Question about Logitech QuickCam 961464-0403 Webcam
Uninstalling software When I use the add/remove feature the software for webcam will not go away, I no longer have the webcam or installation cd. I think the driver for the Logitech webcam I had is interfering with my new webcam
  • Logitech Master
  • 13,433 Answers
Try revouninstaller.
http://www.revouninstaller.com/
It is very highly unlikely that your old driver would be interfering with the new driver.
You can get logitech webcam drivers from
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=gb,en
Posted on May 20, 2009
I can't uninstall Logitech webcam software 2.0 from the control panel, I push remove,& it just reverts back to0 the same screen
Many devoces have their own uninstall program. Push Start, then all programs, and look for Logitech, Webcam, and see if it has a program in the folder called "uninstall Logitech" or something to that effect.
Also, if you are upgrading to a different Logitech webcam software, the program might uninstall the 2.0 as a process of installation.
Jun 10, 2012 | Logitech Computers & Internet
Voice call and video call in yahoo messenjer not appear . i changed setting but not work
First, update your system:
>Install the latest version of Yahoo! Messenger.
>Microsoft has released updates for DirectX and Internet Explorer. Please download and install the following software updates: 1.DirectX Runtime 2.Internet Explorer 3.Microsoft Windows Update (Please make sure to open this link in Internet Explorer)
>Uninstall and reinstall your webcam software: 1.On your keyboard, hold down the Windows key and press the R key. This opens the "Run" command. 2.Type in appwiz.cpl and click OK. This will open Add or Remove Programs or Programs and Features. 3.Select the webcam software and click Remove or Uninstall. 4.Unplug your webcam. 5.Restart your computer. 6.Visit the webcam manufacturer's website to download and install the latest driver software. Follow the instructions described by the webcam setup program, and plug in your webcam only when prompted.
>Run the Video and Voice Setup assistant to test your webcam.
Additional Notes: >Most webcam manufacturers maintain the latest webcam software drivers on the download or support areas of their website. >Plug in your webcam USB cord only when prompted.
Feb 27, 2011 | Yahoo Messenger
Havimg trouble with webcam
if its xp computer then go to control pannel//add and remove prog// right click on webcam s/w installed and uninstall it// restartthe computer and reinstall the s/w if u have the s/w cd//
May 06, 2010 | Computers & Internet
Loct installation CD, need to uninstall. Can this
Broderbund software is often lousy to uninstall, leaving bits and pieces behind, including often registry keys no longer needed.
I would try it through the Add/remove programs function in the control panel as long as you have the restore routine keeping a backup of your system in case the removal takes something away with it that you need. It doesn't take long to get a system back to where it once was.
Nov 04, 2009 | Broderbund PrintMaster Gold 16 for PC
How to fix my web cam
hi..
The very first step is of course to check your webcam connection.Most webcams use the USB port to connect to the PC, so check if yourUSB cable is properly plugged. For build-in webcams this steps does ofcourse not apply. Many new laptops have a build-in webcam. Also tryconnecting your webcam directly to your PC instead of through a USB hub(if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but theright drivers are not installed. The yellow explanation mark willindicate a problem.
If the device is not recognized in Windows XP, it will be listed under Other Devices.
In either case you can try to update the drivers. Right-click the device, and in the popup menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the webcam can be found, you can try a third party driver scanning program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to uninstall the software that came with your webcam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party uninstaller.
After uninstalling the software, restart your PC and then reinstallthe webcam software. In most cases this will solve the problems.Depending on the software, you might need to unplug your webcam duringthe software installation.
If the drivers and webcam software are correctly installed, and youstill cannot see any video, there can be a problem with the programsettings. Most chat and meeting software have a configuration option toselect the video source for the webcam feature. If you have multipledevices that qualify for video, you might need to select your webcamdevice as the source for the webcam feature in that program.
Some webcams and programs require additional software, although thatshould be installed with the webcam if things are right. But is doesnot harm to check if your Java, Flash and Quicktime software are installed and up to date.
Lastly, if your webcam’s image is not sharp, check to see if it hasa focus ring. A blurry image can sometimes simply mean the webcam isnot in focus. Adjusting the focus through the ring can solve thatproblem....
thank u
rate me!!!
Jul 14, 2009 | Computers & Internet
Webcam software
before installng the driver you must first remove it by uninstalling the previous driver from your machine. To do that, go to control panel, click the webcam software that you use then click uninstall. after uninstalling put the cd to the dvd rom drive then, run it, then install it.
Apr 05, 2009 | Dell Inspiron 1525 Laptop
I want to remove genuine microsoft software from my computer
i want to remove genuine microsoft software from my cumputer'''but genuine microsoft software is not installed to my program..
Mar 20, 2009 | Microsoft Office Professional 2007 Full...
No icon of webcam appears.
u just go to add and remove option check that webcam drivers installed properly or not
take achancr uninstall it and install again from driver cd or dvd
hope u will get webcam icon
Mar 05, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
I cant instal web camera in messenger
hi,
First, make sure you follow the instructions from your camera manufacturer to ensure the proper installation of your camera.
This involves inserting the camera installation CD, being guided through a few steps for installation, and restarting your computer. Plugging in the camera's USB cord at the incorrect time during the camera software installation procedure can cause various problems.
To reinstall your webcam:
Uninstall any existing camera installations. Click "Start," "Settings," "Control Panel," and "Add/Remove Programs." From the list, choose your webcam software and click Remove.
Unplug the camera's USB cord from the computer.
Reboot your computer.
Insert your camera's setup/installation CD.
Follow the instructions described by the camera setup program, and plug in your camera only when prompted. This is usually done after restarting your computer.
thanks,
P.S. rate our answers properly.
Feb 19, 2009 | Logitech Quickcam IM 961361-0403 Webcam
MICROSOFT LIFECAM VX 6000 FAILED
If you have got the istallation CD for the Cam. You need to uninstall and reinstall the software .
1.Go to control panel , add remove programs , and select the software for the cam and click remove.
2. Make sure you disconnect the cam when you are uinstalling the software and then restart your computer
3.Plug back the cam and redo the software it should fix the issue
Thanks
Mandeep
May 07, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Logitech QuickCam 961464-0403 Webcam Logo
60 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
