Question about Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore upright freezer
Plug in the freezer and nothing happens. There is 120v of power at the overload connected to the embraco compressor as well as starter (three prongs on the compressor, with everything connected and powered up, 2 prongs have 120 v- not sure if it should). also, he fan isnt workin. Compressor prongs read 4 ohns between the 2. Is this a problem with the timer
  • 828 Answers
No it is not the timer. You may have an open overload protector at the compressor. Check across the overload for a reading with an ohm meter. If it reads zero it is good, if not replace it.
Posted on Sep 14, 2008
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Kenmore upright freezer. continually runs. Temp. is 10 degrees f. I cleaned the dust off the compresser. Checked for leaks on the door seals no leaks. I have just now set the temp control from 4 to 3 and...
Power outages would not make a difference, but dust on the compressor coils would. The best way is to vacuum the coils and then spray with soapy liquid making sure not to spray anything electrical.
Dec 15, 2017 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer fan on compressor off
They make generic "compressor packs" to solve these. Your capacitors and relay and parts that support the compressor operation went out.
If you're really really like just the temp overload switch went and you can jumper bypass it. It usually looks like a piezo electric type of disc connected right onto the comp case itself.
But you're right with the DT, the motors go out on them a lot. They are usually for 4/6/10/12 hours depending on make and model. Sometimes the contacts go So if you could isolate them... they're on the larger side and will go from the power to the compressor. Use a jumper and test for a complete circuit to the plug and through the compressor before trying it.
By law all freezers and ovens have to have a schematic diagram on them. Often it it in a little plastic package and sometimes just wallpapered to the inside of a large piece of sheetmetal in back.
Good that you know how to use a meter!
Jul 13, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Compressor kicking on and off. freezer not freezing. is it a relay? Frigidaire LFFH2067DW4
If you have 120v coming out off the outlet and it is kicking on and off change the relay and the overload. if it has a capacitor change that to
Mar 13, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Plugged in freezer after standing 3 days unplugged compressor ino
That sizzling noise i suspect is either the compressor overload or start capacitor burning out .
You need to look in connection box on side of compressor,the relay should just pull off once cover is off.BEWARE even with the freezer unplugged there is a charged capacitor connected inside this box and will give you a nasty shock should you touch it! with insulated pliers touch all terminals to each other and earth to make sure capacitor is discharged .You should be able to get astart capacitor and overload from local repair shop there not expensive if this doesn't fix it the compressor is possibly locked up and will need replacing
Oct 05, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Compressor stops running unplug for awhile then plug back in compressor starts for a day or two
There could be many reasons for running hot, and the "Thermal Overload" is protecting the compressor.
Make sure nothing else is on the circuit used by the freezer.
Lastly, you may have a weak overload.
May 04, 2009 | Kenmore Freezers
Kenmore freezer quit working after power outage
simple stuff, you have a compressor a stat and power. check the receptacle to be sure you have 120 volts . then check the compressor with stat at max cold setting to see if you have 120 volts at compressor. if you do then compresssor is bad =new compressor or new unit. if no power to compressor then stat is bad= new stat. i always recomend new unit cause new stat or compressor wont fix a freon leak.... i have replaced a few compressors that died soon after due to a freon leak. good luck...
Nov 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Timer is before the power to the compressor and overload protector and is unrelated with the exception that the power passes through the timer to the thermostat and then to the compressor. Power at the compressor indicates that the timer is supplying the power. The gears in the timer turn one cycle every 8 to 12 hours depending on the model of the timer.
Sep 14, 2008 | Freezers
Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Jul 01, 2008 | Freezers
Kenmore 20.6 cu. ft. Upright Freezer 24092 Logo
208 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
