Question about Hotpoint First Edition FEW12 Front Load Washer
Crunching and grinding
Crunching/grinding noise coming from lower front right side. Seems to happen when drum is turning but not on a spin. It doesn't happen every time.
  • 641 Answers
That noise come from the pump that drived the water out the drum. Since you don't have this noise every time, it's seems like it's cause an unclean filter issue. Cleaning the filter - should solve this issue. Before openning the filter, prepare a bowl and a floor cloth to avoid water's flooding. Good luck !
Posted on May 25, 2006
When it spins, the washer makes a loud noise. it rattles. Also when it is doing the rinse cycle I can hear a vibration/rattling noise.
I'm sorry to say that tis is potentially very bad news. the problem you describe is almost certainly because the main bearing on the drum is worn out, allowing the inner drum to "flop about".
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. If the bearings are bad enough then symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is the result of the failing bearing allowing water to escape through the seal at the rear
Jul 07, 2011 | Maytag Washing Machines
The drum is getting very tight as if it is stuck especially when one uses the spinning
This is potentially very bad news I'm afraid. Beyond failed bearings, there are very few reasons for the drum to become tight.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. Other symptoms of bearing failure will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings)
You will have become aware of the spine cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins
Jul 05, 2011 | Washing Machines
I HAVE JUST FITTED MY NEW DRIVE BELT ON MY HOOVER WASHING MACHINE HSE130M AND IT KEEPS ON SLIPPING OFF?
This is potentially very bad news I'm afraid. There are very few reasons for a belt to come off. Presuming that you are convinced it is the right size (and it probably is) Then there is a fair chance that the belt is coming off because the main bearing on the drum is worn out, allowing the inner drum (and therefore the large drive wheel on the back) to "flop about".
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drup up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. If the bearings are bad enough to allow the belt to dislodge then symptoms will typically include:
A clonking noise as you lift and releas the inner drum (this is the inner drum rattling on its bearings
You will have become aware of the spine cycle becoming far noisier recently and pissibly even a grinding crunching noise when the machine spins
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is the result of the failing bearing allowing water to escape through the seal ar the rear
Jul 04, 2011 | Hoover HF130E Front Load Washer
Have grinding noise in front drivers side on a 2006 dodge ram 1500 4.7 v8 seems louder while turning
Had this problem of grinding/crunching/clicking left front. The front 4 x 4 didn't work. The front left axle had to be replaced.
Dec 15, 2010 | 2008 Dodge Ram Pickup 1500
XC90 Front end "Crunch"
you CV joints are going bad.  you need to have them checked and replaced.  Rebuilt units are availabe.
Mar 29, 2009 | 1999 Buick Century
Agitator ''dogs'' not gripping, agitator spins freely; tub rocks
Likely a broken dog itself was making the noise. They should all be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Hotpoint First Edition FEW12 Front Load Washer Logo
167 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
