Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Microoven did not work's
Hi..  i have the microven.. i did not start .. i have checked the supply card.. is there any solution to solve it. please help..?
    Genius:
  • 1,239 Answers
Hi   the microven work with the voltage of 230-250v 50 z.. if it is not a supply card problem..  u see whether the control panel work are not by pressing start button if it did not not start's mean's it is a circuit board problem.. and at same time there will problem with the fan also.. so, it does't start's.. if it is not in warrenty period .. u could dissamble.. it and chek with a muiltimeter .. by verifying the power board, and conntro board.. dissamble and clean it first.. there may be some minute problem so, that it will not work..  don't forget to vote me..  thank u..
Posted on Sep 14, 2008
Microoven is locked, how do i unlock it?
What is the model number of your unit?
Nov 27, 2012 | Washing Machines
Hi, I have a GF FX 5500 graphics card (AGP) 256M 128B DDR TV/DVI newly acquired. Since I installed it the computer restarts at least once before it had entered password on this computer. With very...
I would check that your power supply is able to handle this card. This card requires a minimum 450 watt power supply. If you take the card out, I would imagine the computer will start fine. Also, verify that you plugged in the power connector into the video card. However, use a volt meter to test your power supply.
Dec 13, 2010 | Nvidia GeForce FX 5500 Video Card Graphic...
Microven doesn't work.
same problem here.
I just unmounted it and checked.
Main things you'd better check (if able, otherwise contact assistance..) :
- UNPLUG POWER
- Unmount, open the top (5 screws)
- microven fuse (open the top, standing in front look right top corner, there's a small circuit with wires and a black plastic case with a 250V 8A fuse in it): check it's ok
- microven transformer: it's the big one on the rear top, you need to check primary and secondary wires for short circuit (that's why the fuse blows up in case)
- magnetron: if both previous ones are ok, check (I can't say how except for getting a new one and trying..) and eventually replace the broken one.
Hope this helps
Sep 29, 2010 | Smeg S201X Electric Single Oven
My samsung microven MD800SC / zam 1100 watts (made in Malaysia) is working but not heating anything. Kindly advise what is the problem.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 26, 2010 | Samsung MD800SC Microwave Oven
Microoven model 860A is not getting heated
Basic Microwave Oven TroubleshootingTips
heatman101p][p[]p
Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
Monitor not recieving signal?
If you are really sure that your monitor is working, then you would probably have to change your graphics card with a working one to see the results. That should solve your problem. If this does not solve your problem, then we are not dealing with a display problem here. In this case, you may have to check your memory.
All the best.
Jan 13, 2010 | EPoX EP-8KRA2+ Motherboard
Setting the time on Sharp microovens.
Normally it's
Clock > time numbers > Clock
or
Clock > time numbers > Start
Sometimes it's
Clock > (1 or 2) > time numbers > Clock
or
Clock > (1 or 2) > time numbers > Start
If this doesn't work, please reply back with your model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 08, 2008 | Microwave Ovens
P4MBMS Motherboard Problem
look for the reset jumper on the board and then reset it then try again
Jun 03, 2007 | Mach Speed P4MBMS Motherboard
NATIONAL NNN -C 2000P LOW VOLTAGE PRIMARY GETS FREQUENTLY OPENED
There is something on the secondary side which is drawing too much current. I would check all electrolytic capacitors, zener diodes, transistors, and voltage regulators.
Mar 27, 2007 | Panasonic NN-C994S Convection/Microwave...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
