RadioShack 4-IN-ONE REMOTE
Can you please provide the programming sequence to use the subject TV remote for a GE Model CTC177AJ2 television.
Press and hold the device you want to program
continue holding and press the on/off button
hold both until the lights stay on on the remote
release and press the play button once
allow the codes to cycle in 5 second intervals (press the play button every 5 seconds until the device turns off)
once the device is off is off press the release button twice
press the stop button
if you have pressed the play button 20 times, and the remote starts to flash, this means the remote will not program that device
One problem I had after program was that my rca tv and vcr were clashing on the menus because they are both on the same frequency, hence, another issue I have to tackle. hope I did not skip any steps, I am doing this from recall
Posted on Sep 14, 2008
I NEED THE CODES NUMBERS TO PROGRAM THIS TV WITH UNIVERSAL CONTROL
GE Universal Remote Codes ' Jasco
https://jascoproducts.com/support/ge-universal-remote-codes
Make a note of which version you have and replace the batteries and cover. A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Programyour GE Universal Remote using the correct code list and instructions. ... Sometimes a code will allow limited function control (e.g. volume and channel ...
Universal Remote Control Codes
www.remotecodelist.com/
Codes and links for a number of universal remote controls, including Sony, RCA, ... If you have a remote for which you know the codes (or a web page that lists them) head to ... How to Program a GE Universal Remote Control .... look for your model of TV or VCR and find the online instructions that include the remote codes.
RCA Universal Remote Control- Target Programming ...
Jan 05, 2016 | Coby TF-TV3217 32 in. LCD TV
I cant program my samsung plasma with a radioshack universal remote
go to the manural call up samsung and give them your make and modle and ask them to mail you another remote some universal remotes don't work even thou they say they do
Sep 28, 2012 | Samsung 43 PN43D450A2D Plasma TV
I need the code for ge universal remote rc24993-c to connect to a sony television please
Universal remote allow you to control multiple electronic devices with a single remote. You can use the remote to work your TV,DVD player, cable boxes and other devices from the comfort of couch.Philips is a popular manufacturer of universal remotes.to program a GE remote for SONY TV,you will either need to input the device code or perform a code search
direct entry
first.turn on your TV manually. next.press down and hold set-up on the remote.the red indicator light will stay lit.after that.press the TV device button to let the remote know you wish to program a television then.enter your device four digit codes on the remote..GE list several codes for SONY television including 0002 0006 0007 0018 0107 0114 0310 0312 0502 0601 0704 0719 0803 0806 0810 0901 0911
..if your remote needs 3 digit codes remove only the number zero in the beginning of the codes finally.test the remote to ensure it works.with the turned on,press the channel button and see if the TV responds..if it is work the remote programmed and you are done,if it doesn't work try the different code......
IF THIS SOLUTION HELPS YOU PLEASE DON'T FORGET TO RATE MY ANSWER THANK YOU
Mar 09, 2011 | Televison & Video
We have a sanyo tv and a ge tv remote control and we need the code 2 program the remote 4 that sanyo tv.. helppp
hi,
you didn't specify the brand and model number of your remote . any way follow the steps to prgram your remote with your tv. if it is GE universal remote. any other brand contact me back with its brand and model number.
1.Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit ( or three digit)code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5.Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
code for your tv if the remote is 4 digit one
0049, 0097 ,0110 ,0004
code for your tv if the remote is 3digit one
004, 012, 013, 049, 097, 108, 110, 180, 209, 268
ok
Feb 02, 2011 | Sanyo DS31590 31" TV
Codes search for a radioshack 15-2147 remote
Here are the codes...1447,0047,0051,0178,1347,1917,1147,1907,1922,1919,.....To program.. Turn the TV on, make sure you have fresh batteries in the remote,and installed correct, Press and hold down the P button until the LED blinks twice, enter one of the four digit codes, the LED will blink twice,it not, repeat the steps using a different code..hope this was helpful...
May 30, 2010 | Radio Shack 15-2147 Remote Control
Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
Apr 21, 2009 | GE JASRM24912 Remote Control
Need codes to the remote for a Sharp TV.
look under remote manuals rca, radioshack, it will lists for tvs vcr ect.
Dec 17, 2008 | Gemini 1 Device Universal Television...
Remote controls
have your problem fixed get a / one for all / remote controe it has the tv in that you have in the list cost little to nothing to get it go to wall mart please reply thanks p.s. rca dont have codes for that tv all for one does
Mar 28, 2008 | Durabrand DWT1905 TV
3-in-1 remote 15-2147
Have you tried these codes?
Toshiba TV codes: 0154, 0156, 0060, 1945, 1935, 1918, 1704
If your TV is a TV/DVD combo then use code 1935
Please follow "Programing a Device" on the product manul.
Feb 18, 2008 | Radio Shack (15-2147) Remote Control
Televison & Video Logo
540 people viewed this question
Top Televison & Video Experts
