Sony Cyber-Shot DSC-P32 Digital Camera
Problem for Sony Cyber-Shot DSC-P32 Digital Camera
Camera dropped, lens won't retract or expand
By smarks on May 24, 2006
My son dropped the camera smack dab on the lens while it was on in camera mode. The lens was crooked and you could hear the gears turning when you tried to shut the camera on or off. Is this fixable by me or does it have to be sent off? I've had estimates from $50 to $150, at the $150 price I should probably buy a new cam. Any help from anyone? Thanks
Same Problem
Aug 23, 2008
-   My Dad dropped his Panasonic Lumix with the zoom extended, now it won't extend. It's all the way back up inside the camera, and there's nothing to get ahold of to gently guide it back in the place. I've wiggled it a bit but it seems jammed pretty good. Is this a job for the technicians? He's already got a new one and this is mine if I can get it fixed. I'd welcome any suggestions.
Thanks
DL
-   DL Zeta
Aug 22, 2008
-   I was playing with some friends, and my camera, like smark's, fell on its lens, and now it th lens keep on going on and on, and it wont let me take a picture.-   bbyugar
Jul 23, 2008
-   i dropped my samsung S7360 - not on the lense - and now it won't focus. any help?-   Guest
May 09, 2008
-   I was taking pictures and I my camera hit a wall. There are no chips, dents, cracks or anything, but now the lens will not retract. How do I fix this?-   BrittyLynn
Apr 29, 2008
-   MY ZOOM LENS WAS STUCK AND I TRY TO PUT IT STRAIGHT BUT WHILE I WAS DOING THAT I DROP IT IN THE FLOOR NOW IS STUCK ALL THE WAY INSIDE THE CAMERA AND DONT CAME OUT . DOES IT HAVE A CHANCE TO BE FIX IF I SEND IT TO A TECHNICIAN OR THAT'S IT FOR THE CAMERA ?-   ANANIS
Best Solution
posted on Nov 06, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the advice, this is my story to the T, down to the son dropping the camera. lol. I tried unsuccessfully to gently pull and push lens several times. It finally clicked and works now. Easy fix. Thx for posting so I was more confident it would work than just trying to grit my teeth and hope for the best.
Solution #2
posted on May 26, 2006
Helpful)
bmwrider
Rank: Wiz  Sony Expert
Rating: 84%, 1902 votes
You sound as if you don't want to waste money on this camera. You could try to gently pull the lens straight. If it's leaning to the right then pull the lens to the left. Don't use brute force but it's possible to realign the lens this way. If it works you'll hear a click and the lens will look straight. Switch on and see if it retracts. I'd only use this as a last resort because you can cause additional damage if it's overdone. But believe me I've seen it done and I've done it myself with about a 40% win rate.
bmw
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
Helpful)
Nightdiver
Rank: Guru
Rating: 87%, 169 votes
Hi Smarks,
This is a common problem, which has happened to me as well. The only thing you can do is have a camera shop fix it. It should not cost more than $50.00 to get the lens back on track, and would be well worth it at that price.
Best regards,
nightdiver
Was this helpful?
Yes
No
Solution #4
posted on Oct 27, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
THANK YOU GUYS SO MUCH FOR THE INFO! WE WERE ABLE TO FIX OUR CAMERA BY JUST GENTLY POPPING THE LENS BACK INTO PLACE! Saved us $50. Thank you guys for all the help!
Solution #5
posted on Oct 22, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I took the advice of the above user and popped my lens back in place. My lens was leaning to one side, so I gently pushed it to the other side until I heard a pop. Then, my lens was able to retract and the camera works.
Solution #6
posted on Sep 05, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
THANKS GUYS SO MUCH FOR THIS....IN MY CASE I TRIED TO MOVE A LITTLE THE LENS WHILE THE CAMERA WAS OFF...BUT WHEN I TURN IT ON THEN I COULD EASILY MOVE THE LENS IN THE RIGHT POSITION. I SAVED SO 50$.
Solution #7
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
same exact thing happened to my Pentax S5z (great camera). Lens jammed and would not retract, so it powered down with lens out. Here's what I did, and the results:
I powered up, and as it tried to extend/retract the lens, I shoved it closed. Then I tried to power it up again--repeatedy, though, the lens didn't move and it powered right off each time. Eventually the grinding sound stopped. I fully disassembled the unit (easier than I thought, did it in a minivan at 70MPH at the time, using eyeglasses screwdriver) and confirmed I burned out the motor that extends/retracts the lens. There are also some very small plactic nubs and springs that you will probably break off and lose like I did. This does not help either. then tried looking for used S5Z's on the internet... let you know how that works. The Option Z10 is NOT it's equal.
Solution #8
posted on Aug 19, 2008
Not Rated)
Lulaa
Rank: Apprentice
Rating: 0%, 0 votes
Bad Thing I Did that and when i press the on button it wont turn on. should i take it back to the shop?
Was this helpful?
Yes
No
Solution #9
posted on Jul 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This is the same problem I am having and will try it for myself once I get back my free repair estimate. I had another camera that wouldn't open. The repair was $100+. I tried gently rubbing around the lens gap (with my finger nail) and it opened. I can't believe they were going to charge so much for such a simple fix!
Popular Solutions for Sony Cyber-Shot DSC-P32
Questions and Unsolved Problems for Sony Cyber-Shot DSC-P32
Do you recommend Sony Cyber-Shot DSC-P32 Digital Camera?
Answer
Answer
I turn it on and the screen says turn off then back on, and the shutter cap will not open in front
Answer
When I turn on my camera I get a C:13:10 format error. What is this and why is it occuring?
Answer
I plug in my cybershot, XP tells me that the device is ready to use, then it tells me that the... (More)
Answer
I have swapped out the memory stick and it still tells me "No Memory Stick." I have taken... (More)
Answer
lens open, but the screen stays black on picture taking mode or on pics review. please help.
9 Other Users Have The Same Problem - Continued
Comment by vickiepickie, posted on Apr 21, 2008
my camera wont turn on it always tells me that there is a lens errer 1500326 i dont understand. HELP ME!*!*!*!*!*
Comment by hunnybear, posted on Mar 25, 2008
My camera was dropped while in camera mode, the lens will not retract, but I can hear it clicking when I try to take a picture. I can look at other pictures on camera.
Comment by Guest, posted on Mar 06, 2008
Camera was dropped on lens and now it wont retract. can this be easily fixed?
Comment by nerds12343, posted on Feb 24, 2008
i droped my camera when it was open right on the lens now it wont expand or close
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
