Question about Pride Sonic 3 Wheel Portable Scooter
Scooter will not charge
Although the power connecter box shows that it is recieving power, the charge light does not go on and the scooter will not charge. We've checked all connections and nothing looks bad, we've checked the fuse, we've pushed the reset button. Any ideas? Of course, we can not find the instruction manual!
  • 650750 Dec 19, 2008
    my uncle's go go will not charge and tried new batteries and a new charger. checked the fuse and also the breaker - both have continuity. contacts are clean and now i'm stumped.
    thanks
  • Anonymous Mar 22, 2014
    Shows power light on charger but charge light stays off. New scooter used very little
I have a 4 wheel scooter .the fan want out of the charger and i replaced the fan but befor i know it want out i smell it so i replaced it and now i charger my batters they say they are chargered but i work it for 10 15 min the meter gos back in the red never did this till after the fan want out can you tell me who i can call to fix or look at my charger i cant afoued a new one THANK YOU PLEASEHELP
Posted on Oct 18, 2008
    New Friend:
  • 38 Answers
Sounds like the gell batterys you can try a battery conditioner it may charge them enough for your charger to work again .if the batterys are not charged or used for a wile the batterys will not let the charger work they should be charged almost all the time
Posted on Oct 11, 2008
    Master:
  • 505 Answers
Check the fuses may have a Blown fuse
Check to see if power supply witch charges the scooter is not faulty
Regards; Aaron
Posted on Sep 16, 2008
When i turn the key on the scooter, nothing happens and nothing lights up, i have checked connection and all show power, the power indicator does not move, yet batterys are fully charged any ideas TIA
hi Shane, i recommend you check the fuses on the tiller ..
if all okay check the fuses located on the battery leads , if fitted and check the connections to the controller which is located under the foot panel..
Regards
Rob
Nov 05, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
DMA SCOOTER WONT MOVE ALTHOUGH BATTERY FULLY CHARGED
Are there any fault codes, flashing light. Check your user manual in the trouble shooting guide.
Have you disconnected charger from scooter as it will not move if it is still connected to scooter.
Apr 18, 2015 | Health & Beauty
My leo mobility scooter charger light shows green as soon as connected to power it remains green when attached to the battery and does not charge
Hi, that could be because it can't see the battery voltage in most cases or at worse the batteries refused to charge, or your charger has called it a day , check the fuse on the scooter as well...
Regards
www.gewizrepairs.co.uk
Oct 06, 2013 | Electric Mobility 4 Wheel Power Electric...
Battery charged power light dead
hi, if that's the model where the rear axle comes away from the frame , check the connections there make sure they are clean and do in fact connect
Regards
GeWiz.
Feb 05, 2013 | Electric Mobility Health & Beauty
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
I have a new Drive Medical Odyssey that will not charge. Several attempts but the yellow "charging light" will not turn green, even after 24 hours. Once I disconnect the charger and turn on the...
soo Have the provider install new batteries. No telling how long the "new" batteries sat on a shelf and in the showroom without being charged. The batteries are warrantied and should be replaced. While you're at have them check out the scooter after the new batteries are installed and remember to charge before use. Hope this helps
Mar 25, 2011 | Drive Medical Odyssey Full Size Scooter
Battery is charged, scooter is assembled, but when the key is turned on, the scooter and all gauges are dead
Has the scooter been sitting unused for a while? Will the horn honk when the scooter is connected to the charger?
If the batteries are charged and NO LIGHTS come on at all when you turn the scooter on, please check all of your connections, most importantly the fuses as your circuit may be incomplete.
If there was any power getting to the scooter at all, the lights would at least blink to let you know there was a problem.
When batteries sit for a while they will oxidize and go solid which may prevent them from getting a full charge. The charger shows them as full but it is just the current bouncing back from the solid core. Try replacing the batteries to see if that solves the problem, if not, contact the manufacturer.
Dec 18, 2010 | Health & Beauty
The scooters won't start although lights and horn workd
mcdevito75 here, Is the battery fully charged, if not, Charge battery, if Charged double check connection at battery and motor.
Jun 24, 2010 | Electric Mobility Mobility Electric Power...
Will not charge (It came with the scooter) it's charged time after time, but has failed. Charger will charge another scooter, but not mine. Shows red light only
then I would first chec kthe connections that the battery charger connects to, check the batteries on another scooter .
Regards
GeWiz
Aug 22, 2009 | Pride Mobility Legend 3 Wheel Electric...
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Dec 07, 2008 | Razor E200/300 Electric Scooter Battery
Pride Sonic 3 Wheel Portable Scooter  Logo
531 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
