Question about Jensen VM9410 Car DVD Player
Poor radio reception
'Is there a way to boost up the frequency of the radio'
    President:
  • 3,130 Answers
You wanna boast up the radio signal?? There are ant. boasters around, But if your far away from a radio station your radio cant make that weak signal any higher in amplitude. All you would be amplifying is noise or static. Sorry
Posted on May 25, 2006
Transmits off frequency
did you put it on a frequency counter? they can be set back on freq. if you know how to set it. how old is it? I would send it back to where I got it and have them fix the problem.
Jan 23, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
CANT GET AM ON MY RADIO. HELP!
AM reception depends on orientation of the radio. Take the radio from its handle (top side up) and rotate it until you find the best signal. If it has Automatic Tuning, take the radio outside, find the best direction and initiate the ATS. Once the stations are recorded in memory, tune to one radio and listen. If that reception is poor rotate the radio without changing the frequency on the dial.
Jul 06, 2012 | Radio Shack "Accurian" Tabletop HD Radio...
Very bad am radio reception, how do i fix?
If it's interference from the high tension wires,you probably need new spark plug wires with good resistor type plugs.
Now,also a bad antenna or a poor match of frequency to the antenna from the rec eiver can cause weak reception.Anyone who knows electronics can match the antenna to the receiver. don-ohio
Sep 14, 2011 | 2005 Dodge Magnum
Emerson rp 6247 radio AM stations does not come in clear
Try moving the telescopic antenna around in different directions until you get a clear reception. If that doesn't work, try moving the whole unit (radio) to another location. Make sure you are using the tuning knob to switch between stations. Moving it to a different location may be the best thing because the radio antenna may be received in frequency waves from another electronic device (i.e. a television set, another radio or in microwave) which is causing a reception to be poor.
Mar 21, 2011 | Emerson RP6247S FM/Weather/AM/TV Radio
When I press Weather/Snooze the radio emitts a high pitch sound like a whistling. I have the radio set to voice, I have verified the channel 162.4750 for my area. I have a scanner tuned to that same...
Solution #1
Some counties have two frequency channels. check this URL address to see if you have another frequency channel for your area- http://www.nws.noaa.gov/nwr/indexnw.htm. If you do, try the other frequency channel for your area.
Solution #2
You may be receiving a poor reception quality because of where the radio is located or the antenna's positioning. First play with the antenna until you get a better reception. If this doesn't help, try moving it to a location near a window or outside room. If this doesn't help, you may have to buy an external antenna from an electronics store and hook it up to your radio. If you still have your WR-100 Owner's Manual, they have a page in there for reception (page 12), and it lists in there their suggested weather radio antenna.
Solution #3
It may not be anything you've done at all. It could be the weather station's transmitter itself. May you should call your local NWS office and plea your case to them.
Sep 13, 2010 | Midland WR-100 Weather/RDS Radio
I have a jc penney car stereo, am/fm cassette (service # 682-0392-00) that has very poor reception at its best. It is not a problem with the antenna, that has been changed and substituted with one from my...
You can purchase a in-line amplifier to boost radio signal, or just buy a new deck for less than $100 and get it installed. Great deals out there for decks below $100 installed. Try Best Buy or Fry's electronics.
Mar 15, 2010 | Car Audio & Video
AM reception
Since there is no AM antenna input on this radio, you will have to get an AM proximity antenna. One that does not need to connect to the radio. At Bose they recommend the Terk AM Advantage proximity antenna. I think you can get it on Audiovox.com.
Jun 17, 2009 | Bose Wave Radio
Poor antenna reception
That's a problem with the digital broadcasting. Signal strength is critical, and the frequencies used are more directional. Some people are finding they get no reception at all. Your antenna may not need to be higher, but aimed in a different direction. Did you have a rotator installed as well? An outside antenna really should be pointed toward the station. You might also be able to add an amplifier to the antenna to boost the signal. But get a mast-mounted version that mounts right at the antenna, not the kind that goes at the TV set.
Apr 09, 2009 | Televison & Video
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
Jensen VM9410 Car DVD Player Logo
246 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
