Question about Dometic RM2652 Refrigerator
Yellow stuff My Rm hascraped out.. I find ammonia has leaked into the boiler unit. DOMETIC says to install a kit. This kit only shuts off the gas to prevent the trailer burning to the ground. After several call and a total runaround I am now really ticed-off. The unit is only three years old and a leak in the pipes is not from faulty care but from premature failier of a defective item. ANYONE GOT IDEAS? BTW Domectic has now sent me a recall notice.. Isn't that great!!
  • 3 more comments
  • fluidos1 Dec 31, 2008
    My Dometic Americana stopped working in my 2004 Layton trailer. the inside light comes on. I smell some ammonia in the back.
  • Anonymous Apr 01, 2009
    same problem. talked to a lot of nice people. the recall only keeps it from a bon fire doesn't fix the problem which was my argument. so far they won't do anything for me. there was ammonia leaking. i told them their recall was like putting a bandaid on a broken arm but it didn't work.
  • zbop Apr 07, 2009
    Yellow stain around exhaust vent. Out of warranty Dometic's response was parts don't last forever, They should in a non-mechanical system. They have stretched the tubing down so thin to save a few extra pennies that they are developing "fatigue" cracks. Now that it's out of warranty they do not have to do anything but charge you for a new cooling unit or refrigerator (your choice) with the same problem !!!!!!!!!!!!!!!!!!!
    Anyone with the same problem please call Dan Billington@636 583 5103
    for a class action law suit.
  • menaima Apr 12, 2009
    Hi I have the same problem it smells ammonia and the unit does not work anymore I live in mexico and would like to know if I can send or replace the part that is defective by sending it out without having to take the complete fridge out of the unit.
    Thank you for your response.
  • Anonymous Apr 21, 2009
    my refrigerator has quit cooling. When I went to check the fusses in the power module I noticed that some yellow stuff had come out of the back of the refrigerator( fusses were good).
    Problem Solver:
  • 19 Answers
Fridge caput.
Posted on Nov 18, 2008
I have a dometic RM 2862 refrigerator and smelled ammonia and then heated up but no signs of leaks, is the cooling unit bad?
Is it still working? If you can smell ammonia, I would say that there is a very small leak. Over time, the fridge will lose its efficiency and take longer and longer to cool down. Eventually, it wont cool at all once all the gas has escaped. From what I remember of Dometic fridges, is that they used to supply exchange refrigeration units. You remove the entire refrigeration system and swap it for a new or rebuilt system. It worked out a lot cheaper than buying a new fridge.
Jun 19, 2014 | Dometic RM2852 Refrigerator
Lhave a rm 2601 rv refrigerator and when I cut it on the freezer coil gets warm instead of cold.Also it is making a gurdling noise. when I open the door to refrigerator the it has a ammonia bad...
Shut it off and get it checked. Ammonia is dangerous as I am sure you are aware. Ammonia smell is an indication of a leaking cooling unit. Time for a new fridge. Sorry.
Oct 14, 2011 | Dometic Rooftop RV Air Conditioner
I have a Dometic 2650 refrigerator in my RV. It is leaking a scent of ammonia and we do not know what is causing this or what is leaking. PLease help immediately .
Shut it off immediately and do not use it. Ammonia is sign of coolant leak, thus cooling unit is leaking/faulty, and as I'm sure you know, ammonia is dangerous to inhale etc. Sorry to say but, it's time for a new fridge, and at very least a cooling unit, but speaking from experience, your better off buying a complete new unit. I've seen many people replace cooling unit to save a few hundred dollars, then end up replacing circuit board, and various other item one after the other down the road. New fridge comes with year or 2 warranty as well.
Sep 29, 2011 | Dometic RM2652 Refrigerator
I have a Dometic Americana refrigerator that is not working. When I first turned it on, everything was fine. I left for about an hour and when I came back, there were no lights on the control panel or...
These often have a recall kit installed that has a thermal fuse in the burner area....when the burner overheats the thermal fuse shuts the hole thing down to prevent fire, the ammonia smell is probably from the cooling unit. check under your burner, to see if you see a bright yellow powder or liquid if you do, your cooling unit is for sure bad and is dangerous to run. The thermal fuse shuts the fridge down completely and can be reset by pushing in the button in the middle.
May 21, 2017 | Dometic RM2652 Refrigerator
Dometic refrig not cooling but found yellow oil at service panel
if you find an oily substance its most likely freon. this looks pretty new so i would say you have a bad soldered joint on a copper to steel line. theses usually ar fot the high side. where the condensor coil or loop runs either to underref or up in the ref walls
Aug 01, 2010 | Dometic RM2652 Refrigerator
Our rv has a dometic rm2600 fridge that smells of ammonia inside and has a little bit of yellow residue in behind service panel. is the fridge wrecked or is it worth repairing. the rv is 27 years old.
Sorry to give you the bad news. The ammonia smell is the the refrigerant
leaking out. Dometic uses ammonia that is heated and then condensed to cool. It will all leak out and quit cooling.
The fridge is wrecked. There are shops that rebuild the units. Beings as ammonia is corrosive one must assume there may be other leaks ready to appear. There are RV salvage yards that sell good used units.
Again Sorry for your loss.
Apr 27, 2010 | Dometic RM2620 Refrigerator
Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Jul 06, 2009 | Dometic RM2620 Refrigerator
Ammonia smell when Dometic Air Comditioner is on
sounds like you have an old unit and it has a leak , the real old units where filled with ammonia as the gas
Feb 16, 2009 | Dometic Rooftop RV Air Conditioner
Dometic RM2652 Refrigerator Logo
263 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
