Konica Minolta DiMAGE F100 Digital Camera
Problem for Konica Minolta DiMAGE F100 Digital Camera
Shutter will not fully open or close
By morris on May 25, 2006
The automatic shutter gets stuck at different points and causes a shadow in the image corner.
It will not fully open when the camera is turned on and will not fully close when the camera is turned off.
The only solution to this problem is invert the entire camera and shoot that way.
Same Problem
Aug 10, 2008
-   My top shutter will not fully open.-   sydneyN
Jul 28, 2008
-   camera lens shutte doeanot close even when the camera is swtiched off.-   schordia
Dec 26, 2007
-   My lens cover will not fully close or open by itself...I have to force it manually to open fully. I've taken this puppy to the beach and everywhere I go for several years...so I'm pretty sure it's due to dirt build up. Is there any way I can clean the mechanism myself? Is there a lube for the mechanism?-   Dan55
Best Solution
posted on May 26, 2006
Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1900 votes
Try using a can of compressed air on the shutter mechanism. You may have a piece of grit between the blades. Also whilst the camera is switched off you can gently move the shutter manually when you do and there's something stopping it you'll feel it. Move the shutter up and down quickly and the grit may fall out. Even a gentle tap with the camera upside down and the right way up may dislodge any dirt.
One of my customers had the audacity to put a dab of super glue on the shutter. He never had a half open shutter again. A bit drastic but it worked for him. He ended up fitting a UV filter to the lens and his lens is safe from damage or dirt.
BMW
Was this helpful?
Yes
No
Solution #2
posted on Jun 09, 2008
Not Rated)
jocky wipple
Rank: Apprentice
Rating: 0%, 0 votes
wip it up side down and snap it a couple times put your finga on the round hole and blow through it then snap it again \.
da wipper snapper soultion
Was this helpful?
Yes
No
Solution #3
Not Rated)
Nightdiver
Rank: Guru
Rating: 87%, 168 votes
It sounds like the shutter mechanism is dirty, or you have a bad spring. Try taking it to a camera shop and have them clean it. It is not very expensive, and well worth it if it fixes the problem.
Best regards,
nightdiver
Let me know if it solves the problem.
Was this helpful?
Yes
No
Popular Solutions for Konica Minolta DiMAGE F100
Questions and Unsolved Problems for Konica Minolta DiMAGE F100
Do you recommend Konica Minolta DiMAGE F100 Digital Camera?
Answer
Answer
i have an old (?) canon power shot whose shutter has frozen 3/4 open. new batteries (including date... (More)
Answer
blurred lcd screen ONLY when taking pictures, please help!
Answer
hi, i have a minolta dimage f 100 it turn on and after a 2 secons turn off i dont know why can... (More)
Answer
I just bought a charger for the Dimage F100 and the book says to take the battery out before... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
in , CA
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
