Question about Toshiba Satellite P205-S6287 Notebook PC
Follow up Re: Blank Screen
Hi, I'm very grateful for your help, When I pressed F8 and boot it in safe mode, a screen appears, stating Loading Windows Files but it stopped, the last line is "Loaded: Windowssystem32DRIVERSCplIR.SYS" and a white bar with Please wait... word, after a while it reboots. I want also to know if how to reinstall the video card driver, since the screen is blank and where will I can find drivers for the video card Thank you very much.
  • vic donald somera
    vic donald somera May 11, 2010
    you can try to boot on enable vga mode upon pressing f8 this should be your screen.
    choose vga mode
    the VGA mode
    allows Windows to be fully functional except it uses a plain old VGA (circa
    1987) video mode.
  • 56 Answers
Most likely the operating system of your computer is already corrupted. you need to run the recovery on the computer. if you have the recovery discs with you, simply put in the disc and boot to cd. included in the recovery disc are the drivers that you need for your computer to work. and that includes the video graphics driver. you can also visit support.toshiba.com for the video graphics driver.
i hope this info helps.
Posted on Sep 17, 2008
Toshiba satellite problems L775 can't get past "windows is loading files"
First restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
Jul 03, 2013 | Computers & Internet
My HP Pavillion dv7 3112sa won't boot and remains
Hi, at startup try pressing f8, this should give you a menu, select 'start windows with last good configuration', this should restore windows to the state before it started rebooting randomly. Failing that...try starting in 'safemode with command prompt' and then do a 'system restore'- press f8 again at start up and then follow the instructions below. this should restore your system to a previous state when the computer wasn't doing random things.
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
I hope that this helps you to sort out the problem. Toni
May 27, 2012 | HP Computers & Internet
Is there another way to have my T3500 run in safe mode other than F8...When I press F8 while my computer is booting up it gives me a blank screen.
If you stop windows from booting up all the way by holding down the power button during the "loading windows" screen, until it turns off. Start it back up and before windows loads it will give you a menu, with options like "start windows in safe mode with networking" or "safe mode with command prompt"
May 03, 2011 | Dell Precision WorkStation T3500/ T5500/...
How to enter the safe mode with network, which key should i press, please help
Hi chankp,
Welcome to FixYa! How are you doing?
Please try to do the following to boot your pc to safe mode with networking:
  • Turn off the computer. Turn on the computer then immediately start tapping the F8 key repeatedly.
Note:
You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu does not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
  • Use the (Down Arrow) arrow key on the keyboard, scroll down to Safe Mode with Networking then press Enter.
  • Login to your User Name.
Hope that helps. Thank you for using FixYa!
Apr 27, 2011 | Computers & Internet
I cannot get passed the loading screen. Doesn't boot up. Just seems to go in a loop.
Hi, try go to safe mode ( before loading screen, press F8 and select safe mode, ) if it goes on to safe mode, goto; Start ->Run..->type msconfig ->goto stratup startup.
uncheck all the entrys, and boot the machine normally, if it boots normally, start adding the entrys one by one, until it failes to start. report back.
Apr 06, 2011 | Computers & Internet
Acer aspire one starts to boot up stops at windows xp screen
Hi there !
I suggest you try to run your computer on safe mode by pressing F8 when booting up. Advance menu options will pop up and choose run on safe mode. When it load the Windows, try to figure out what you installed or you before your computer happens. I suggest that you download also windows registry cleaner to fix some errors in your computer that prevent you to go to windows screen when booting up on normal mode. Run the FULL SCAN and press the fix errors button.
I should somehow help your computer.
Feb 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi, I need to know how to start-up in safe mode.
During boot up repeatedly press f8.
Or within Winows press start >> Run >> msconfig >> press Boot tab >> check safe boot.
Jan 02, 2011 | Acer Aspire T650 (AST650UC3601) PC Desktop
How to open in safe mode
Turn on the PC - as soon as the BIOS screen dissapears keep tapping
F8 - this will bring up the boot menu and let you select "safe mode".
If you get to the Loading XP screen with the moving bar you pressed F8 too late, reset and try again.
Jan 25, 2010 | Microsoft Windows XP Professional for PC
After booting process done. Screen goes blank and Keyboard not working only Mouse cursor is dispaly and working on the blank screen in My acer Laptop.
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, F8 key on your keyboard. When Windows Options menu appears, scroll to select the Safe mode menu item, and then press Enter.
Select "Last known good configuration" then press Enter.
If that doesn't work reboot again and keep tapping on F8 to Safe Mode and instead of selecting "last known good configuration" select "Repair Your Computer"
Or you can try this:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  1. Place your Windows XP set up disk in your CD drive.
  2. Turn off your computer and change your BOOT order to boot from CDs first.
  3. Turn your computer back on.
  4. Press any key on your keyboard when it asks you to.
  5. Press enter when you see a blue screen, one of the options should say, "To setup Windows XP now, press ENTER.".
  6. Press enter to start the windows set up.
  7. Accept the Licence and Agreement and confirm that the setup is searching for current versions on XP.
  8. Press "R" when the set up has found your current version of XP.
  9. Notice that the Set up is deleting all your windows xp files and replacing them. (This will not cause loss of data)
Jan 11, 2009 | Acer Aspire 5610 Notebook
Windows xp logo will start to load then......
To solve this will require more information from you. The Blue screen is Windows way of telling you that it has a driver issue with a basic component, usually your video card. Did you recently make any hardware changes? If so please let me know what was changed.
When windows first boots, you can repeatedly press the F8 key until you see a menu giving you choices of windows booting. You need to select Safe Mode. Safe mode should allow you to at least boot without a blue screen. The blue screen could also be cause by a virus or other software.
Microsoft has a description of Safe mode here;
http://support.microsoft.com/kb/315222
but here is a quick snippet
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Dec 13, 2008 | Compaq Presario S6000NX (DQ178A#ABA) PC...
Toshiba Satellite P205-S6287 Notebook PC Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
