Tune in sky remote code for sanyo ce26ld81-b/uk tv
Emsy32
  • 3 Answers
SOURCE: Sky remote handset will not operate mute. volume etc.
Go to interactive
Select Number 5
Then select the remote option (5) You will then get a list of tv models with codes, follow the directions on screeen
Posted on Jan 06, 2008
SOURCE: Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
Posted on May 20, 2008
rathkenny
SOURCE: DOES ANYONE KNOW THE SKY
Google "sky handset codes" and you'll get lots of answers. For example, page
http://www.satcure.co.uk/tech/digicode2.htm
Has a huge table of codes for many manufacturers. A quick search for SANYO on this page gives 3 hits.
One for 3 specific products sent in by the public.
One for the earlier series handsets which offers 0159 as the primary Sanyo code and the following to try if this fails
236,073,100,064,174,185,367,039,245,246,398,241
For Rev 4 digibox remotes and later they offer the following selection:
236 073 100 064 174 165 367 039 245 246 572 583 037 132 182 244 191 398 241
I'm guessing that they are in descending order of popularity.
Failing that why not go directly to the Sky web site where they tell you step-by-step how to do it and have a tool that will give you the correct code.
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
Not knowing the revision of your handset (4, 6 or 8) I can't say what codes to try, but they all list 236 as the first one, just like the first web site I mentioned.
Posted on Dec 06, 2008
SOURCE: setting up 42lg3000 with sky
i have same tv, this i was i did on mine. on the sky+ remote push tv and then press select + red button at the same time, the red light blinks twice, then push 1174 then power button.
Posted on Jan 07, 2009
SOURCE: Unable to tune my Sky Remote to my tv
panasonic 37in can't pair sky remote with tv
Posted on Feb 16, 2009
Can you tell me the code for a veitech tv . I cannot find the code to programme the remote hope you can help ?
can you till the code 4 veltech tv two operate sky remote
www.justanswer.co.uk > TV
Question - can you till the code 4 veltech tv two operate sky remote - 2H. ... if you will rate me in a positive fashion before you close this page, the system will ...
Sky Digibox TV remote control codes for your television
www.satcure.co.uk/tech/digicode1.htm
Jump to How to get inside remote - If you warm the remote with a hair dryer, the plastic becomes more ... Please tell me if the link no longer works.
Jan 20, 2016 | Televison & Video
I need a code for my sky remote for my sanyo tv in order to get the volume working It is a sanyo 32" Model CE32LD33-B-01
with the tv on and sky off, press red button & select together, remote blinks twice.press tv then standby repeat this action until the tv turns off. when it goes off press select. press standby again and tv should start. your sky remote should then work perfect. as a tip with tv on and sky off press tv then back up this should then go to the freeview setup and you can watch those as well for free
Sep 09, 2010 | Sanyo Televison & Video
I have a sanyo fxwk remote...I need codes for my sanyo tv
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
also check the below link -
http://www.skyuser.co.uk/tools/remotecodes/index.php
Good Luck!!
May 23, 2010 | Sanyo DS27930 27" TV
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  2. Press tv on your Sky remote control.
  3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
  4. Press tv on your Sky remote control again.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
  6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Oct 12, 2009 | Sanyo Televison & Video
I am unable to pick up sky and set it to a position on analogue tv settings. The Tv is sanyo ce26ld90b.
If first we could ensure some connections are tight before moving into TV settings.
You have told me that you are using sky over an analogue connection. Make sure that these are plugged in at both ends (sky box and TV) and that your sky box is on.
Now using your TV remote, enter the TV settings (there should be a button for this specifically on your remote), and opt for Tuning and manual tuning. The layout for most TV settings are similar.
By manual tuning, you are able to select the number on which you want to view a channel (in the analogue case, Sky as a whole is considered one channel on your television)
Now you should be able to use the left and right keys on your remote to tune up and down a range of frequencies, one of which Sky will be on. Once you have found this frequency, you should store it to the channel you have selected.
To my mind, the only thing that would then cause this to reset is if you turn off your TV from the mains each time you finish using it.
Aug 23, 2009 | Sanyo Televison & Video
Problems turning up my sky remote on a technika tv
It depends which model of Technika TV you have. Visit here....
http://www.skymediauk.co.uk/oneforall.php
for some of them.
Feb 02, 2009 | One For All URC 7740 Remote Control
Jan 09, 2009 | Televison & Video
Sky Remote code for Sanyo LCD TV
I HAVE FOUND THE CODE AND SKY NEVER HELPED THE CODE IS AS FOLLOWS DEPENDING ON HOW OLD YOURE REMOTE IS 0065 IF YOU HAVE AN OLD REMOTE TAKE THE FIRST ZERO AWAY
Sep 02, 2008 | Televison & Video
May 20, 2008 | Bush WS6671 28" TV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
