Question about Dual DWM-3900 System
Can't adjust my speakers??
In set up mode where you adjust all the speakers, I turned down all the speakers and now it won't let me get back into the 5.1 speaker set up. When you scroll down the menu it just skips that area. Is there a way to reset the entire thing I tried to unplug it but the memory still held can you help me it's the sanyo dwm-3900 my e-mail is jon300theman@yahoo.com
thank you
  • 25 Answers
Sansui hdlcdvd26s
see the diagram attached, you can have wrong connection. However clean the contacts and test the wires.God bless you
he speakers are not connected properly. Check the speaker connections. The sound level on the rear or center speakers is turned down. Adjust the sound levels. The receiver is not in the proper surround mode. Set the receiver to a surround mode. The speaker settings are incorrect. Check the settings as per the user's manual.41a9b9c6-64e2-4745-adf3-95fdac1fe686.jpgba7a1620-dfc0-4e45-8fea-6237135735f9.jpeg
Jul 26, 2013 | Televison & Video
Can anyone help
What size is the amp and how many watts is the speaker(s) you have it ran too? If your speakers are trying to pull too much power from the amp it will turn itself into protect mode to keep from blowing a fuse as well as if you are pushing to many watts into small small speakers it will do the same to protect from blowing the speakers I would recommend turning the settings on the amp down slightly and then trying it out also make sure your wires arnt crossed adjusting the setting as it plays is the easiest way to fix the problem also make sure the bass isn't all the way up on your head unit
Jul 12, 2013 | Car Audio & Video
KENWOOD KDC-215S HOW TO SET BALANCE
Step 1:
Press and HOLD the A.ADJ (Audio Adjust) button for 1 sec. to enter audio control mode.
Step 2:
Press either FM (or AM) button to select the mode you wish to adjust. Keep pressing until you find the mode you require (in this case, it will be BL for Balance).
To change the value, press the Down Search or Up Search button to your desired setting. Centre balance is "0", negative number is Left speaker, Positive number is Right speaker.
Step 3:
Repeat Step 2 to select the TREBLE (TRE) mode, then use Down, or Up keys to change the value.
Hope this helps.
Cheers,
Scott
Jan 21, 2013 | Kenwood KDC-215S CD Player
Dpx-u5120 dosent show subwoofer option in function mode , how to fix it ?
I manage to slove to my DPX-U5120 Subwoofer level adjustment. In STANDBY mode, Press the Main Volume button and turn to Setting, turn until you find the SW Preout, Swith to normal mode, its won't work if u switch to REAR
Go back to CD/USB Mode, Then Press the Main Volume and find Audio Adjustment and now u can find the Subwoofer Level , Sub Phrase and Sub LPF adjustment.. Um Glad i found this and Happy Setting
Mar 22, 2012 | Car Audio & Video
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Can't change from MONO to AUTO mode
Hello
Can't make sound from mono to auto is your problem I thinks and posts this solution.
Hit the "Menu" button and surf through, come to "Sound Adjust" window.
The settings allow you to change and adjust sound in your TV. There are Bass, Treble and Balance control to adjust to your individual taste.
To adjust them
1. Press Menu button.
2. Press UP or DOWN button to select the desired item.
3. Press => or 4. Press EXIT button when finished.
When adjusting the parameter of "Balance" control, always set it to mid position to get stereo sound from both speakers. If it is set to any extreme end, there will be no output from the speaker of that side, and will hear as mono.
If you press "0" [Zero] button, you can reset the sound settings to it Factory settings.
To select 'Streo mode;
1. Press "Menu" button.
2. Press UP or DOWN button to select MTS [Multi-channel Telivision Sound].
3. Press => or [The ON AIR arrowtells you if a broadcast is in stereo AND/OR contains the SAP.
Press "Exit" button when finished.
Keep the TV in stereo mode to get the best sound quality. The sound will work in stereo
mode even if a certain broadcast is in mono sound only.
Choose the mono setting to reduce excessive noise on a certain channel or broadcast.
Selecting SAP will allow you to hear an alternative soundtrack, if one is available.
Apr 01, 2011 | JVC AV32F476 32" TV
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
Rear speakers are dead, never got them to work. Changed front to back and rears work so speakers and wireing are good. Is it possible that because I did not hook up a center speaker this is the problem?
if its a 5.1 channels it means 2 front speakers,2 rear speakers or either the center speaker or the subwoofer.try to hook up either center speaker or subwoofer.
Jun 05, 2010 | JVC RX-888V Receiver
Casio Illuminator w-94h
Hold down the "Adjust" button (top left) for three seconds. It won't adjust unless you hold the button down.
Press "Mode" (bottom left) to change what you're adjusting, seconds, hour, minute.
Press the top right and bottom right buttons to adjust the number up and down.
Press "Adjust" again when you're done setting the watch.
To change date, alarm, alternate time, etc, press "Mode" to get to those functions before hitting "Adjust."
I hope that helps.
Jan 17, 2008 | Casio W94HF-3AV Wrist Watch
Subwoofer volume and sound
i had the same problem when i tried to adjust speaker output levels, distance and equalizer manually without using audessy setup..so i reset everything to factory setting (0s)..and then ran
audessy setup..reduce volume on your subwoofer to slightly above minimum(behind the subwoofer) before running the setup..once audessy setup is completed successfully..i started changing setup
manually..changed speaker config for front speaker to small (it is set as large by audessy setup), this should automatically adjust center and other speaker configuration (if not make sure to set them to small as well), then set the cross over frequency to 120..increase the volume on your subwoofer and now you should hear it fire..if this does not help..try playing some rock music with all channel streo mode..if your subwoofer does not fire even for this..then take the system back for exchange..
Dec 28, 2007 | Onkyo HT-SR800 System
Dual DWM-3900 System Logo
98 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Michial Gueffroy
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
