@joea1956
Try the following:
1. If you want WPA2 encryption on your router, (which also have higher security and compatibility issues with wireless cards), you could try WPA2-TKIP (which is standard encryption and made compatible for all wireless cards) or WPA2-AES (for specific wireless cards that are unable to connect to TKIP encryption)
2. If Step 1 won't work, try to lower your security encryption to WPA-PSK (either TKIP or AES) and try again. If this works, your IPAD2's wireless card doesn't support WPA2 encryption yet.
If all of the above fails, I do not recommend WEP since it's easily cracked (for advanced users) but you could try it as a last resort.
Good luck.
etting up wireless security is the easiest way to prevent other people from using your wireless internet connection. Your Linksys router supports three (3) of the most commonly-used wireless security types WEP, WPA and WPA2.
This article will explain the difference between WEP, WPA, WPA2 and how to set up each of them.
