Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore model 525321 overheat problem
Wed a.m. smelled what i thought was "electrical" burn. couldn't locate in kitchen. later that day went to get ice but it came out slushie. opened freezer, everything was defrosting. husband came in, took off back, found burnt wires and had me order the start/overload relay. he replaced it, plugged fridge back in and waited. fridge is on but does not run still. compressor hot to touch so unplugged, checked wires again as the part our local appliance center ordered from whirlpool stated it was a manufacturer's substitute. is there a chance the wiring setup is different?
  • 943 Answers
Hi thanks for the question after your husband replaced relay & overload if the compressor started & kept on running but no cooling you have a bad compressor
Posted on Sep 22, 2008
My Kennmore 79363 Gas Range/ Electric Oven electrical doesn't work. Started smelling electrical burning smell, tracked to oven. shut off breaker, smell stoped. Few hours later checked again after...
The person who installed the oven didn't do the connections up tight enough.
I would replace the breaker/power switch with a new one and trim back the wires if the burning is in the breaker. If on the rear of the oven, same applies with badly tightened connections.
If in doubt, call a qualified electrician. That will be better than having a fire!
Aug 06, 2017 | Kenmore 79363 Gas Kitchen Range
I have a Kenmore Elite model 110.63022100. My dryer runs for 30 seconds to 1 minute before completely powering off. There is a burn smell when it stops.
Usually when an electric dryer overheats and shuts down, it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat.
Jan 09, 2011 | Kenmore Dryers
Burning chemical smell coming from the gas dryer
You first thought was probably the correct one...the fumes from the new paint may take a few days to disspate enough not to react with the heat of the dryer...I would give it a few dyas to clear before looking any further...
heatman101
May 28, 2010 | Kenmore Elite HE4 Electric Dryer
HAVE A MODEL KENMORE ELITE He4 ELECTRIC DRYER. IT
Check the burner tube and clean it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2009 | Kenmore Elite HE4 Electric Dryer
The Kenmore Model 70 Smells Electrical Burning,
Hi..
You need to unplug the washer. Locate the source of the odor then read the instructions in the related section.You need to open the back cover, Check the parts which is spark, and become faulty, there is a short circuit, that become loose contact.
Regards
PCmania
Jul 15, 2009 | Kenmore 22422 Top Load Washer
Stuck at 288 degrees
NO PARTS REQUIRED!!! DON'T PAY FOR A SERVICE CALL!!!
After a power outage, my wife's grandmother said she could no longer set her over to 300, 400, 450, whatever..
I went over to troubleshoot.
I couldn't figure out why everything seemed functional and why I couldn't set the over to higher than 288 (and thought, that's a rather odd number)... until I realized that that 288 degrees C = 550 degrees F which is the max the oven can do.
The power outage reset the computed back to celcius instead of fahrenheit.
Save them a ton of money... cause this could have been an easy cash grab to some cook out there.
May 01, 2009 | Kenmore Kitchen Ranges
Dryer shutting off too early. Faint smell of something burning?
Check the vent for clogging condition that will turn off unit and cause it to overheat. If vent goes up to roof check up there also - that is where mine was clogged with a sort of paper mache clog!!!!!
Sep 02, 2017 | Whirlpool LER4634J Electric Dryer
Kenmore Elite Dishwasher model 16264 electrical fire
I contacted my lawyer who advised that I file a Civil Complaint against Sears so that is what I have done.
Feb 18, 2009 | Kenmore 24 in. 16264 Built-in Dishwasher
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
135 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
