Question about GE JGBP28 Gas Kitchen Range
Oven fan Is there a way to stop the oven fan when backing is complete? Do not like the noise when it keeps running
    Sergeant:
  • 409 Answers
Can you tell me the model # off the stove? the fan shouldn't be continuously running.
Posted on Sep 13, 2008
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
I have a belling double oven. The bottom is fan assisted. It all works okay but when it is turned off it is making a drumming noise after the fan has stopped. This lasts for at least 5 minutes. Any...
Sounds like the cooling fan bearings are worn, hence the noise after you turn the cooker off.This fan is in the top of the oven and helps to keep the inside cooker electrics cool and often keeps going for a while after you have turned the cooker off. Best to call an engineer to check this out for you!
Nov 30, 2014 | Ovens
Noise when oven running and stops when oven stops
Is it a convectional oven? If so, this is the fan turning on to circulate the heat. Being an electric oven, there really shouldn't be any noise whats so ever when on. I suspect your have a convectional oven and the fan is making the noise...either because it is working fine...or because its not and needs to be replaced.
Dec 02, 2013 | Thermador SC272T Electric Double Oven
Kitchenaid KEMS378sss fan noise
Does it keep heating food? You do not run it without the fan very long and maybe it will shut off or down when it senses the fan stopped and might stop cooking. You want to isolate it is the fan and not the magnatron (cooking device). It is pretty new for that but always a posibility.
Do you have a straight vent fan that you can turn on without cooking? try that and see what you get. If it does the same, I think you have a defective fan.
e
Nov 19, 2011 | KitchenAid Architect Series KEMC308KSS...
Loud droning noise from fan.
You are correct in assuming that is a noisy fan bearing, only solution is to replace the motor complete unfotunately.
Please rate my advice.
Thanks.
May 27, 2009 | Ariston Technologies Ovens
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Hotpoint microwave exhaustive fan combined unit - fan not working
Do you feel air flow? That's the key.
Most microwaves have the exhaust fan assembly at the back edge, not up front immediately behind the grille / vent.
Post back if you can give us more detail or have other questions.
Oct 13, 2007 | Hotpoint RVM1635 Microwave Oven
Fan assisted oven
i would suggest to renew the complete fan, but i found a company which sells lubricants that can bear tempratures of 550 degrees. follow this link: http://www.tomlinscientific.com/lubricants.html
Aug 16, 2007 | Belling XOU252 Electric Single Oven
Oven
oven has two fans. the second fan is out of sight and cools the casing. it is operated by a seperate stat. not unusual for it to run for up tohalf hour after switching off. if it runs for an excessive time may be a fault nwith fan stat
Mar 20, 2007 | Bosch HBL 5056 Electric Double Oven
GE JGBP28 Gas Kitchen Range Logo
100 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
