Fisher & Paykel GWL10 US won't spin
6 year old Fisher & Paykel GWL10 US won't spin. For awhile, the clothes in the very bottom seemed damper than usual. Yesterday's clothes didn't spin well, now a load today won't spin at all. It does not matter what I do...the machine will not spin the clothes dry
Buy an new one and trash this one
Posted on Sep 13, 2008
2 Suggested Answers
fanny
  • 146 Answers
SOURCE: Fisher & Paykel GWL10 US won't spin
If the machine still has water in it, the drain pump is jammed or there may be an obstrution in one of the hoses. It is most likely the drain pump. Switch off the machine at the wall and unplug it. Tilt machine against a wall and look underneath. On the right you will see the drain pump. It looks upside down. Unplug the wiring harness to the pump and remove pump by turning it clockwise while at the same time releasing the little white clip that holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
IWL16 leaves black specs on clothes
there could be something stuck in the machine between the two bowls. lifting the lid, removing the ring, agitator and inner bowl will easily check this. if the machine has become loud on spin, and the leak is actually from the bottom (more likely) then it could need seals and bearings replaced. don't run it too much more while leaking, electricity and water don't mix XD
Nov 10, 2013 | Fisher Paykel EcoSmart GWL15
I have a 10 year old Fisher & Paykel GWL10 washing machine. Fault code 1 is coming up. The machine turns completely off. The longer it cools down, the longer it goes before turning off again. This...
Code 1 - usually means on the later models of Fisher & Paykel is a faulty Motor Control Module, often though one would have to replace both as well as the display module.
Anyway - it sounds like the electronics are overheating hence the intermittent problems you are experiencing.
May 27, 2011 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel GWL10 begins to spin for about 15 to 20 seconds, just starts to pick up some speed, then machine beeps and shuts down. Seems like the water is draining. Any ideas? It has also been...
Yes it does seem like a control module fault.Bit concerned about the noise coming from the machine even thou it is not running.Please turn it off at the power point when not in use.Now if and when it faults again please reply back with error code as per 1st posting.
Jun 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
its possible that the pump is either going bad or there is somethin gin the pumps/sump assy. on this model the unit generally tends to shut down when the pump overheats, and will only restart when the pump cools off, a warnig obout replaing hte pump if need be is the pump is actually 220v. you MUST UNPLUG MACHINE BEFORE SERVICING. its a foriegn brand remember so theres abuncha wierd wiring and the pump is one of them!
Mar 25, 2008 | Fisher and Paykel IWL12 Top Load Washer
Sep 16, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
370 people viewed this question
Top Washing Machines Experts
