Phillips dvd player
Cant get phillips hdmi dvdr3475/37 to play on tv i am using direct tv as primary signal source i have dvd hooked up using 3 wire hook up furnished by phillips
I need to figure out how to burn a dvd with my phillips hdmi recorder.
Posted on Nov 30, 2008
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
I have a Coby DVD938 hooked up through a cable box. The sound is fine when a DVD is playing, but when the TV plays, the sound is very quiet. I tried hooking the audio wires direct to the TV and had the...
You're Going to have continuous problems like that with your current configuration. You should plug your video and audio cables directly to a separate input into the back of you set. That's provided of course that you have another input on the set. If your set and dvd player are HDMI cable capable then you also would have typically another hdmi input. In that cast you don't need separate audio cables. The audio is carried as a digital signal in the HDMI cable.
Oct 28, 2013 | Coby DVD938 Theater System
PROSCAN PS27123 TV directions how to hook up dvd player
First, I strongly urge you to purchase a short HDMI cable IF BOTH units are equipped to utilize them. Run HDMI "out" from the player and hook the other end to HDMI "in" on the TV. That will avoid all this angst you are experiencing now since HDMI carries audio and video at a high resolution.
If you must use the RCA cables, make sure they are coming out of the"out" jacks on the player and going into the "in" jack on the TV. Now, I feel strongly your problem has to do with the "input" or "source" button on the remote. You MUST have it set to DVD player. Play with it. It's imperative to, with the remote, select the proper source - which in this case is DVD player, rather than, say, cable box, computer, etc. By the way, even if you use HDMI, you'll still have to do that, and you will also still have to select the correct input (sounds maybe like you have 3). Good luck!
Jul 26, 2017 | Televison & Video
Connected samsung ht x720 (home cinema system 2.1) to v+ box.Cant get picture when playing a DVD.Can hear the sound tough.Thanks
You probably need to change the incoming input signal on your tv.
In other words, your audio is coming directly out from your dvd player, and going directly to the audio power amp.
Your video does the same thing, except it goes to your tv. Your tv has multiple places for "incoming" signals to hook in to it. Take a look at where you're hooking your video in - the input should be marked ... something like "Component 1" "Component 2" "HDMI 1" "HDMI 2" ... something like that.
On your remove, there will be a button that says, "Input." When you push this, you will see that your TV brings up an input selection window. Pressing the "input" button on your remote should scroll through the ports on the tv. Briefly pause on each input selection to see if it begins receiving a video signal from your DVD player.
Nov 19, 2010 | Samsung Audio Players & Recorders
I dont really have a problem. I just dont know which port to hook dvd player to. I need maybe the layout of the back panal, on what goes where.
U have a lated DVD player,like less than three years old?U can hook it up with one cable wire.It call a HDMI cable.Very easy to hook up,just one end of the HDMI cable to the tv HDMI tv port hub,the other side of HDMI cable to the HDMI DVD player port hub that it.Now u,must know with HDMI hub port u put ur signal in like 1 to 4,now go to that HDMI port hub,and will find ur dvd disc picture in playing in.
Apr 26, 2010 | Mitsubishi WD-52528 52" Television
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
HDMI->DVI cable won't work
Are you using a HDMI to DVI cable or are you using a HDMI to DVI adapter? Sometimes, though not on all products you have to go into the menu and select which out put your using for each source and whats going through it. You might need to go into your dvd player menu and tell it not to try to run audio through the cable. That way it's not trying to force a signal through the cable that cant be accepted by the TV. That might possible solve your problem for the DVD player. Let me know if it works
Have a Great day
Aug 11, 2008 | Televison & Video
Problems playing my Phillips DVD/ VHS with my new WESTENHOUSE HDTV
I notice this was made in 2008 and I hope you have found the answer. But if you or others have not here is my answer. Are using the RCA cable from the output on the DVD Player and you have plugged it into the RCA in ports then you need to use the remote to move through the on screen menu. My INSIGNIA has a Source List menu on the remote that shows on screen. I can scope through the MENU for TV, Composite Side, S-Video Rear, S-Video Side, Composite 1, Composite 2, VCR, HDMI 1, HDMI 2, HDMI 3. That is found using either the INPUT button on the upper left on the remote or the buttons; VIDEO, COMP, HDMI, AND TV across the top of the remote. Hope this helps.
Apr 13, 2008 | Philips Televison & Video
Televison & Video Logo
171 people viewed this question
Top Televison & Video Experts
Electro Med Services...
