Question about Adaptec 1 Bay ACS-100 (2177400) USB 2.0 External Drive Case
The hard drive won't boot up
When the hard drive starts up, you can hear the disks spinning and the device working. However, now when I power on the hard drive I get nothing. The blue light comes on and I can sometimes hear the device clicking as it tries to start spinning, but it never gets going. My computer recognizes the power on and power off, but it cannot detect the hard drive b/c the drive never gets going. Any advice on how to correct this problem? I have everything stored on this drive.
  • Anonymous Oct 04, 2008
    I have the exact same problem. The problem is not with the hard drive itself. The issue seems to be from the adapttec product. I removed my hard drive from the adaptec enclosure and ran it directly off of my computer (using the ide and power supply from a dvd drive). So your files are ok, i just can not tell you how to fix the problem.
  • brett9 Jan 11, 2009
    I'm not sure I have the exact same model, but my problem seems the same. I was replacing the drive because the front light started glowing red and making a loud clicking sound, so I plugged in a brand new drive and now I get the normal blue light but there is a faint clicking sound and drive shows up as 0 bytes and cannot be formatted. (Mac OSX)
    Top Expert:
  • Adaptec Master
  • 45,531 Answers
The hard drive is dead ( dreaded click of ***** syndrome )
you can have that verified at a computer repair shop and if that is the case use a solid state hard drive as a replacement and not the spinning disc type as for the data you have stored , there are places than can recover it from the dead hard drive but unless you have it all backed up on an external hard drive or storage device then it is lost
Posted on Jun 04, 2017
`no bootable device insert disk and press any keys what should i do
Have you left a CD in the CD Drive, if so take it out and re-boot.
Can you access the BIOS - if so check the Boot Order and ensure the Hard Disk is the first boot device.
Also check that the BIOS is recognising the Hard Disk.
It maybe that the Hard Disk has gone down - can you hear it spinning up or down when you boot up or switch off. Make sure it is seated correctly.
Aug 22, 2012 | Acer eMachines 350-2074 Netbook
Error why coming
Can you hear any fan or drive sounds? If you don't hear anything at all when you try to turn the laptop on, no little LED's light up, the problem almost certainly isn't related to the hard drive. So if you don't have a live screen, start with the LCD troubleshooting flowchart, and if you don't have any activity at all, start with the power troubleshooting flowchart. Even if the hard drive has failed at the electro/mechanical level and won't spin up, this wont prevent the LED's on the laptop from lighting up, or the LCD from displaying the BIOS information and complaining about the lack of a boot device.
Ford F150 Body Kits
Jun 07, 2012 | Computers & Internet
I have a problem with my m/b k7som+ 7.5c. When I press the pwr button everything seems ok, all fans are working properly and I also hear the HDD spinning sound. However there is no POST beep or anything...
There are a few procedures you can possibly try before replacing components.
I HIGHLY recommend you unplug power while trying these steps
1) Unplug power and remove CMOS battery (usually a small silver circular battery) on motherboard for 1 minuted then reinstall battery and see if it boots up.
2) Re-seat all RAM memory chips. If it doesn't help, then try booting the system 1 memory chip at a time, to rule out a bad stick of RAM
3) If you have a separate video card (not onboard video) then try re-seating it
4) unplug both data and power cables to all internal components (hard drives, CD-Roms, Floppies, etc) and also internal cards and see if it boots. If it does then reconnect one device at a time til you find the culprit
That's pretty much all you can do without swapping out parts.
I hope this help and I wish you luck!!
Regards
Mar 07, 2011 | EliteGroup V7.5A (K7SOM+ V7.5A)...
Unit failed to boot and observe the followng; - No start-up display - No CMOS boot-up display - Hard disk clicking sound and OS won't start
Turn the computer off.
Disconnect the AC power supply.
Remove the battery.
Remove the disk-drive.
Reconnect the AC power supply.
Turn the computer on.
Put any "data" disk into the CD-drive.
Does it display the CMOS boot-up display?
Can you hear the PC try to spin that "data" CD, i.e., trying to "boot" from it?
If it works "better" without the disk-drive attached, the disk-drive is the problem.
Jan 11, 2011 | Toshiba Satellite A105 Notebook
I have pluged in the usb plug and plug the maxtor to the electrical plug but nothimg happens. How do I get it going?
Take a multi-meter, and test the voltage and amperage outputs from the power-supply, to confirm that the readings match the specifications on the label on the power-supply.
If the power-readings are correct, then when you connect the power to the external enclosure, you should either hear the disk-drive start to spin, or feel the vibrations as the disk-drive spins.
If you don't, then the disk-drive inside the enclosure has "died".
If the device is still under warranty, MAXTOR will replace the disk-drive, for minimal costs to you.
If the warranty has ended, then open the enclosure, remove the disk-drive, purchase a new, compatible, disk-drive, install it into the enclosure, and thus "revive" your external storage device.
Nov 04, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Feb 15, 2010 | Apple MacBook White- 2.1GHz Intel Core 2...
Hard drive not booting
Test the power supply with a volt meter. You should be able to hear the hard drive spin just by putting it up to your ear.
Dec 04, 2009 | LaCie Big Disk Extreme (300797U) 1000 GB...
Verbatim 160GB Hard Drive won't boot.
Try it on another PC or on a powered USB hub: maybe it's not getting enough power to run.
If it still doesn't work, and you don't hear the drive's spin-up noise, the electronics may be damaged, the internal disk disconnected or the internal power connection faulty.
If you hear the spin-up whirring and then a series of repeated whirrs and clacks, ending after about 30 seconds - one minute, the disk might be damaged. It still might be recoverable if extracted from the case and connected directly to an appropriate hard disk port (a 3.5 to 2.5 adapter might be necessary), but when things go this far, the chances aren't too good.
Oct 27, 2009 | Verbatim Computers & Internet
Dell latitude D610
This fault usually means the hard disk has failed or the disk controller, in most cases it is the hard disk that has failed.
Check the BIOS settings and see if the hard disk is detected, if not it is probably a faulty hard disk.
When you boot up the computer does the hard disk LED light flash and can you hear the hard disk spin up. If the hard disk is making a clicking noise then it is definitely faulty.
To test the hard disk another way, remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer cannot detect this as an external hard drive and you can't open the folders and files, this confirms it as faulty.
To get the computer operational again, you need a new hard drive, Install Windows on the new hard drive with the computer's device drivers and your programs.
Sep 05, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Wont boot or make noise but lights are on
remove it from the case and put it straight into your computer using a spare power plug and cable. to see if you are doing it right check one of the other hard drives in the tower switch on and see if there is any diffrents if not then i am sorry to tell you it is caput
May 26, 2009 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Adaptec 1 Bay ACS-100 (2177400) USB 2.0 External Drive Case Logo
107 people viewed this question
Top Adaptec Computers & Internet Experts
Rommel Balcita
Martin Murray
Robert Graf
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
