SOURCE: No LCD Display when opened at 90 degree
Dear sir, If the Picture in View finder is connect, then problem in LCD ribbon cable. LCD Ribbon cable may damage. Replace LCD ribbon cable. thank you, replie if any problem
SOURCE: Won't load DVD for Initial IDM-7110
First check and see what is happening inside. Take something small and stick n the lock mech, which is the hold that a small part of you top to the player sticks in to tell the unit that it is closed. See if the lense light up and moves up and down and also see if it moves forward a bit and back to start position. If player does not do any of this then with fingers move lense down line abit to see if anything is obstruting path. You can move all the way down then place DVD in and try again
SOURCE: Wall charger
Radio shack carries a universal kit with choices of many different voltage and milliamp combination. Bring your DVD player to them, and they can help find the one that best suits you.
SOURCE: LCD... Problem
I found an answer here as my lg 19" has the same problem, not having any tech knowledge I banged the monitor and it has cleared the problem for now but I think it will neeed replaced i dont think there is any other option please advise if there is!!
Ryan
Iiyama Monitor Model: Vision Master 17 (8617E Chassis)
Horizontal dark line across screen shadowing text or other complex display data - giving appearance of 3D grooves or just dark lines on light background - temp fix (few minutes) by banging monitor or jiggling the video cable (thats what threw me for a while)
Removed tube base board and ran over disc capacitors and other solder joints whether they looked dry or not. No re-occurence in 2 weeks of daily use. Seems to have fixed it. (Be prepared for a lot of metalwork and screw removal when opening one of these up - I still havn't figured out how to get the PSU/main board out of one !)
(John)
SOURCE: lines in images
Sent camera to Kodak whch fixed it and sent it back weeks ago. A solution almost a month after the inquiry is too late to be helpful.
