getting half of the needed voltage, since some things work and others do not. Check your circuit breakers or fuses, which ever your home is equipped with. This may solve your problem.
Dave
    Brigadier General:
  • 5,158 Answers
If the clock works there is power to the range.... i'm uncertain if you do have the manual for that stove. if not i will do further research
Robert
  • Roberta Smith
    Roberta Smith Sep 13, 2008
    I'm having trouble looking up the model number you have supplied. be that as it may... is it a digital display or the old fashioned analog display.... i realize the issue is the stove going on but there is a possiblity that stove uses a timer control to shut off the burners after a certain period of time.... safety idea.
    Robert
  • Roberta Smith
    One other thing to explore... there is a panel... either on the top... lifts up... or at the base under the controls for the stove... you often have to remove to screws or bolts to gain access to it. there are a row of fuses there. one for each burner and a main fuse. even if that main fuse blows the clock may very well work.
    Robert
    Genius:
  • 3,422 Answers
HI,
You are correct the first thing to heck is the circuit breakers for the electric range. They both should be on.
  • 5 more comments
  • Priya darshan Sep 13, 2008
    check*
    Also d check the power from the outlet or the junction box, if it's hardwired.
    Next I would recommend to pull the range off the wall and check all wires and connections, starting from the power cord.
    Heating
    elements eventually burn out. Sometimes, when an element burns out, you
    can see that the coil burns in two, or blisters and bubbles.
    When
    your heating element burns out, you have to replace it because they are
    not repairable. If, when the heating element burns out, the infinite
    switch that controls it also fails, you have to replace it too. Also
    see the "A burner works only intermittently" section, next.
    If
    one of your burner heating elements works only intermittently, it's
    probably because of worn or bad contacts in the receptacle that the
    element plugs into. On most electric ranges, you can remove the element
    by lifting it up several inches and firmly pulling it away from its
    attachment (receptacle). Read your owner's manual to learn the correct
    technique for your range.
    If, after removing the element, you
    see that the ends of the element that were plugged in are pitted,
    corroded, burned, scarred, or rusted, replace both the element and the
    receptacle.
    Please click on the below link and all your doubts will be cleared:
    http://www.rd.com/familyhandyman/content...
    If you need anymore help let me know before you rate the solution.And if you are satisfied with my solution please don't forget to accept it as fixya.
    Also check out the below link:
    http://home.howstuffworks.com/how-to-rep...
    And also let me know if you hear a click noise?
    Genius:
  • 1,239 Answers
Hi
Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1:
 Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
  • 4 more comments
  • ABHISHEK.C
    ABHISHEK.C Sep 13, 2008
    hi
    If the oven won't heat to the desired temperature or heats unevenly, the problem could be a defective door gasket. The best way to test for this is to pass your hand around the door, being careful not to touch it, while the oven is turned on. If you can feel heat escaping, the gasket needs replacement. Replace it with a new gasket made for the range.
    On most ovens, the gasket is located on the frame of the oven, and the door closes against it. This gasket is generally friction-fit in a channel and can be replaced. In other units, the oven door has two sections, and the gasket is not mounted on the door frame, but is installed between the front and back sections of the door. Don't try to replace this type of gasket; call a professional service person. Here's how to replace a frame-mounted gasket:
    Step 1: Pull the old gasket out of the channel. On some oven door frames the gasket is held in place with screws. To get at the screws, bend back the exposed edge of the gasket.
    Step 2: Clean the channel and the door frame with a solution of mild household detergent and water.
    Step 3: To install the new gasket, start the replacement at the top of the door frame and work down the sides, easing the gasket around corners. Finish the installation along the bottom, butting the ends of the gasket firmly together.
  • ABHISHEK.C
    hi ihave a last solution
    The flame of gas range burners should be steady and slightly rounded, with a light-blue tip. The flame should be quiet and should respond to adjustments made at the control knobs. Most burner troubles can be quickly solved by adjusting the air shutter mixer plate, which is located at the end of the burner tube near the knob controls. Turn a small screw on the plate, slide the plate open or closed, and tighten the setscrew.
    If the flame is yellow, it's not receiving enough air. To allow more air in, open the plate slightly. If the flame is high or makes a roaring noise, it's getting too much air and you should close the plate slightly.
    ©2006 Publications International, Ltd.
    The flame of a gas range burner should be steady and slightly rounded, with a
    light-blue tip. To adjust the flame, slide the air shutter mixer plate open or closed.
  • ABHISHEK.C
    hi do you have mltimeters or voltmeter to check voltage...................
  • ABHISHEK.C
    ok.......................sorry then contact technician.please rate it
  • ABHISHEK.C
    hi there is full details in www.how stuff works.com
  • ABHISHEK.C
    i think it is timer problem.........service it
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
Apr 07, 2015 | Kenmore Kitchen Ranges
I had a pot of water boil over and the stove top turned off. How do I turn it back on ?
Probably just got too wet in the burner or igniter. Give it a day to dry on its own or light it with a match to dry it with its own heat.
Dec 29, 2014 | Kitchen Ranges
Why do burners not get hot? After rehooking to electrical power, due to a remodel, the burners don't seem to heat up as hot as they used to. Cant boil water on any of the 4 burners.
Could be not enough voltage on your 220.lines ( one wire lose or a bad breaker. or the wires are hooked up wrung causing it to try to operate on 110 instead of 220
Aug 17, 2014 | Kenmore Electric Smooth Top Stove
Hello My gemini top burners cycle on and off,
The burners are designed to cycle on and off, it is technology that helps to keep from burning food. If you are using the correct pan to burner size ratio and high setting on your burner, the water should boil in the normal time. Don't watch the pot (just kidding)
Nov 30, 2009 | Maytag Gemini 30" Self-Cleaning...
Clicking sound on my gas stove
there switches behind each knob, 1 of them is broken,or wet, when you remove the knobs then remove the knob panel you can test them and find the bad one,they are no more then $15.00 each. to test you can plug the stove and disconect the switches one at a time until you find the bad one replace and you are back in bussines.
Dec 11, 2008 | Maytag MGR5770 Gas Kitchen Range
Kenmore gas range
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Nov 06, 2008 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Electric starter for Electric stove
I think you mean you have a gas range with electric ignition. When you turn a burner to light, all burners should spark. The most common problem is boil overs have happened on those two burners. Take the burner head off for sealed burner ranges and clean them out. For non sealed burners, the little holes toward the center side of the burners need to be cleaned. You don't have a model listed, so I can't be real specific.
Aug 15, 2008 | GE Spectra JBP78 Electric Kitchen Range
2 burners work, 2 don't
ok, first check that the ranges are seated properly , clean the connectors , do a test , if it still doing the same problem , then you need to replace the modules of each range thats not working,in this case 2 modules.
Nov 15, 2007 | Kenmore 96213 Electric Kitchen Range
Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Aug 09, 2007 | Frigidaire FES367 Electric Kitchen Range
Kitchen Ranges Logo
93 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
