Steinberg Cubase SX3 (502010600) for PC, Mac Logo
Posted on Sep 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When exporting track to audio mixdown the page disappears when I click on save everything els seems to be in order [ex] wav set and 16 bit what is the problem?
Geoffrey
Level 2:
New Friend:
  • Expert 65 Answers
  • Posted on Sep 08, 2011
Geoffrey
Expert
Level 2:
New Friend:
Answers
65
Questions
0
Helped
15022
Points
146
Have you set left and right locators at the start and end of the section you want to mixdown?
Bounced trks 3&4 to 7&8 clicked on wav file button canceled says out of capacity
You have a memory problem. If you are using a flash card for memory or a CD drive or perhaps you have configured an external drive, you need to free up some space. Try deleting tracks or songs you don't need anymore.
Each song is independent on a CompactFlash
without affecting other songs. You can give a desired song name for managing recorded songs
(see pages 23 and 91).
Recorded track data is stored in a song as mono WAV files.
The MR-8mkII can convert the two WAV files recorded on tracks 7 and 8 (L and R) to a stereo
WAV file (see page 115).
You can export the converted stereo WAV file to your USB-connected personal computer, and
use the file by a music software application or make an original audio CD on the computer using
a CD burn software application. You can also burn an audio CD by using an external CD-R/RW
drive connected via the [USB HOST] port of the MR-8mkII (see page 115 and 123)
Fostex MR 8MKII Owner Manual Page 73 Fostex MR 8MKII Owner Manual Exporting Data To Personal Computer...
Are you using the auto delete feature? Get rid of data you don't need here: http://www.manualslib.com/manual/53326/Fostex-Mr-8mkii.html?page=135#manual
Olympus DW 90 VN series. I have been using the
get switch audio converter software from www.nch.com.au
works for us like a charm
9helpful
9answers
EZ Audio Converter does not export files to iTunes
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
Very low output volume from Presonus Firebox recordings
i do'nt know the name of the sound driver installed in my PC
6helpful
Can't export song as audio mixdown on Cubase SX
I had this same problem, only it was after a reinstallation. Fixed it by changing the Output in the Audio Mixdown settings box to
"BUS 1 (Stereo)".
Audacity
Use Sound recorder that is included on Windows XP it gives the easiest conversion option for .WAV files.
Converting the File Properties
1. Left click Start, Programs, Accessories, Entertainment, Sound Recorder. If you
intend to do this procedure often it is recommended to drag the Sound Recorder shortcut
icon onto your Desktop for convenience.
2. In the Sound Recorder box click on File> Open
3. In the Look In field locate and select your file. Click Open.
4. The Sound Recorder box is back. Click File> Save As.
5. In the Save As box click Change…
There are all the options listed that you can change and the bit rate is one of the options.
Dragon software
Forget about soundwave, I don't know if it saves 16 bit Wav or mp3.use Wavelab it is easier just open the files and do save as and chose format 16 bit. You can do the same with soundforge.
Whatever software you use , you use just (File button on top left)command open and save as or export, and when saving you set 16 bit wav. It is not to difficult.
Some of this software has many feature use solo basic file open save as or export
7answers
How do I change a 32 Bit to a 16 Bit?
Not only does the wav have to be 16 bit, it has to be PCM, 11.025
or 22.050 kHz, 16 Bit, Mono. I think it would be easiest just to play the audio from your sound recorder right into the microphone of your computer, since the Dragon software is especially made for listening on the microphone, Or hook up the audio out from the sound recorder to the Line-In jack of your computer using a male to male phono cable.
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
3answers
Usb file transfer
In reading and working with the unit, I have learned that the file transfer is for backup only. If you want to manipulate the file they have to be transferred individually via your sound card or an interface.
Top Steinberg Computers & Internet Experts
 Grubhead
Grubhead
Tesfay
Tesfay
Arcane Winzel...
Level 1 Expert
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
