Question about Whirlpool Dryers
Dryer that shuts down
My name is Jennifer and my dryer shuts off about halfway thru the cycle--it seems to heat just fine and the lint was cleaned/removed from the internal exhaust line (the top where the lint screen inserts all the way down to the exhaust port at the bottom) and from all areas around the motor and the inside of the dryer shell. So, I'm not exactly sure how dryers work in terms of what's connected to what and I don't have a schematic for this unit. Is there a termostat that controls the element temp. that has gone bad allowing the elements to overheat and trip a resettable breaker? Thanks for any help you can give.
  • frednjen Sep 13, 2008
    Thanks Mike. I'll give it a try and report back. Jen
    Genius:
  • 1,122 Answers
ON THE BLOWER BOX THERE IS A BLACK THERMISTER THAT GOES BAD AND THE DRYER WILL RUN A FEW MINUTE AND CUT OFF,REPLACE THAT AND YOU SHOULD BE OK,MIKE
Posted on Sep 13, 2008
Beko drcs76b dryer not heating up, i have changed the heat element but still blowing cold air, any suggestions?
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Apr 03, 2015 | Dryers
Zanussi tumble dryer keeps cutting out
Feb 25, 2015 | Zanussi ZDC37100W Electric Dryer
Maytag dryer stops after few minutes
Feb 21, 2015 | Maytag Dryers
I have a AEG LAVATHERM 59800 DRYER AND IT IS NOT GETTING HOT NOW AND I HAVE CLEANED THE VENTS BUT STILL THE SAME? ALSO WHEN IT REACHES 0 AFTER A CYCLE IT IS NOT SHUTTING DOWN OFF? CAN YOU HELP?
Feb 19, 2015 | AEG Dryers
Whirlpool dryer, when set for auto dry low heat, or timed heat, then dryer runs fine, when set on auto dry high heat timer doesn't move, what could be the problem? does it have to be the timer?
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Feb 10, 2015 | Whirlpool Dryers
I have a gas dryer. It heats up just fine, but it won't shut off. if put on time dry it won't count down the time and on any other cycle it will just keep running and drying
Oh I can't think of the name of it right now but the whole knob assembly inside needs to be replaced. It's like a timer its integrated into the knob.
Jan 05, 2015 | Dryers
Ge front loader dcvh515efoww - dryer shuts off when put on heating cycle
Did you pull the dryer out or forward sounds like you may have pinched the exhaust which restricts air flow exiting the unit this will cause it to heat briefly shut down heat shut down and continue this cycle the fact that it worked before makes me think it something simple it will not tumble in any cycle if door switch not installed correctly.
Mar 21, 2014 | GE Dryers
The dryer shut off mid-cycle. It smelled overheated.
Hi
Your thermostat is shutting you off on mid-cycle because your overheating the dryer...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me thumbs up.
Sep 18, 2011 | Maytag PYE2300AY Electric Dryer
Dryer seems to be heating but cloths are not getting dry hardly any lint on cleanout screen
Is the air venting all the way to the outside? If you ducting is clogged, dry times will be much longer. You may also be seeing steam come out the door if you open it halfway thru the cycle if vent is clogged. A crimped hose between the dryer and the wall can cause a similar problem. A clogged vent can also be a fire hazard.
Nov 19, 2009 | Microwave Ovens
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
