Question about RCA DRC108N DVD Player
Dvd My issue with this RCA DVD player is that it plays great but when you click the eject\open button it will not ject the DVD. The other buttons work also
  • Albert Quinonez May 26, 2006
    Hey: Techman I open the DVD player the belt is OK and the dvd does not make a noise like it wants to open.Got the dvd to open manually then pressed the open/close button it closed the door also checked the button it feels OK.Is there another solution to this problem
    President:
  • 3,130 Answers
Does it act like or sound like it wants to open? This could be a small belt drive that is broken or slipping and not letting the door open. Also theres a cam inside thats driven by a belt or worm gear that if that dosent turn then the disc clamper wont raise up and let the door open or you could have a problem with the motor drive circuit that controls the tray motor and last but not least does the eject button feel like its making contact with the little swith inside or is it a flat feeling as maybe the switch could be broken or out of alighnment with the eject switch? Anywho if you unplug the unit it woulnd hurt for you to open the unit to check the belts worm gear or eject switch but if your not handy andy then I would seek a pro for assistance. Good Luck
Posted on May 25, 2006
  • Larry  Dillon
    Larry Dillon May 26, 2006
    if you opened it as little and then it closed when you pressed the button then we know thats all ok.. HMMM ok is the laser assy all the way back to home?? i mean all the way against the spindle or turntable? If that all ok then Im guessing that the problem is in the motor servo control for the tray assy. theres a forward and a reverse ie open and close. Maybe the control ic for the motor has a bad function to it?? remeber this is a hard thing to do when I dont have the unit in front of me. Oh one more thing is there a open and close on the remote?? does that work the same?? if it does and everything is as I said such as with the laser assy postion ect ect then you most likely have what I ststed a bad motor control ic for the tray assy.. Good Luck
Eject button is stuck
Get in touch with the manufacturer's product support and ask them.
May 07, 2015 | Televison & Video
My dvd does not play in laptop due to digital copyright problem. what can i do to fix this? no dvd wil play
Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Jan 28, 2013 | Compaq Computers & Internet
My dvd wont play on laptop
b> Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
Rca dvd\vcr locked on hello
The hello issue is most likely a faulty DVD-RW. These go out on thse models more than usual. Reset is a combination of 2 buttons. Press and hold the play and disk tray open or the power and play ( i forgot the exact sequence but you get my drift, press 2 buttons for about 10 seconds). You can also update the firmware...or atleast could before from RCA.COM but they no longer support this midel. I do have the software update on CD but it won't do any good on Hello issue. If worst comes to worst, open the player up and replace the DVD-RW drive.
May 25, 2008 | RCA DRC8060N DVD Recorder
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
RCA DRC108N DVD Player Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
