Question about Xerox WorkCentre PRO-215 All-In-One Laser Printer
Xerox pro 215 overheating
When printing more than 7 or 8 copies the unit seems to overheat and the paper jams. Less than that and no problem other than a toner smell. And after you let the copier sit for a while, running a few copies at a time is no problem.
A fuser problem? Does it need replacing? I've read something about an overheating re-set. Will that fix things?
The copier (remanufactured) is fairly "new." I've run less than 500 copies.
  • 2072 Answers
SOURCE: Xerox Phaser 5500 printer...paper stops halfway thru fuser unit.
Are the paper tray settings correct? If you have the tray mis adjusted, such as the tray thinks it has 14 inch paper in it and it has 11 inch, it will just shut down like that.
Make sure the settings are correct on the computer and the printer.
Also, its unlikely but the latch for the load springs in the fuser may be unlatched, but you shold NOT be able to close the covers like that.
Posted on Jan 06, 2009
faxman789
  • 297 Answers
SOURCE: xerox pro 215, error H4 please help
H4 is a fuser error....not getting up to temperature.
Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
If this doesn't bring it back to operations then the fuser lamp needs to be replaced.
Posted on Jan 17, 2009
yooperbud
  • 8637 Answers
SOURCE: Xerox WorkCentre Pro 215 E2 Error Code
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 29, 2009
  • 239 Answers
SOURCE: xerox m15i copier guide broken
This sounds like the paper path guide that sends the copy by the drum modual and then to the fuser.
If the walls are stained yellow, they the "vains" plastic guides are broken and will cause paper jams. Also after the paper has been fed out of the fuser modual there are other plastic guides that might appear to be yellow in stains. these tips often break and will cause constant jams.
The door guide has to be replaces and the vertical transport may need replacing as well. You would need to get part numbers for this specific model and someone who knows how to dissasemble this machine.
End result, you may need to call Xerox for assistance.
Good luck.
Posted on Oct 17, 2009
  • 85 Answers
SOURCE: I have a Xerox Copier
I would truly call in for service. Copiers require a trained tech to replace the fuser. Trust me I work in the IT industry. Have a trained tech fix it.
Posted on Nov 23, 2009
Colour Xerox Machine problem
its a problem with the fuser unit ,its overheating .two ways to solve it first check if the sticker paper is supported by your printer ,2nd you may need to replace the fuser unit
Oct 02, 2014 | Xerox DocuColor 242-252-260 PS
Xerox 416 Work Centre Pro Paper Jam
You should first have a check over the roller . Mostly the problem will be the roller only .
But let me know how old is your copier ?
Depending on it we can solve your problem .
SAM ANDERSON
Sep 23, 2008 | Office Equipment & Supplies
I have a Xerox WorkCentre Pro 416. It has worked very good for several years. I was printing several pages and I heard a noise like something plastic broke and then I got the alarm with a paper jam...
sounds like the unit has an issue with one of the rollers not activating. contact a repair technition, any one worth their weight should be able to diagnose in a few hours. units with so many moving parts are hard to diagnose without visuals.
Mar 07, 2011 | Xerox WorkCentre Pro 416 All-In-One Laser...
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
The copier makes it half way thru the copy the stops with a paper jamb usually on the print table. I keep having paper jamb issues also have finger prints on copies which started after I removed the toner...
The jamming with the copy half way thru is almost always a broken fuser drive gear. The unit that gets hot as the paper exits the machine. Check the back side of this unit. You will see a gear, or part of a gear that is about 1.5 inches across. Either that gear breaks or the cog inside of it shears off and this causes the fuser not to turn. Very inexpensive part at less than $15 and pretty easy to change.
As far as the fingerprints go you most likely touched the drum surface. You may have to remove it again and clean your fingerprints off the drum with a soft cloth.
Oct 20, 2009 | Xerox Office Equipment & Supplies
Borderless printing kodak 5500, clear coating business cards
Go to printing preferences of the particular program and then select Borderless . THESE ARE THE SIZE OF PAPERS SUPPORTED IN Kodak printers.
  • 3½ × 5 in.
  • 4 × 6 in.
  • 4 × 8 in.
  • 4 × 12 in.
  • 5 × 7 in.
  • 6 × 9 in.
  • 8 × 10 in.
  • A
  • A4
May 07, 2009 | Kodak ESP 5 Printer
Nov 19, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
J2 Error ? Xerox Pro 215
J2 means your drum needs to be replaced. The life of the drum is expired.
Mar 13, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Xerox WorkCentre PRO-215 All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
